Torquing prop bolts
Goto page 1, 2  Next
carlisle
PostPosted: Wed Oct 21, 2009 5:44 am    Post subject: Torquing prop bolts Reply with quote
Was surfing around and found this little note on another forum. It applies to a Zenair but struck a note with me. Every time I go to retorque my GSC 66" adjustable pitch prop, the bolts are loose. The prop was just inspected and overhauled by GSC. My torque wrench is calibrated, etc, etc.
Anyway, here's the topic:
Our CH601HD Zodiac with a Rotax 912S 100 HP engine has a 68-inch, 3-blade
GSC wooden prop. In our installation, there is a prop flange extension.
The prop is held on by 6 1/4-inch bolts (3 through the aluminum blade
roots), and by 6 5/16-inch bolts onto the flange extension. GSC Systems
says use 100 inch pounds of torque for the 1/4 inch bolts, and 140 for the
5/16; these values are critical. Normally, with a washer under both the
head and the nut, one holds the bolt head stationary, and torques the
nylon lock nut; these nyloks are the preferred nuts recommended by GSC.
Because of the design of the prop flange extension, it is not possible to
get the torque wrench onto the nuts. Thus, one holds the nut stationary,
and torques the bolt head. THIS IS NOT THE SAME THING. My son Peter
(co-builder of our aircraft, and a professional mechanical engineer) knows
from practical experience that putting the torque wrench on the bolt head
can undertorque the nut by possibly 20-30%, or even more. It stands to
reason: the bolt shaft (or grip) inevitably experiences some friction in
passing through the parts being bolted together on the way to the nut.
There is a little part called a "crow's foot" to overcome this difficulty,
which goes over the nut, extends radially outward for about an inch, and
has a square hole for attachment of the torque wrench. It happened that I
had always torqued the prop bolts on our aircraft. In setting out to
retorque the bolts yesterday because the weather is now turning cold,
Peter realized right away that there was a problem. I had never used a
crow's foot (I did not know of their existence!). I'm guessing that many
others using this Rotax/GSC prop installation were also unaware of this
problem. What have others done about this? Were they aware of the
problem?
Anyone else run into this problem?
Chris
Model 2, 582
Sioux Falls, SD
bw12345(at)sbcglobal.net
PostPosted: Wed Oct 21, 2009 6:13 am    Post subject: Torquing prop bolts Reply with quote
Using a crows foot or any extension of the torque wrench will change the torque that you read on the wrench. How much?
BOB
--- On Wed, 10/21/09, carlisle <carlisle_99(at)yahoo.com> wrote:
Subject: Torquing prop bolts
Date: Wednesday, October 21, 2009, 9:44 AM
Av8r3400
PostPosted: Wed Oct 21, 2009 6:43 am    Post subject: Re: Torquing prop bolts Reply with quote
Check my reply here for a couple of good links on the torque error with a crow-foot socket.
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos
carlisle
PostPosted: Wed Oct 21, 2009 8:14 am    Post subject: Re: Torquing prop bolts Reply with quote
I guess my issue with the crow's foot is that it's imprecise. The reason you should torque on the nut instead of the bolt head is that there are no other resistances. If you're on the bolt head, one has no way of knowing how much resistance there is to torquing along the length of the shaft. Therefore, it's anyone's guess as to just how much you should compensate. I think that the 20-30% advocated in the original thread is an estimation and probably ok for non critical/structural applications. Holding the propeller on the airplane is not one of these however.
My A&P mechanic buddies say that a crow's foot is not designed for this. They also say that a little loosening of the prop flange bolts is normal and 'figured in' when determining the correct torque settings, especially with a wooden prop where expansion/contraction has to be taken into account.
Chris
Tommy Walker
PostPosted: Wed Oct 21, 2009 12:09 pm    Post subject: Re: Torquing prop bolts Reply with quote
Hi,
Just wondering. Is there a FAR that requires that bolts go from front to rear? Could the bolt head be placed in the rear and the nut in front. I had a Warp Drive prop on a 912, and I believe the instructions for assembly of the prop and hub specified this.
Tommy Walker in Alabama
Do Not Archive.
