Posted: Mon Oct 05, 2009 4:24 am Post subject: Another comment about the UplockRe: Gear uplock piston |
The uplock is a mechanical latching mechanism that is released by air pressure moving the pin in the uplock outward which releases the mechanically latched "parrot hook". If the uplock was not there and you put the gear selector in neutral, the gear would go limp and drop down out of the wheel wells. If you lose air pressure in your main system, the uplocks hold the gear up and locked until you use the emergency system to blow the gear down, which releases the "parrot hook" the same way; the uplock pin is moved outward to mechanically release the parrot hook.
Dennis
