Manifold Pressure
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Sun Apr 09, 2006 11:28 pm    Post subject: Manifold Pressure Reply with quote
Wonder what to expect (roughly) for a take off Manifold Pressure on a standard day at a 5000’ MSL airport with the standard M14P?
Scott
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
dsavarese(at)elmore.rr.co
PostPosted: Mon Apr 10, 2006 7:38 am    Post subject: Manifold Pressure Reply with quote
Scott,
On a standard day at sea level, barometric pressure in inches is 29.92" which equals 760 mm.  At 100% the supercharger boosts the pressure (at sea level) to approximately 885 mm or 34.85", a factor of 1.165.   At 5000' on a standard day the barometric pressure should be about 24.9 inches, or 632 mm.  Given the supercharger boost factor, at 5000' with 100% rpm the manifold pressure should come up to about 736 mm.   I'm sure if my numbers are wrong someone will definitely correct me. -)
Dennis
tedwaltman(at)i1ci.com
PostPosted: Mon Apr 10, 2006 7:50 am    Post subject: Manifold Pressure Reply with quote
Dennis,
This whole debate started with a couple of us comparing MP on our M-14 engines.  Yesterday, at roughly std temp--or maybe a few degrees warmer--I saw 26.1" at takeoff at 4,965'.  A standard engine on a Swift was showing about 22" at takeoff (at 1,921 prop rpm or 2,919 engine rpm).  We were both at roughly 25" before engine start.
So, I'm not seeing the 736mm, or 28.97", you indicate below.  Perhaps my gauge is a bit off?
Ted
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Monday, April 10, 2006 9:38 AM
To: m14pengines-list(at)matronics.com
Subject: Re: Manifold Pressure
Scott,
Dennis
ScottA
PostPosted: Mon Apr 10, 2006 7:53 am    Post subject: Manifold Pressure Reply with quote
That is about what I was thinking we should see roughly 29 inches.  With no real charts (that I know of or can understand) I am wondering when the supercharger starts to loss it effectiveness in giving the approx. 5 inch.
Scott
Subject: Re: M14PEngines-List: Manifold Pressure
Scott,
Dennis
PostPosted: Mon Apr 10, 2006 7:58 am    Post subject: Manifold Pressure Reply with quote
Most likely the gauge is off, just like I know mine is.  We're at 200' MSL here at our airport.  So our MP gauges should read pretty close to 760 mm on a standard day.  I can tell you this.  Mine surely does not.  It reads low by about 30-40 mm compared to the other 4 Yaks in our hangar.   The numbers should be just about right I think.  I used this site, http://www.digitaldutch.com/atmoscalc/, to get the standard atmospheric pressure at 5000'.  The rest of the data came from the engine manual and basic calculations.
Dennis
PostPosted: Mon Apr 10, 2006 8:02 am    Post subject: Manifold Pressure Reply with quote
The super charger drop is basically linear, assuming 100% power.  It never really loses its "effectiveness".  It will always boost above atmospheric pressure, as long as it's turning.  -)  It just starts off higher (+5" approximately).
Dennis
ScottA
PostPosted: Mon Apr 10, 2006 8:27 am    Post subject: Manifold Pressure Reply with quote
That brings up the question (at least for me) if you had a small leak in the MP line on a supercharged engine would that cause low indication due to pressure loss?  Whereas on none turbo or supercharged a leak may cause higher indication due to less vacuum (because it is really vacuum and not “pressure” on a standard engine, i.e. MP usually drops slightly when takeoff power is applied).  Too much thinking…
Scott
Sent: Monday, April 10, 2006 9:58 AM
Dennis
PostPosted: Mon Apr 10, 2006 9:31 am    Post subject: Manifold Pressure Reply with quote
Yes, too much thinking for sure! -)  Sounds about right to me.
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
