clemwehner
Posted: Thu Dec 03, 2009 9:28 pm Post subject: battery capacity |
How do I determine the minimum battery capacity required for a KF model IV with a 912 and minimal avionics?
I'm convinced the RG (starved electrolyte) battery is the right type (like the Odyssey), but what size is the right size? We're looking to save weight but don't want to do anything stupid.
thanks,
Clem Wehner
KF IV-912
Oklahoma
_________________ Clem
Oklahoma
Kitfox IV-912, under construction since 1991 |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Dec 04, 2009 8:26 am Post subject: battery capacity |
Clem,
I bought the PC680 recommended by a friend. You won't be sorry with an
Odyssey. They will hold a charge up to two years and the one I bought was
fully charged out of the box. It won't fit in the factory box, but then it
doesn't require a box. I made a tray out of aluminum with a velcro strap.
Lowell
Guy Buchanan
Posted: Fri Dec 04, 2009 10:15 am Post subject: battery capacity |
At 09:28 PM 12/3/2009, you wrote:
| Quote: | How do I determine the minimum battery capacity required for a KF
I've been doing fine with a 20ah battery. I use the Powersonic
because I'm cheap, but I think the Odyssey has more cranking power.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
clint_bazzill(at)hotmail. Guest
Posted: Fri Dec 04, 2009 3:27 pm Post subject: battery capacity |
I am using a motor cycle battery. GTX14-BS. Easy to get anywhere C put the acid in when you buy it. You can buy them anywhere and they are not expensive.
I change it out at annual time C every other year. Haven't had one go bad. Just about 1500 hours now on 912ULS.
Clint
and I have a lot of avonics. Model IV-1200
[quote] From: lcfitt(at)sbcglobal.net
Subject: Re: battery capacity
Date: Fri C 4 Dec 2009 08:12:36 -0800
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Clem C
fully charged out of the box. It won't fit in the factory box C but then it
Lowell
Dick Maddux
Posted: Sat Dec 05, 2009 5:55 am Post subject: battery capacity |
Clint,
Like you I am also using the GTX14-BS. Bought it at Walmart and seems to be holding up fine after 1 1/2 years but the Odyssey is tempting. I wish it would fit in the battery box.
Dick Maddux
Fox 4
912UL
Milton,Fl
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sat Dec 05, 2009 5:15 pm Post subject: Re: battery capacity |
I have been having battery issues as well so I am wondering what you guys think about this. I have the battery which is in the Kitfox catalog and presumably it has been in the plane for 2 years. Since the temps have dropped down below 55f I have not been able to start the plane cold without jumping it from my truck. I took the battery to Autozone twice and both times it tested fine, when I throw the charger on it it indicates 90-95% charge after it has sat for a week but it runs out of juice before it gets started. Today it was 34f wen I was starting the plane and with jumper cables it took about 30-40 seconds to start. I have seen video of Dave hand propping in the snow with less trouble so I don't get it. Any thoughts?
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Paul A. Franz, P.E.
Posted: Sat Dec 05, 2009 6:51 pm Post subject: battery capacity |
On Sat, December 5, 2009 5:15 pm, WurlyBird wrote:
clip clip
Running the battery to nearly dead then recharging it repeatedly definitely is severe
usage and shortens the battery life. Two years is about the normal life span of these
smaller batteries used heavily, that is from full charge to a very low voltage
condition frequently. So, it is not unreasonable to replace that battery now. But
before you do, make some measurements. With the jumpers connected right at the battery
and while cranking it over measure the voltage. Then do it again right at the starter.
That will determine the voltage drop in the cable. I think that it should not be more
than 2 to 2.5 volts drop. If it is, examine the connections and make a determination
whether your cable is big enough. You didn't say where your battery is located. If it
is in the tail, then the long run means generally you need a larger gauge cable than
for a very short run.
