Drilling 1/8" hole on the fuel vent tube
Thruster87
PostPosted: Wed Oct 21, 2009 11:46 am    Post subject: Drilling 1/8" hole on the fuel vent tube Reply with quote
How many of you have drilled a 1/8' hole at the back of the fuel vent tubes [just above the angle cutout] to stop siphoning ????? Is it really needed ??? Cheers T87
Ron Lendon
PostPosted: Wed Oct 21, 2009 5:17 pm    Post subject: Re: Drilling 1/8" hole on the fuel vent tube Reply with quote
Is that hole called out in the prints? I must have missed that.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Thruster87
PostPosted: Wed Oct 21, 2009 5:35 pm    Post subject: Re: Drilling 1/8" hole on the fuel vent tube Reply with quote
It was in the final check list [about 20 odd pages] for a new 601xl. Can't remember where I down loaded it.Cheers Alan
Thruster87
PostPosted: Wed Oct 21, 2009 9:30 pm    Post subject: Re: Drilling 1/8" hole on the fuel vent tube Reply with quote
It was in this document
CH 601 XL SLSA PRE-FLIGHT INSPECTION 2008.pdf
 Filename:  CH 601 XL SLSA PRE-FLIGHT INSPECTION 2008.pdf
 Filesize:  150.68 KB
 Downloaded:  1028 Time(s)
Ron Lendon
PostPosted: Fri Oct 23, 2009 3:45 am    Post subject: Re: Drilling 1/8" hole on the fuel vent tube Reply with quote
I don't see what you are referencing in the SAMPLE book you posted. To the best of my knowledge the vent gets cut on a 45 degree angle which faces forward. This is done to create a positive pressure inside the tank during flight.
Could you point it out for me? Or give me a search term to find what you are referring to?
Ron Lendon
CH 601 XLB
N601LT - Flying
Thruster87
PostPosted: Fri Oct 23, 2009 11:58 am    Post subject: Re: Drilling 1/8" hole on the fuel vent tube Reply with quote
Posted the wrong pdf file Try this one,I've been flat out getting the final inspection done and starting the high speed taxi runs Cheers Alan
Zodiac_CH601_650_inspection_%20checklist.pdf
 Filename:  Zodiac_CH601_650_inspection_%20checklist.pdf
 Filesize:  1.64 MB
 Downloaded:  4591 Time(s)
