f4ffm2(at)roadrunner.com Guest
Posted: Tue Nov 17, 2009 11:32 am Post subject: TSA run amok |
If you aren't already a bit worried about the powers of the DHS and the TSA, may I suggest that you read the below referenced story. As I see it, an agency truly run amok.
Policy Watch [img]cid:2BD565DF-AF32-44D7-A703-E7595D28000A(at)san.rr.com[/img][img]cid:D14BF226-079E-4EC2-B94F-241C59E73145(at)san.rr.com[/img]TSA seeks inspection authority for aircraft-repair shops
The Transportation Security Administration on Monday sought regulatory authority over airplane-repair shops, arguing that terrorists could use the facilities to sabotage planes undergoing maintenance. There are nearly 5,000 approved repair shops around the world, where work can range from mending upholstery to overhauling engines. TSA is especially concerned with shops on or near airport property, where terrorists could potentially take control of an aircraft for use as a weapon. Critics of the proposed policy note that all shops working on U.S.-based planes already are subject to FAA licensing and inspection. USA TODAY(11/17) [img]cid:9E9FB78B-0CCA-477D-9D83-FE879F99914F(at)san.rr.com[/img][img]cid:D14BF226-079E-4EC2-B94F-241C59E73145(at)san.rr.com[/img][img]cid:EEF5975A-26AE-4A89-B2BE-9E697F3AE94C(at)san.rr.com[/img][img]cid:D14BF226-079E-4EC2-B94F-241C59E73145(at)san.rr.com[/img][img]cid:98244FF5-57AB-43DC-BA04-068EC3ED8481(at)san.rr.com[/img][img]cid:D14BF226-079E-4EC2-B94F-241C59E73145(at)san.rr.com[/img][img]cid:07F8F088-DF06-41AA-ABAA-CCDE398A163C(at)san.rr.com[/img][img]cid:D14BF226-079E-4EC2-B94F-241C59E73145(at)san.rr.com[/img][img]cid:D7E09E12-5184-4A04-8A93-46245729B34D(at)san.rr.com[/img][/list]
191 Bytes |
1980 Time(s) |
43 Bytes |
1980 Time(s) |
246 Bytes |
1980 Time(s) |
1 KB |
1980 Time(s) |
561 Bytes |
1980 Time(s) |
589 Bytes |
1980 Time(s) |
467 Bytes |
1980 Time(s) |
Posted: Wed Nov 18, 2009 8:59 am Post subject: TSA run amok |
Just a thought and a reference from the past if I may be so bold:
"McCarthyism was the politically motivated practice of making accusations of disloyalty, subversion, or treason without proper regard for evidence. The term specifically describes activities associated with the period in the United States known as the Second Red Scare, lasting roughly from the late 1940s to the late 1950s and characterized by heightened fears of communist influence on American institutions and espionage by Soviet agents."
Now simply replace "communist influence" and "espionage by Soviet Agents" with: Terrorism and Al-Qaeda agents.
Sorry for being so "off topic", but running "amok" is exactly the right term. Also spreading fear and taking away personal freedoms in the name of security and safety.
Mark Bitterlich
smime.p7s |
5.09 KB |
239 Time(s) |
cjpilot710(at)aol.com Guest
Posted: Wed Nov 18, 2009 9:48 am Post subject: TSA run amok |
In a message dated 11/18/2009 12:00:44 P.M. Eastern Standard Time, mark.bitterlich(at)navy.mil writes:
Not to be labor further - - -
"Those who give up their liberty for more security neither deserve liberty nor security"
Benjamin Franklin
| Quote: | Just a thought and a reference from the past if I may be so bold:
Mark Bitterlich
