Carbon Fiber Plenum
DCS317(at)aol.com
PostPosted: Mon Apr 10, 2006 9:23 am    Post subject: Carbon Fiber Plenum Reply with quote
I'm in the process of designing and getting the materials for a carbon fiber
plenum. I want the look of the carbon fiber rather than the fiberglass.
Questions:
1. Resin: High temp? Suggestions? Source?
2. Carbon fiber: Weave? Thickness? Source?
3. Laying it up: Vacuum bag? Release agents? How many layers of carbon
fiber? How to get a good looking outer surface (the inner surface of the plenum
will be the smoothest since I'm planning to lay it up over a smooth form
[plug]).
4. Drilling holes (after the resin has set up) for nutplates? No problem
with this re the fiber?
5. Any ideas for covering the nutplates with filler material and a second
lay up of fiber and resin to smooth out the interior of the plenum to keep air
turbulence down?
6. Websites or previous post suggestions would be also helpful--thanks!
Do not archive!
Don Schmiesing 120 hours of flying RV-8 417DS
speed3guy(at)comcast.net
PostPosted: Mon Apr 10, 2006 7:59 pm    Post subject: Carbon Fiber Plenum Reply with quote
Talk to Jeff Bordelon. Here's a link to some great photos of his.
http://www.jeffsrv-7a.com/ENGINE/06-03-23.htm
Guy
fiber plenum. I want the look of the carbon fiber rather than the
fiberglass.
Questions:
plenum will be the smoothest since I'm planning to lay it up over a smooth
form [plug]).
air turbulence down?
Do not archive!
