nuckollsr(at)cox.net Guest
Posted: Wed Apr 12, 2006 9:47 am Post subject: Current Limiter On The Aft Side of Firewall |
At 12:01 PM 4/12/2006 -0500, you wrote:
Quote: |
Bob ...
Do you see any problem with mounting the current limiter on the aft side of
the firewall? I'm trying to keep most electrical hardware components off
the engine side of the firewall.
Why? There's nothing inherently evil about mounting
things under the cowl. You simply choose parts designed
to function well in that environment. Certainly things
like contactors, current limiters, shunts, and batteries
are candidates for mounting on forward side of firewall.
Generally speaking, from a maintenance perspective, things
are easier to get at on the forward side of firewall than
aft side. I'd put as MUCH stuff as practical on the front side
with an idea of minimizing firewall penetrations by wires . . .
especially fat wires.
Quote: | Is there a limiting wire size for fuselinks ... where the smoke generated
from burning them is just too much for the human body to cope with?
Review Note 4 of
http://aeroelectric.com/articles/Rev11/AppZ_R11F.pdf
Fusible links are ROBUST. They're kind the mini-version
of ANN/ANL current limiters. Compared with fuses, they'll
carry a LOT of current for a long time. I would not
recommend them for any applications other than those
suggested in the Z-figures. Further, it's best that
any fusible link be under the cowl and not in the
cockpit.
Quote: | At one time, I thought, the max fuse size for fuse blocks was 20A. B&C now
lists 15A. For amperages over 15, what do you suggest for protection of the
wire?
The Bussmann rating for these fuseblocks is 30A max
for any one branch. As I pointed out in the recent article
on switch failures . . .
http://aeroelectric.com/articles/Anatomy_of_a_Switch_Failure/Anatomy_of_a_Switch_Failure.html
. . . electronic components are most likely to fail because
of environmental effects (in this case, compromised metal
to metal contact at the contact rocker). De-rating helps to
slow down the rate at which environmental effects chip away
at a device's performance.
What system needs a higher fuse value than 15A?
< with experiment. >
< --Lawrence M. Krauss >
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Wed Apr 12, 2006 11:35 am Post subject: Current Limiter On The Aft Side of Firewall |
Quote: |
<nuckollsr(at)cox.net> Firewall
>Bob ...
>of
The airplane is an RV8A which is nose heavy by design. The battery goes
behind the aft baggage area. There is no battery planned to go on the
firewall. Therefore any electrical hardware mounted to the firewall would
require more penetrations than already planned.
Quote: | Generally speaking, from a maintenance perspective, things
The design of the RV8A includes a storage well directly behind the firewall,
on the right side and below the fwd baggage area. This storage well
provides convenience for working on fuses, contactors, aux battery and a
wiring center. This makes the distance from contactors to fuse blocks only
4-6 inches. The baggage door covers all of this storage well. There is no
need to remove engine cowling unless there is a stater or alternator
problem.
The endurance bus feed is planned to be tapped off the hot battery bus
through a fuse similar to Z12. The endurance bus will be running about
22A. It seems this feed wire needs to be moved to the hot battery bus lug.
Should this be done and what method of wire protection should be used with
this source of power for the endurance bus?
Thanks ...
Jerry Grimmonpre'
endspeed(at)yahoo.com Guest
Posted: Wed Apr 12, 2006 1:14 pm Post subject: Current Limiter On The Aft Side of Firewall |
Hi Jerry, I too, believed the 8A would be more
forward in cg than the tailwheel 8. I came across
some info, where escapes me, that stated the 8A is
actually less forward in cg than the 8. Apparently,
the gear towers in the 8 are quite heavy and move the
cg more than the 8A's nose gear. Investigate this to
verify it. I too, will check it out. Bob
--- Jerry Grimmonpre <jerry(at)mc.net> wrote:
Quote: |
Grimmonpre" <jerry(at)mc.net>
L. Nuckolls, III"
>>Bob ...
>>of
mounting
designed
things
batteries
firewall.
perspective, things
firewall than
the front side
This storage well
problem.
the hot battery bus
Thanks ...
Jerry Grimmonpre'
browse
Subscriptions page,
FAQ,
Admin.
Jerry Grimmonpre'
Posted: Thu Apr 13, 2006 9:10 am Post subject: Current Limiter On The Aft Side of Firewall |
Hi Robert ...
Your thoughts about the 8 cg being more fwd, were thought provoking sending
me to Van's site. Empirical comparisons brings me to the possible belief
the lack of rake on the 8 gear along with the weight of the towers, could
place the cg fwd of the 8A. That tail wheel, being some 16' aft of the main
gear, does serve as a powerful arm in the scheme of things. Thanks for your
info Robert.
Jerry Grimmonpre'
Quote: |
<endspeed(at)yahoo.com>