Another thing to consider when sizing a battery for aircraft the starting function is
not generally the limiting factor. It is the time required to complete the operation
running only what's on the essential buss. So, say your minimum essential load is 10
amperes and your minimum required time to complete the operation is one hour then you
will need to have a battery with a capacity of 10 AMP-HRS *BEFORE* it discharges to
the minimum operational voltage. That minimum voltage at the buss is probably around
10 to 10.5 volts or about the top 25% of the battery's capacity so in this case you
would need a battery with a capacity of 40 ampere-hours roughly. I believe Bob
Nuckolls recommends using two batteries, each with about half the required capacity
and changing them out in alternate years so one battery is always under a year old and
the other is under two years.
I didn't verify the numbers quoted above so they aren't precise but you get the idea.
Time to complete your present operation should there be an alternator failure, is
probably more limiting than is cranking capacity.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
Suppose you were an idiot. And suppose you were a member of
Congress. But then I repeat myself.
-- Mark Twain
"It does not take a majority to prevail ... but rather an irate,
tireless minority, keen on setting brushfires of freedom in the
minds of men."
--Samuel Adams
"We, the members of the New Republican Party, believe that the
preservation and enhancement of the values that strengthen and
protect individual freedom, family life, communities and
neighborhoods and the liberty of our beloved nation should be at the
heart of any legislative or political program presented to the
American people."
-- Ronald Wilson Reagan (1911 - 2004)
"Wise politicians will be cautious about fettering the government with
restrictions that cannot be observed, because they know that every break
of the fundamental laws, though dictated by necessity, impairs that
sacred reverence which ought to be maintained in the breast of rulers
towards the constitution of a country."
-- Alexander Hamilton, Federalist No. 25, 1787
"A fondness for power is implanted, in most men, and it is
natural to abuse it, when acquired."
-- Alexander Hamilton, The Farmer Refuted, 23 February 1775
"This Government, the offspring of your own choice, uninfluenced and
unawed, adopted upon full investigation and mature deliberation,
completely free in its principles, in the distribution of its powers,
uniting security with energy, and containing within itself a provision
for its own amendment, has a just claim to your confidence and your
support."
-- George Washington, Farewell Address, 1796
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
WurlyBird
Float Flyr
Posted: Sun Dec 06, 2009 1:04 pm Post subject: battery capacity |
The main requirement for the battery is to start the engine. If your engine doesn’t have a starter you don’t need a battery at all. For that reason the size of your starter and the amount of work it has to do should be what governs the capacity of the battery.
This is a bit off line here but certified planes can install electrical load to the capacity of the alternator if they have a load meter if they don’t have a load meter they are only supposed to install electrical load to 80% of the generating capacity. Many airplanes have plugins for external batteries or power supplies to start the engine… That saves a lot on weight carried aloft.
My 582 was supposed to have a maximum of 16 Amp continuous generating capacity. The most load I had installed was for around 8 Amp. That meant that with everything I had on board turned on I was still only at 50% of my generating capacity.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clint Bazzill
Sent: Friday, December 04, 2009 7:53 PM
To: Kitfox list
Subject: RE: battery capacity
I am using a motor cycle battery. GTX14-BS. Easy to get anywhere, put the acid in when you buy it. You can buy them anywhere and they are not expensive.
I change it out at annual time, every other year. Haven't had one go bad. Just about 1500 hours now on 912ULS.
Clint
> To: kitfox-list(at)matronics.com
> Date: Fri, 4 Dec 2009 08:12:36 -0800
> Clem,
> Lowell
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Paul A. Franz, P.E.
Posted: Sun Dec 06, 2009 2:42 pm Post subject: battery capacity |
On Sun, December 6, 2009 1:01 pm, Noel Loveys wrote:
| Quote: | The main requirement for the battery is to start the engine. If your engine
doesn't have a starter you don't need a battery at all. For that reason the
That would only be true if your essential load was zero. That is, the case if you
require no power at all to complete a flight operation safely in the event of
alternator or VR failure. Night flight, operation in Class B airspace, or IFR flight
would certainly have some essential loads for lighting, navigation and communication.
If you don't *EVER* need those, then it is reasonable to declare you have no essential
load. The reserve battery capacity to complete a flight operation safely while
operating the minimum essential load with an alternator or VR failure is usually more
than that required for engine starting.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
In general, the art of government consists of taking as much money as possible from
one party of the citizens to give to the other.
