coop85(at)bellsouth.net Guest
Posted: Tue Jan 10, 2006 4:28 pm Post subject: Garmin 480 vs 430 |
I’m waffling on which radio to get and am looking for opinions. I know the 480 is better due to its WAAS capability and precision GPS approaches, but are there any other advantages of the 480 over the 430? That $2400 difference is no small chunk of cash and I’m not sure how bad I need the precision approach capability with 2 ILS systems on board (GNS ??? and the SL-30), although it would be nice to have for runways without an ILS. I also spoke to the Grand Rapids folks (I’m using the Dual Display GRT EFIS) and apparently there is a warning that shows up in the 480 indicating “no OBS detected” (or something similar) since you don’t use normal display. I’m not sure if it’s just a nuisance warning only at startup or if it is displayed continuously/frequently which would be a real distraction.
Thanks for any experiences and recommendations,
Marcus
40286
jskirkland(at)webpipe.net Guest
Posted: Tue Jan 10, 2006 6:07 pm Post subject: Garmin 480 vs 430 |
Garmin says the software development effort on the 430 and 530 to
incorporate WAAS isn't going as smoothly as they hoped, so its going to be
late and expensive, $2K to upgrade a 430. So I'm thinking a 480 for my
Comm/Nav #1, and a King 125 for a backup Comm/Nav #2. If the 480 goes junk,
the King will get me on a localizer or VOR approach at least.
John Kirkland #40333
Marcus Cooper writes:
| Quote: | I'm waffling on which radio to get and am looking for opinions. I know the
difference is no small chunk of cash and I'm not sure how bad I need the
also spoke to the Grand Rapids folks (I'm using the Dual Display GRT EFIS)
and apparently there is a warning that shows up in the 480 indicating "no
OBS detected" (or something similar) since you don't use normal display.
I'm not sure if it's just a nuisance warning only at startup or if it is
cjensen(at)dts9000.com Guest
Posted: Wed Jan 11, 2006 5:53 am Post subject: Garmin 480 vs 430 |
Ray.R.Doerr(at)sprint.com Guest
Posted: Wed Jan 11, 2006 6:04 am Post subject: Garmin 480 vs 430 |
