Thom Riddle
Posted: Sun Oct 11, 2009 5:44 am Post subject: Incidence Angles |
While I had my Warp Drive Protractor out measuring the new pitch of my TN prop yesterday, I decided to see what the incidence angles were on my Slingshot out of curiosity. I borrowed Jack Hart's drawing of his FireFly with incidence angles shown and edited the numbers to correspond to what I measured on my Slingshot. Image attached.
The Slingshot has a rather tall main gear so the root tube is angled up a lot more than the short leg Kolbs when on the ground.
In my mind, the numbers worth noting are the Horizontal Stabilizer angle is the same as the Root Tube. If at cruise speed the HS is even with the relative wind, then the wing bottoms are at about 7 degrees AOA and the engine centerline is pointing UP about 3 1/2 degrees from relative wind.
If my assumption is wrong about the HS being level at my normal cruise airspeed then this would be wrong. Since it is supposed to provide a small down force at the tail, it is probably pointing down a little bit during cruise flight. In any case, the difference in incidence between the wing and HS is 7 degrees which seems like a lot to me.
I'd like to hear from others about these angles on their Kolbs. Especially from the few other Slingshot flyers on the list, but others as well.
60.51 KB |
14835 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Oct 11, 2009 6:44 am Post subject: Incidence Angles |
> In my mind C the numbers worth noting are the Horizontal Stabilizer angle is the same as the Root Tube. If at cruise speed the HS is even with the relative wind C then the wing bottoms are at about 7 degrees AOA and the engine centerline is pointing UP about 3 1/2 degrees from relative wind.
If my assumption is wrong about the HS being level at my normal cruise airspeed then this would be wrong. Since it is supposed to provide a small down force at the tail C it is probably pointing down a little bit during cruise flight. In any case C the difference in incidence between the wing and HS is 7 degrees which seems like a lot to me.
I'd like to hear from others about these angles on their Kolbs. Especially from the few other Slingshot flyers on the list C but others as well.
Thom Riddle
Buffalo C NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x31
Thom C
I have done quite a bit of research on the Kolb MkIII wing's incidence angles C (and have a data table of results) C since I am having to change the incidence from the Classic angle to the Xtra angle (since my MkIII has undergone a rather complete transformation from starting out as a Classic to now being an Xtra).
Yes C believe it or not C 7 degrees incidence C in level flightseems to be pretty close to what my research has shown. 7 degrees incidence sounds like a lot C and frankly C I think it is C but it must be what Homer had intended. Evidently C a high incidence wing angle gives the performance that the Kolb are known for.
I do know of at least one individual who is considering lowering the incidence on his MkIIIC.
Mike Welch
MkIII
Hotmail: Free C trusted and rich etarget='_new'>Get it now. [quote][b]
Thom Riddle
Posted: Sun Oct 11, 2009 7:18 am Post subject: Re: Incidence Angles |
Mike,
I was not surprised at the approx. 7 degrees AOA (wing vs relative wind) which varies with airspeed. The higher the airspeed the lower the AOA and vice versa.
What I was surprised at is the decalage, i.e., the difference in incidence angles between the wings and the horizontal stabilizer. Attached is Jack Hart's drawing of his FireFly which shows a decalage of only 2 degrees, 11 (wing) minus 9 (HS).
I was also surprised to see the major difference in thrust lines relative to wing incidence. Note that on Jack's FireFly, at least at the time of this drawing, shows his thrust centerline to pointing down relative to the wing bottom with a negative difference of about 5 1/2 degrees. My SS thrust line is pointing up relative to the wing bottom by a positive 3 1/2 degrees.
I know these airplanes are different in many ways but these incidence and thrust-line differences are pretty major, which is what prompted my query about other Kolber's incidence angles. I've not looked at the SS plans to see what they call for but suspect mine is pretty close to plans and it handles very well. But I'm curious if any other Kolbs have this sort of incidence and thrust-line relationship.
52.16 KB |
14823 Time(s) |
Buffalo, NY (9G0)
- Anonymous |
rickofudall
Posted: Sun Oct 11, 2009 7:25 am Post subject: Incidence Angles |
Guys, Let's get back to basics before people start changing angles of incidence. There's a reason for that 7 degrees. The Kolb flies at about 9 degrees angle of attack. You might remember that number from the factory recommendation for weight and balance measurement. Do the math for the amount of lift needed at whatever you consider your cruise speed. You know, dynamic pressure X wing area X lift coefficient. What you find is that the lift coefficient that works out is in the 8 to 9 degree AOA range.
So what you end up with is less trim drag when flying at cruise when the AOI is set at something near the AOA required for cruise. Lower the angle of incidence and now the fuselage flies at a higher angle of attack in cruise flight and produces more drag, Then there's the lift needed by the horizontal stabilizer to hold the wing at that higher AOA (compared to AOI), net result more trim drag.
