AC 500S In-Flight Breakup
wjrhamilton(at)optusnet.c
PostPosted: Sun Nov 08, 2009 6:42 pm    Post subject: AC 500S In-Flight Breakup Reply with quote
http://www.atsb.gov.au/publications/investigation_reports/2007/aair/ao-2007-029.aspx
Folks,
This is worth a look, just out today.
The accident sequence appears to be almost identical to a sister aircraft breaking up in severe turbulence in Tasmania several years ago, ie: The wings failed in downward bending in the vicinity of the main spar section change just outboard of the engine nacelles.
Steve Nott, who was killed in the accident, was the proprietor of the only Twin Commander service centre in this part of the world, his one 690A Grand Renaissance rebuild has to be seen to be believed.
He owned a considerable fleet of 500S (10+), and all were kept in impeccable condition, the structural failure (as in Tasmania) was straight overload, no suggestion of a fatigue failure or any corrosion issues.
Best regards,
Bill Hamilton
ZK-DCF
 Filesize:  530 Bytes
 Viewed:  1615 Time(s)
