tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Sun Oct 04, 2009 1:23 pm Post subject: Gear uplock piston |
Hello to all,
just to attract your attention on a small problem I had two times on two different planes about the small uplock cylinder locking and unlocking the gears.
The gear is locked in the up position by a small hook . When we select the gear down position air flows thru the normal circuit to the small uplock cylinder that pushes and release the hook. Air goes in the same time into the main cylinder to push the gear down and extend it.
Those last time I had the problem on my Yak18T and on my friend 's Yak52 just this last week. This small cylinders stopped working locking the gear in the retracted position. On my plane, I discovered the problem fortunately when my plane was jacked and I was making retractation test (my red retracted light did not want to come on and this was the symptom of the normal operation piston blocked on the emergency piston. The actuator of the light was no more depressed) and without possible anticipation my left gear refuses to go down. The hook did not release the gear. The uplock cylinder was blocked.
The same happened to my friend last week on his 52. He landed with the emergency system and all was fine.
What happened was that those little uplock cylinder are made of two piston moving one on the other and the movement was completely corroded so it was no more moving on normal operation but only in emergency. Inside the cylinder I found a lot of corrosion and even old grease blocking the cylinder. I had to unmount completely the cylinders, use a hammer to separate the two parts of the piston paper sand the corroded parts clean completely the interior and apply some Teflon grease.
I was really surprised how much it was corroded and it seems to me important to attract your attention on this problem. These little cylinders are very easy to unmont. It takes about one hour to unmont it clean it and remount it.
Regarding how annoying it is to land with the gear retracted.....I think it is worth checking these uplock cylinders.
If anyone want I can post pictures of the unmonting process.
And if anyone can explain me how difficult it is or how easy it is to make the same for the main gear cylinders I will be happy. I think that now I will try to check all the cylinders.
Hope that will help
Didier BLOUZARD
didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)
0624243672
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
Posted: Sun Oct 04, 2009 2:45 pm Post subject: Gear uplock piston |
Didier,
This is not an unusual problem with Yak's (50's, 52, Yak 18T's) with uplock actuators. In fact, it happens more frequently than one might think. The problem is poor maintenance of the pneumatic system in years past. As you have already found out, when you disassemble the uplock actuator you will very likely find rust and corrosion inside. Very likely one or more of the C-clips will be rusted or maybe even totally disintegrated. It is highly recommended that at every annual inspection at least one uplock actuator be removed, disassembled and inspected. Whatever you find in the small uplock actuator is representative of what you will find in all the other actuators (undercarriage and flap). So if you have an uplock actuator that is not functioning and you find corrosion and rust internally in the actuator, you can almost count on finding the same thing in your undercarriage and flap actuators. Additionally the air start valve is probably full of junk/gunk as well.
If the metal parts except the C-clips are in good shape, you can overhaul the uplock actuators. I would strongly recommend you do this before you end up with an in-flight problem with the undercarriage not coming down. And believe me, it WILL happen if you don't take care of it now. Do not use grease when reassembling. Use only a light weight oil. Grease may block the small holes in the shaft between the main and emergency sections. (The steel part that inserts into the brass part). You can pressure test the uplock actuator with shop pressure from a standard shop compressor. I would recommend you do this on both the main and emergency sides before reinstalling in the airplane.
Removing the undercarriage actuators is pretty straight forward. Of course you will need to jack the airplane. First remove the end of the actuator from the drag link that moves the undercarriage up and down. Then remove the bolt and nut at the top of the actuator. I would recommend you take the actuators to person who is familiar with disassembling and reassembling the actuator because it can be difficult getting the end caps off. Then when reassembling it is easy to damage the new seals.
Finally, seriously consider overhauling all of the undercarriage actuators and the flap actuator. Better to be safe than sorry.
Dennis
cjpilot710(at)aol.com Guest
Posted: Sun Oct 04, 2009 3:13 pm Post subject: Gear uplock piston |
Guys,
I know these up locks are standard on every Yak and CJ-6 EXCEPT mine. When I bought my airplane 15 years ago, they were not installed on the airplane. Somewhere I remember seeing a pneumatic system drawing without them. I've heard of one other aircraft that didn't have them either. I now have well over 1,800 hours on my airplane with out them. I personally think you can get along without them.