-- Voltaire (1764)
Bellevue WA
425.241.1618 Cell
Posted: Sun Dec 06, 2009 4:45 pm Post subject: battery capacity |
This sort of sounds like it is right out of Mr, Nuchols posts of a decade
ago. He, at the time, was a regular participant on the Kitfox list and due
to his urging, I wired in the essential buss and all the trimmings in my
1993 Model IV. It sounded like a good idea at the time. The only thing,
though, was the need in the 912 installation, to put a dummy load in the
charging circuit on case you ever shut down the altenator to prevent frying
the regulator. I don't understand the circuitry, but that was what I
understood.
In short, the only thing my essential buss switch served for was as a
conversation starter as almost everyine that ever sat in the passenger seat
asked what that switch labeled "Essentail Buss" was for. I never installed
the dummy load and my day VFR flying for the 900+ hours the airplane lasted,
I never had an occasion to need it.
Bob Nuchols is the Guru, but most Kitfoxes do not use an alternator that is
capable of runaway charging voltages and the need of an alternator switch to
protect a battery from a runaway alternator. In my opinion, he might have
something to say about certified installations and particularly those in
complex aircraft like the Lancair and some others, but to use much of what
he recommends in our stock Rotax installations results in way overkill. For
some reason, I also prefer circuit breakers to fuses.
Lowell
Float Flyr
Posted: Mon Dec 07, 2009 5:52 am Post subject: battery capacity |
My take on it, after having a look at the schematic, is the voltage
regulator requires some load on it at all times to work properly. Without
the load if you happen to turn everything off the regulator can overload and
go into runaway. If that happens with a 9XX and the built in alternator the
answer is simply to switch everything on and unfortunately, replace your
regulator/rectifier as soon as practical. If you have an optional high
output exterior alternator don't turn anything on because the voltages will
be high enough to fry bacon.
I do have a question I'd like to pose to Msr. A. Bombardier. Why didn't
they build in a load into the rectifier/regulator? It would make wiring a
lot easier for amateurs who are more interested in flying
Noel
Kitfox III-A
occom
Posted: Mon Dec 07, 2009 2:00 pm Post subject: battery capacity |
I would guess that Bombardier didn't build in a dummy load because A) they
didn't design or build it, B) it isn't necessary when an actual load is
present C) the heat generated by wasting 12-16 watts of generated power
would be damaging to the unit without a constant source of cooling and D)
because this is the cheapest unit they could find that does the job most of
the time. (well it's cheap when Rotax BUYS it. No guarantee about when they
sell it).
I posted a long time ago about how these units regulate and the advantages
and disadvantages of each. The best by far is the key west unit if you want
to stick to "official" units. Any unit off virtually any permanent magnet
alternator equipped motorcycle, scooter, outboard, garden tractor, could be
used even one from a late model Harley if you are predisposed to Harley type
stuff.
Guy Buchanan
Posted: Tue Dec 08, 2009 8:15 am Post subject: battery capacity |
At 04:39 PM 12/6/2009, you wrote:
| Quote: | Bob Nuchols is the Guru, but most Kitfoxes do not use an alternator
that is capable of runaway charging voltages and the need of an
alternator switch to protect a battery from a runaway alternator.
For about a year I had my voltage regulator intermittently fail,
allowing high voltages into the system. The Nucholls "crowbar"
overvoltage system handled it so well I didn't get around to fixing
it for quite a while. I finally replaced the regulator with a Key
West which solved the problem. I built Bob's "simple" Rotax schematic
which didn't have any of the essential bus stuff, but if I was going
to fly at night or IFR (I do neither) I probably would.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Float Flyr
Posted: Wed Dec 09, 2009 11:58 am Post subject: battery capacity |
As far as I know the load resistor is a fairly hefty thing... as electronic
resistors go. I don't think it can handle anything over 2W and is designed
to pass a lot lower wattage than that. Without checking I think the
resistor that was on my 582 was around 3.5 kOhm. That means there is about
.0039A. going across the resistor or .05 W. at stabilized 13.8V.
Noel
Kitfox III-A