Chris
Model 2, 582
Sioux Falls, SD
Tommy Walker
N25A - Anniston, AL
helili(at)chahtatushka.ne
PostPosted: Wed Oct 21, 2009 2:41 pm    Post subject: Torquing prop bolts Reply with quote
Nope. It's not a FAA/PMA prop. No FAR specifies which way bolts are
installed. There are Advisory Circulars that recommend certain ways to
install bolts, but manufacturer's recommended procedures take precedence
over AC recommendations, even in the case of FAA/PMA approved products.
John Hart
KF IV, NSI Subaru
Wilburton, OK
Tom Jones
PostPosted: Wed Oct 21, 2009 3:53 pm    Post subject: Re: Torquing prop bolts Reply with quote
Chris, which bolt circle do your prop bolts use on your 582 prop flange and are they threaded? Some people have been known to use 5/16 bolts in the holes that are actually 8mm. 5/16 is a hair smaller than the 8mm. If the bolts are correct and you use either saftey wire through the heads or nylock lock nuts on the bolts I would say, if they are loose, the prop has shrunk.
Tom Jones
Classic IV
Ellensburg, WA
Roger Lee
PostPosted: Wed Oct 21, 2009 4:42 pm    Post subject: Re: Torquing prop bolts Reply with quote
Here you go. See attached for Crowsfoot torque calculation. It's not a huge change, just a slight one. Play with the calculation it isn't hard. Just kind of fill in the blanks and a simple math problem.
Torque with a crowfoot calculation.pdf
Crowsfoot Calculations
 Filename:  Torque with a crowfoot calculation.pdf
 Filesize:  26.27 KB
 Downloaded:  758 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Av8r3400
PostPosted: Thu Oct 22, 2009 3:08 am    Post subject: Re: Torquing prop bolts Reply with quote
Check this out.
This was part of my response to the original poster on the Team Kitfox Forum.
Av8r3400
YouTube Videos
Float Flyr
PostPosted: Thu Oct 22, 2009 12:36 pm    Post subject: Torquing prop bolts Reply with quote
Changes in torque can be significant especially when torquing composite and
wooden props. The easiest way to eliminate and deviation in torque form
what is delivered by a properly calibrated torque wrench is to always apply
the final torque with the crows foot at 90 degrees to the torque wrench.
This is easy to verify by simply torquing a nut and bolt put through an old
piece of scrap steel. Then checking the torque without the crow foot. For
those of you worried about a crow foot slipping you can also use a cable or
hose wrench. It looks like a cross between a crow foot and a ring wrench.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
carlisle
PostPosted: Thu Oct 22, 2009 3:58 pm    Post subject: Re: Torquing prop bolts Reply with quote
Tom...I'm not sure what you mean by 'prop circle'. The bolts that attach the prop hub to the flange ARE threaded, there are 6 of them, and there are 6 studs that are also threaded into the prop flange and fit into holes in the back of the hub to relieve torsional loads on the prop. In addition, there are 2 'pinching' bolts for each of the 3 blades that squeeze the hub onto the molded neoprene blade roots. They do not pass through to the flange on the transmission.
Chris
Tom Jones
PostPosted: Thu Oct 22, 2009 5:04 pm    Post subject: Re: Torquing prop bolts Reply with quote
Chris
My original post was to alert you incase you had a prop that uses 8mm bolts into the threaded 8mm holes so you could be sure someone had not put 5/16 bolts in.
If it is a Type-B drive:
The prop flange has 1/4 inch and 8mm holes arranged on a 75mm circle. On older Rotax prop flanges the 1/4 inch are threaded to 1/4-28. On newer flanges the 1/4 inch holes have no threads and you use lock nuts on the prop bolts. On both old and new types the 8mm holes are threaded and those are the holes the 8mm studs are threaded into.
If it is a Type-C drive:
There are two different diameter bolt circles. A 75mm bolt circle (same as the Tyle-b drives) and a larger 100mm bolt circle. the 100mm bolt circle is always 8mm and untapped. If a prop is designed for the larger circle it is attached with 8mm bolts.
If your GSC is the same as the one I used all the bolts are 1/4 inch and the 6 8mm studs in the threaded 8mm holes. Some use a drilled head bolt and safety wire and some installations use lock nuts on the bolt.
