z601a(at)anemicaardvark.c Guest
Posted: Mon Oct 26, 2009 7:57 am Post subject: Cowling attachment, O200 |
This is a query to anyone who used the Continental O200 on their 601XL. How
did you attach the fiberglass cowling to the rest of the aircraft?
I'm looking for ideas. Whilwe I can comew up with something, I hate to
reinvent the wheel if someone already has a good solution.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Mathematics and alcohol do not mix.
Do not drink and derive.
Doug.Norman(at)sportaviat Guest
Posted: Mon Oct 26, 2009 3:28 pm Post subject: Cowling attachment, O200 |
Take a look at what AMD does (www.newplane.com). If you need detail pictures
I can probably photograph my cowling and send them to you.
Doug Norman
(AMD N601DN)
Posted: Sun Nov 01, 2009 3:58 pm Post subject: Cowling attachment, O200 |
Thanks. I reviewed the relevant area of the video, and looked up the fasteners
on the Internet. You're right on both counts: they look like they'd work
better, but it looks like enough to do the XL would cost $300-$400.
However, unless I come up with something like looks like it would work, that
may be the only choice.
On Monday 26 October 2009 19:47, Sabrina wrote:
I used 13 (7 top, 6 bottom) Camloc CM1 adjustable depth receptacles. I
made up my own brackets and mounted them to the firewall. My cowling is
mounted outside the sideskins.
At 4 minutes into this video you can see the brackets:
http://www.youtube.com/watch?v=_ZQfypsw8k4
I am at school and do not have access to my plans or build photos.
They are not cheap, but they hold much better than my attempts with Dzus
fasteners.
http://forums.matronics.com/viewtopic.php?p 69579#269579
Do not archive.
Jim B Belcher
A&P/IA
jfowler120(at)verizon.net Guest
Posted: Sun Nov 01, 2009 4:36 pm Post subject: Cowling attachment, O200 |
While it was about 3-4 years ago when I bought camlocs for the same
application -- although difficult to buy at the time they were about, on
average, $4 each.
Karl
Sent: Sunday, November 01, 2009 6:34 PM
To: <zenith601-list(at)matronics.com>
Subject: Re: Re: Cowling attachment, O200
<z601a(at)anemicaardvark.com>
fasteners
that
> fasteners.
Do not archive.
Jim B Belcher
A&P/IA
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sun Nov 01, 2009 5:02 pm Post subject: Cowling attachment, O200 |
Jim,
I used hinges to connect the bottom cowl to the fuselage. Pictures at
http://picasaweb.google.com/floyd.wilkes/2008_02_07#
I used nutplates and screws to attach the top cowl.
I take off the top cowl then just pull the pin and the bottom is off.
This method is used a lot by the RV folks.
This is a fairly cheap way to do it.
Floyd Wilkes
601XL O-200
_________________ Floyd Wilkes |
Posted: Sun Nov 01, 2009 8:14 pm Post subject: Cowling attachment, O200 |
I would agree it should be less expensive, and probably adequate structurally.
But doesn't the bend in the piano wire in the hinge make it difficult to
remove?
On Sunday 01 November 2009 18:56, Floyd Wilkes wrote:
Jim,
Do not archive.
Jim B Belcher
A&P/IA
floyd wilkes
Posted: Mon Nov 02, 2009 3:57 am Post subject: Cowling attachment, O200 |
Jim,
It is very easy to remove and install.
Floyd Wilkes
pdn8r(at)yahoo.com Guest
Posted: Mon Nov 02, 2009 6:56 am Post subject: Cowling attachment, O200 |
I also used the hinge and nutplate method on my RV. It worked very well, was inexpensive and only took a couple minutes to remove the whole cowl.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Sun, 11/1/09, Floyd Wilkes <fwilkes(at)gvtc.com> wrote:
Subject: RE: Re: Cowling attachment, O200
Date: Sunday, November 1, 2009, 7:56 PM
--> Zenith601-List message posted by: "Floyd Wilkes" <fwilkes(at)gvtc.com (fwilkes(at)gvtc.com)>
Jim,
Floyd Wilkes
601XL O-200
