JRatcli256(at)aol.com Guest
Posted: Sat Dec 05, 2009 8:13 am Post subject: oil sucked outmy 912 |
Ralph B.,
Read about this vent line problem before. Think it was on Rotax site.
Routed my oil vent line down thru the bottom of my fuselage.
Put a plastic (T) fitting near the end of my vent line before it exited thru the fabric at the bottom with the side leg open to unpressurized air inside the fuselage. This will break any vacuum created by slip stream passing the end of the tube below the aircraft.
John Ratcliffe