Wow, I hope I didn't confuse yoy with all this but I think from what you say in your last post your installation is correct.
Tom Jones
Classic IV
Ellensburg, WA
carlisle
PostPosted: Thu Oct 22, 2009 6:32 pm    Post subject: Re: Torquing prop bolts Reply with quote
Tom...Wow, very complicated indeed. But thanks for the explanation. I had no idea there were so many variants.
Mine's a B gearbox. The 6 through bolts that attach the prop are special high grade bolts supplied by Skystar, way back when I built the plane. They have about 150 hrs on them and my A&P mechanic friends say they're in good shape so I don't need to replace them. I'm not exactly sure their diameter or thread pitch and can't remember the markings on the head.
Interestingly, when I had the prop overhauled by GSC, I asked for new bolts anyway and they said that they recommend standard AN hardware for mounting now.
Anyway, I have another question. Does anyone use threadlock? Not the strongest kind (red I think), but just something to make the bolt a little more secure. Is thread lock a no-no in aviation applications?
Chris
Float Flyr
PostPosted: Fri Oct 23, 2009 12:27 pm    Post subject: Torquing prop bolts Reply with quote
This is true... Recommendations are; the prop be bolted on to specified
torque and lockwired, however, Ivo requires you NOT lockwire the bolts.
When I asked why I was told it was because people didn't like to cut the
lockwire to check torque on the scheduled basis. Even though I prefer to
see lockwire on a prop I did not drill and wire mine.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Oct 23, 2009 2:39 pm    Post subject: Torquing prop bolts Reply with quote
The problem with threadlock , there are aviation specific threadlocks
available, is it makes it impossible to check the torque on the bolts. You
will literally have to remove the bolts clean them and the holes they went
into and re-torque them just to check torque. Nyloc nuts are a lot better
answer... and lockwire is better again if you don't mind cutting a bit of
wire at prescribed intervals to check your torques. If you have an all
metal fixed pitch prop then you can torque, lockwire and basically forget
about it for a long time.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
msm_9949(at)yahoo.com
PostPosted: Fri Oct 23, 2009 3:21 pm    Post subject: Torquing prop bolts Reply with quote
I could be wrong Chris, and someone will surely jump me if I am, but since those bolts must be retorqued at least annually during your condition inspection, and since they will be safety wired, thread lock isn't necessary or desireable. At least I don't do that with mine.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Thu, 10/22/09, carlisle <carlisle_99(at)yahoo.com> wrote:
Subject: Re: Torquing prop bolts
Date: Thursday, October 22, 2009, 10:32 PM
--> Kitfox-List message posted by: "carlisle" <carlisle_99(at)yahoo.com (carlisle_99(at)yahoo.com)>
Chris
http://forums.matronics.com/viewtopic.php?p=269tronics.com/Navigator?Kitfox-List" --> http:========================
pwmac(at)sisna.com
PostPosted: Fri Oct 23, 2009 3:25 pm    Post subject: Torquing prop bolts Reply with quote
Nylocks introduce a torque variable. One must do lots of tests to be
able to get the proper torque has to include the torque resistance of
the nylock. I know many use the nylock nuts but to be correct and
precise use a regular nut and lock wire. Always unscrew the nut then
re torque to get a correct reading.
Standard practice.
Paul
Noel
Guy Buchanan
PostPosted: Fri Oct 23, 2009 3:26 pm    Post subject: Torquing prop bolts Reply with quote
I use six 8mm bolts threaded into the flange, torqued, then backed by
six nylocks. I also safety wire. Ain't no way that prop's comiin' off.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Float Flyr
PostPosted: Fri Oct 23, 2009 3:56 pm    Post subject: Torquing prop bolts Reply with quote
What kind of blades do you have Guy? Most departures I've heard of have
most of the root left in the hub when the blade departs. I don't think I've
ever heard of a hub departing.
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Oct 23, 2009 3:58 pm    Post subject: Torquing prop bolts Reply with quote
For the nyloc you use friction torque... That requires the use of a torque
meter or beam type wrench to measure the friction of the nyloc. That
friction is then added to the torque requirement... I prefer your method
with the lockwire but do as the manufacturer instructs me to do.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Goto page 1, 2  Next
Page 1 of 2
