karolamy(at)adelphia.net Guest
Posted: Wed Apr 19, 2006 9:40 am Post subject: Rudder Position/Strobe Mounting Plate |
Has anyone come across a mounting plate or bracket that will fit inside the rudder fairing and secure the A500 Position/Strobe? I had this same problem on my 6A ten years ago and DID find one! It has worked great, was easy to install and comes with the two nuts welded to it to secure the A500 assembly. Cannot find receipt where I got it - was only 10 or 15 dollars. Any help would be appreciated. Rich Hansen
jhasbrouck(at)woh.rr.com Guest
Posted: Wed Apr 19, 2006 1:09 pm Post subject: Rudder Position/Strobe Mounting Plate |
Rich,
I made a mounting plate from .040 scrap and used nutserts ( #4 ) in the plate corresponding to the mounting holes in the light. Epoxied the plate onto the rudder fairing. Looks like it will work great! Mounting plate fits just inside the outer shell of the light.
John Hasbrouck #40264
fuselage
effectus(at)rogers.com Guest
Posted: Wed Apr 19, 2006 2:38 pm Post subject: Rudder Position/Strobe Mounting Plate |
Talk to David Czachorowski <dczachorowski(at)verizon.net (dczachorowski(at)verizon.net)>
I hear that he is looking into supplying this type of bracket.
Dave Hertner
jfrjr(at)adelphia.net Guest
Posted: Wed Apr 19, 2006 4:21 pm Post subject: Rudder Position/Strobe Mounting Plate |
Rich and Karol: All I did was mount the strobe/nav. lights using the screws supplied but then epoxyed two small lock nuts inside the fairing after screwing them down semi-tight. Pulled the screws after partial setup of the fiberglass/epoxy---after drying can now remove/replace the fixture at will. Jay
