Autumn flight in Kansas
rickofudall
PostPosted: Wed Nov 04, 2009 7:05 pm    Post subject: Autumn flight in Kansas Reply with quote
After the chickens and guineas were loosed, the dog walked, and the second cup of coffee, I hit the hangar determined to get two projects done. One, build a camera mount to go on the top of the left strut and, two, tuft up the left side of the fuselage and go fly around and film the tufts. The camera mount was pretty straight forward, just a couple of pieces of aluminum angle and a few holes. Tufting up the fuselage didn't take long and by the time I had Zulu Delta all fueled and ready it occurred to me that my neighbor, John, had asked me about how the Kolb landed with flaps. Seemed like a great way to get him to take a few pictures so I did a half flap take off and landing then a full flap landing after which I departed the pattern to go see if my first attempt at aerial videography would net me anything. The little Nikon did great although the contrast when the camera was in the shade and I was backlighted was a bit too much to ask. The tuft study was done at airspeeds from 62 to 84 mph and confirmed what I suspected. The sides aft of the pilot on the Mk IIIC are pretty much stagnated or otherwise disturbed. only the most aft tufts showed straight flow going into the prop. In the middle of the panel all the tufts point upward at ever increasing angles as speed increases. Those just behind the widest point of the fuselage are very disturbed. The two upper ones got entangled almost immediately and stayed that way throughout the flight regardless of speed. The most curious was the lowest tuft in the second row aft. It pointed forward no matter the speed while both the ones immediately forward and aft of it were pointing aft and up.
Now I have to learn to use Movie Maker so I can cut the video down and add titles for each of the speed ranges. As soon as I have it ready I'll post it on You Tube.
Although I didn't film or get any pictures of the second flight of the day. I got the prop extension bolts just after noon and had the extension on in time to make a flight just before sundown. I suspect, given that my tach bouncing problem reappeared, although milder than running the two blade prop, that my next project is going to be a prop balancer.
Rick Girard
 Filesize:  172.46 KB
 Viewed:  4403 Time(s)
 Filesize:  171.81 KB
 Filesize:  124.16 KB
 Filesize:  166.37 KB
ces308
PostPosted: Wed Nov 04, 2009 7:40 pm    Post subject: Re: Autumn flight in Kansas Reply with quote
Rick,
Nice pictures ! Second...do you think VG's would help the cabin side area??
chris ambrose
Mark III Xtra / Jabiru A-2200
N327CS
Richard Pike
PostPosted: Wed Nov 04, 2009 7:57 pm    Post subject: Re: Autumn flight in Kansas Reply with quote
ces308 wrote:
Rick,
chris ambrose
N327CS
Get some VG's some tape, and stick them in various places on the doors, fuselage sides, etc. And film all of them. You might get lucky.
At worst, it would be like feeding crackers to a dead man...couldn't hurt much... Tell everybody you're on an FFF project - flyin', filmin, and foolin around... As long as you can annoy Al Gore by adding CO2 to feed the cabbages it's all good...
Richard Pike
MKIII N420P (420ldPoops)
rickofudall
PostPosted: Thu Nov 05, 2009 6:09 am    Post subject: Autumn flight in Kansas Reply with quote
Richard, I don't want to annoy anybody. I offset the carbon from the 582 by keeping the thermostat in my house at 55 and doing solar harvesting (opening and closing blinds to follow the sun's track, not very high tech but it works)  For what it's worth, I know about climate change, I grew up in the central valley of California and watched it happen there. I moved to Seattle in the late 70's and watched it go from clear skies and clean air to air pollution alerts within 20 years. If you want to believe the industry lackeys and outright liars, feel free. I'll believe my eyes.
Rick
On Wed, Nov 4, 2009 at 9:57 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
ces308 wrote:
> Rick,
> chris ambrose
> N327CS
Richard Pike
http://forums.matronics.com/viewtopic.php?p=271064#271064
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
slyck(at)frontiernet.net
PostPosted: Thu Nov 05, 2009 6:30 am    Post subject: Autumn flight in Kansas Reply with quote
I'm looking forward to those movies.
BB
Rick Girard
<STOL lift off 3 resize.jpg><Half flaps and slippin resize.jpg><full
flap roundout 1 resize.jpg><All tufted up.jpg>
