chuck960
Posted: Fri Sep 18, 2009 6:36 pm Post subject: Cabin fuel lines |
I'm wondering what might be the best way to run fuel lines through the cabin. The plans don't specify material but Zenith supplies rubber hose with the kit. Would a solid material be better? Rubber should be ok as long as it is changed for new every so often. Aluminum or steel can crack from vibration. Rubber cad dry-rot and is easily cut.
I want an easy way to disconnect the fuel line at the side skin in order to remove the wing. What about fittings? there are many types to choose from. How do I get through the firewall? Does anyone know where I can get a good explanation of all this?
Chuck Dean
Ch650 in progress.
bryanmmartin
Posted: Fri Sep 18, 2009 8:10 pm Post subject: Cabin fuel lines |
I used 3/8" OD 3003 aluminum tubing from the tanks to the fuel valves.
It's easy to remove the wings by just unscrewing the flare fittings
and sliding the tubing out through the grommets. There's no
significant vibration in this area, so it should last a long time. I
used the supplied rubber lines for the rest of the system because it
is relatively easy to access for replacement. At some point, I may
replace much of this with aluminum tubing also. The only place where
vibration is a concern is between the firewall and the engine.
Flexible hose is required here.
On Sep 18, 2009, at 10:36 PM, chuck960 wrote:
is easily cut.
Chuck Dean
Ch650 in progress.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
mhubel
Posted: Sat Sep 19, 2009 6:11 am Post subject: Cabin fuel lines |
I am a firm believer in using only the same grade of parts for fuel
lines as a normal "certified/production" aircraft would use. I have used
all metal tubing and factory made flexible hose with AN fittings for the
fuel lines. The pictures are posted on:
http://groups.yahoo.com/group/jabiruengines/photos/album/0/list
non members may have to create a sign in listing to view them.
There are also some pictures on photo.hubbles.com
On 9/18/2009 10:36 PM, chuck960 wrote:
Chuck Dean
Ch650 in progress.
http://forums.matronics.com/viewtopic.php?p 63769#263769
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
mhubel
Posted: Sat Sep 19, 2009 6:29 am Post subject: Cabin fuel lines |
The album is "N708HU"
Mark Hubelbank
2 Clock Tower Place
Suite 555
mhubel(at)nemon.com
978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
naumuk(at)windstream.net Guest
Posted: Sat Sep 19, 2009 7:11 am Post subject: Cabin fuel lines |
Chuck-
I used 3003 in the cockpit through my C-section, flexible from the
header to the firewall-through, and flexible to my carb. The odd fittings
you need to go from the C-section to the wings aren't available from ACS or
Wicks, the place I found them was Murdoch Industrial. I realize there are
differences between the 650 and the HDS, but my main point is, the odd
fittings you'll need are available from Murdoch.
Bill
chuck960
Posted: Fri Oct 09, 2009 7:22 am Post subject: Re: Cabin fuel lines |
Thanks to everyone for the advice.
I,m not sure what factory grade fuel lines means. Is it 3003 aluminum or something else?
There are too many different fittings and materials.
The car guys have similar problems. They use aluminum some times but generally don't recommend it.
Should I use a single flair or a double?
I flaired some aluminum for practice and it seems like it might be fine but I'm not sure.
How about 3/8 aluminum jic 37 degree fittings with single flair stainless steel lines. Hard to get the seat to seal but they make soft aluminum sealing washer for this.
Chuck
Fly with Gus
Posted: Fri Oct 09, 2009 7:35 am Post subject: Re: Cabin fuel lines |
Get an AC43.13. It has all the info on materials and fittings for fuel systems and is considered FAA approved data.