Of course this is experimental aviation and you can do whatever experiment you like to validate Homer's calculations, but I think you'll find he was right on the money.
MHO with Beauford's maxim.
Rick Girard
On Sun, Oct 11, 2009 at 9:43 AM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
[quote] > In my mind, the numbers worth noting are the Horizontal Stabilizer angle is the same as the Root Tube. If at cruise speed the HS is even with the relative wind, then the wing bottoms are at about 7 degrees AOA and the engine centerline is pointing UP about 3 1/2 degrees from relative wind.
| Quote: | If my assumption is wrong about the HS being level at my normal cruise airspeed then this would be wrong. Since it is supposed to provide a small down force at the tail, it is probably pointing down a little bit during cruise flight. In any case, the difference in incidence between the wing and HS is 7 degrees which seems like a lot to me.
| Quote: | I'd like to hear from others about these angles on their Kolbs. Especially from the few other Slingshot flyers on the list, but others as well.
Thom Riddle
Buffalo, NY
| Quote: | Jabiru 2200A #1574
Thom,
I have done quite a bit of research on the Kolb MkIII wing's incidence angles, (and have a data table of results), since I am having to change the incidence from the Classic angle to the Xtra angle (since my MkIII has undergone a rather complete transformation from starting out as a Classic to now being an Xtra).
Yes, believe it or not, 7 degrees incidence , in level flightseems to be pretty close to what my research has shown. 7 degrees incidence sounds like a lot, and frankly, I think it is, but it must be what Homer had intended. Evidently, a high incidence wing angle gives the performance that the Kolb are known for.
Mike Welch
MkIII
Hotmail: Free, trusted and rich etarget='_new'>Get it now.
jbhart(at)onlyinternet.ne Guest
Posted: Sun Oct 11, 2009 7:34 am Post subject: Incidence Angles |
At 06:44 AM 10/11/09 -0700, you wrote:
Thom,
What is your slip indicator doing at cruise? Is the ball centered?
Jack B. Hart FF004
Winchester, IN
Thom Riddle
Posted: Sun Oct 11, 2009 7:45 am Post subject: Re: Incidence Angles |
Jack,
My slip indicator is a yaw string and it is centered with feet off the rudders at my normal cruise speed. The rudder trim tab is bent only very slightly to the left, giving a little right rudder to accomplish this.
The ailerons do not have trim tabs but the left aileron actuating rod is extended a lot further than the right one to give wings level flight with no apparent force on the stick. But the ailerons appear to be in alignment with the bottom of the wings with stick neutral.
I have electric elevator trim and it flies with the trim indicator near center at normal cruise. What I have not looked at is the angle of trim tab with respect to the elevator when in neutral indicator position. I'll check then next time I am at the airplane.
I'm not very concerned about the difference in incidence of the HS and wings but am very curious about the thrust line difference. When I go to the airport next time I'll fetch the plans and see what was called for.
Buffalo, NY (9G0)
- Anonymous |
rickofudall
Posted: Sun Oct 11, 2009 7:52 am Post subject: Incidence Angles |
To carry on the discussion, the engine is set at a different angle to offset that other airfoil characteristic, the pitching moment. The wing wants to tumble AOTK (a** over tea kettle), the engine driving forward through a lesser angle counters this and once again, reduces trim drag.
Rick Girard
On Sun, Oct 11, 2009 at 10:45 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Jack,
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
A complex system that works is invariably found to have evolved from a simple system that works.
- John Gaule
http://forums.matronics.com/viewtopic.php?p=267470#267470
le, List Admin.
Posted: Sun Oct 11, 2009 9:52 am Post subject: Incidence Angles |
Thom,
Been thinking about this a little more. I lowered my thrust line by
rotating the belt reduction unit on the Victor 1+. By doing so, I believe,
it moved the thrust line closer to the center of drag. This in turn reduced
stabilizer and wing loading for the same cruise speed.
See:
http://jackbhart.com/firefly/firefly101.html
We seem to have the same angle difference between the wing and the
horizontal stabilizer. But where I am trimmed for cruise at 50-55 mphi, and
max weight of 500 pounds, you are banging along at greater speed, weight and
thrust, with a higher thrust line and working the wing much harder than the
FireFly. I don't believe a FireFly comparison is valid. I believe your
best hope is to find another SlingShot owner.
I tried a string as a slip indicator, and then I tried a ball. I like the
ball. I still use the string, but only as a taxi out and in cross wind
indicator.
Jack B. Hart FF004
Winchester, IN
pj.ladd(at)btinternet.com Guest
Posted: Sun Oct 11, 2009 9:56 am Post subject: Incidence Angles |
Mine too on my Xtra but the rudder trim is a length of door draught
excluder.stuck to the trailing edge The sort with a flat section and a small
tube on one edge.
Pat
Thom Riddle
Posted: Sun Oct 11, 2009 10:20 am Post subject: Re: Incidence Angles |
Jack,
I agree that the only things our airplanes have similar other than being Kolbs, is that the wings are similar in size so the comparison is probably not a good one. But yours is the only one I have data on to compare too, not to mention your drawing also being available for me to copy .
On the ground my wing bottoms are at 12 degrees and horizontal stabilizer is at 5 degrees which is a difference of 7 degrees. That is a lot of decalage, compared to yours which is 2 degrees (11 minus 9). Yours is similar to most aircraft that I'm familiar with. As you know the more decalage there is the more longitudinal stability if all else is constant. The Slingshot is pretty short coupled, so that relatively short arm that the horizontal stabilizer is working with may require that much extra decalage. I'll know when I check the plans, if that is close to what was intended. I expect it is about right because the builder was something of a perfectionist, much to my benefit.
As you noted, your thrust line is much lower than mine and perhaps the major difference in thrust angle is also required for that high engine centerline, which I'll also measure on next trip to airport.
Thanks for your thoughts on this.
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Oct 11, 2009 1:54 pm Post subject: Incidence Angles |
Thom R/Gang:
Adjusting length of aileron push/pull tube(s) does a couple things:
a. Changes the position of the control stick when the ailerons load up and
equalize in flight.
b. Increases or decreases droop/reflex.
What it doesn't do is change roll trim.
Blanding, UT
_________________ John Hauck
Titus, Alabama |
JetPilot
Posted: Sun Oct 11, 2009 8:27 pm Post subject: Re: Incidence Angles |
| John Hauck wrote: |
Thom R/Gang:
equalize in flight.
Blanding, UT |
John is correct, changing the length of those tubes will have no effect on Roll trim. It will change where the stick physically centers when flying...
Mike
Kolb MK-III Xtra, 912-S |
russkinne(at)mac.com Guest
Posted: Mon Oct 12, 2009 5:52 am Post subject: Incidence Angles |
ThomInteresting discussion about AOL's of HS & wing. But I wonder if the boom tube of a Kolb in level flight is absolutely horizontal? Anyone have a good picture of a Kolb in flight with the horizon behind it?
Russ
On Oct 11, 2009, at 10:43 AM, Mike Welch wrote:
| Quote: | > In my mind, the numbers worth noting are the Horizontal Stabilizer angle is the same as the Root Tube. If at cruise speed the HS is even with the relative wind, then the wing bottoms are at about 7 degrees AOA and the engine centerline is pointing UP about 3 1/2 degrees from relative wind.
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
Thom,
Mike Welch
MkIII
Hotmail: Free, trusted and rich etarget='_new'>Get it now. | Quote: |
Posted: Mon Oct 12, 2009 6:24 am Post subject: Incidence Angles |
Russ, we've been through that point way in the past. -including inflight pix.Most Kolbs, especially the MkIII, fly tail high. A lesser incidence on the wing, like the SS and the Xtra,
will reduce the boom tilt
BB
On 12, Oct 2009, at 9:52 AM, russ kinne wrote:
[quote] ThomInteresting discussion about AOL's of HS & wing. But I wonder if the boom tube of a Kolb in level flight is absolutely horizontal? Anyone have a good picture of a Kolb in flight with the horizon behind it?
Russ
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
Thom,
Mike Welch
MkIII
Posted: Mon Oct 12, 2009 4:20 pm Post subject: Incidence Angles |
Date: Mon, 12 Oct 2009 09:52:26 -0400
it?
Russ,
I checked the FireFly out with a AOA meter. At cruise the tail boom tube
would be 4.5 degrees up.
I have some photos that help but none with the horizon. The first is a
ground effect fly by at:
http://jackbhart.com/firefly/firefly87.html
Then there are several low level flight photos that were taken from the
ground at:
http://jackbhart.com/firefly/firefly137.html
If you click on the photos they will enlarge. It is difficult to judge from
these photos if the tail boom 4.5 degrees up, but it would be difficult to
say that it is not up 4.5 degrees too.
Jack B. Hart FF004
Winchester, IN
Thom Riddle
Posted: Mon Oct 12, 2009 4:38 pm Post subject: Re: Incidence Angles |
Jack,
If your tail boom is inclined 4.5 degrees up at the tail end during cruise that means your nose rotates down about 6 degrees from 3-point and gives a cruise wing AOA of 5 degrees, which is pretty close to cruise AOA of lots of airplanes, and the HS AOA of about 3 degrees positive. Useful and interesting information.
Buffalo, NY (9G0)
- Anonymous |