Difference? I merely fly around with my gear handle UP, instead going to OFF. If I put the gear handle to OFF (not down), the air merely bleeds out of the system though the gear handle, and my gear will drop out. The same will happen if I happened to lose all my main system air. One time at a near by airshow, I sheared the pins in the compressor. Of course the system pressure started slowly dropping. It got pretty (30 atoms) low before I noticed it. I turned off my main air valve. At about 20 to 25 atoms the gear starts to fall. On the down wind (with zero pressure on the gage) I put the gear handle from the full UP to the DOWN position. I noted that all the "Idiot" sticks were showing the gear nearly down at this point. At this point I opened the main valve, and heard a satisfying normal "clunk" and 3 green lights. I still had 30 atoms in my system for brakes (min is 10 atoms BTW) and still had my emergency bottle in reserve.
Now I know the book says to put the gear handle OFF after the gear is retracted. AND that before extending the gear, one must go from OFF to UP before going to down. This keeps the gear from slamming down. My point is that it does not matter if you leave the gear UP. Nothing is going to happen to the system. There will always be pressure on the up side of the actuator and that is all. This doesn't do any harm to seals. Seals are worn out by movement of the piston in the actuators, not by the air pressure.
Other folks have said that it is easier on the compressor. I say it makes no difference. The compressor will be putting out the same cubic whatever's with each stroke . The regulator will dump the excess pressure when it exceeds the spring's compression set. It would do this with or without the gear being OFF or UP. BTW if you think by having a over board dump valve install (some Yak 18Ts) is easier on the compressor, I find that debatable. The compressor will still chugging right along with the engine however - - - - the engine will not be drained of the hp required for the compressor working to build up that pressure. Hence it would burn a little less fuel (does anyone know how much?).
At one point I considered putting up locks back on my CJ. Then I considered the operational differences and that they may in themselves be a failure point. KISS
Do I recommend taking them off your airplane? No. But for ME - I am fine without them.
So why do the engineers say "Put the gear handle OFF". I don't know. I do know that engineers and the FAA use to say "To remove smoke from the 707 cockpit, open up the sextant valve and if it gets worse, open cockpit windows." (Words to that effect in the emergency check list) Turns out, that was 100% wrong and 3 friends of mine died at BOS doing what they were told.
Not that having a gear handle UP or OFF will be as quite as earth shattering as that, but just the best extreme example I could think of.
BTW (different note) On the B-24 (PW 1830-65 with 14 cylinders) we only pull though 9 blades. On the B-17 (Wright 1820 with 9 cylinders) we pull 9 blades. On the B-25 its a two man (old men) job to pull the 14 cylinder Wright though 9 blades. I pull my M-14 though 5.
Jim "Pappy" Goolsby
In a message dated 10/4/2009 5:23:53 P.M. Eastern Daylight Time, didier.blouzard(at)gmail.com writes:
| Quote: | Hello to all,
Regarding how annoying it is to land with the gear retracted....I think it is worth checking these uplock cylinders.
Hope that will help
Didier BLOUZARD
0624243672
tigeryak18t
Posted: Mon Oct 05, 2009 1:46 am Post subject: Gear uplock piston |
Thanks to all for your kind comments,
merci beaucoup !!!!!
Dennis, I will follow your recommandations and probably have a thorough inspection of all actuators done by a DASSAULT specialist. He has all the specific tools and knowledge.
Just to moderate, on my plane the left uplock was rusted but the right one was in a good state.
For the liquid to put in the pneumatic system TERMIKAS seems to recommand to mix 50% ethanol and 50% glycerin (found in any good drugstore) and to inject this mixture into the pneumatic system as you say.
Regarding the relevance or not of these uplock ...... I question myself. My hungarian operator has been trained by russian engineers and when he was aware that I followed the manual regarding the gear handle in neutral position he told me that this was not the recommandation and I have to keep the gear handle on retracted or extended all the time.
The only problem is (or might be!!!) the compressor always in charge.
Thanks very much Dennis,
thanks to all
Didier
2009/10/5 A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
[quote] Didier,
Dennis
French Wing |
Posted: Mon Oct 05, 2009 4:05 am Post subject: Gear uplock piston |
Regarding the compressor always being "in charge" because you put the undercarriage selector in neutral - it has no effect on the compressor whatsoever because the compressor is always charging the system when the engine in running. Your Hungarian operator is 100% correct.
Another reason I do not subscribe to putting the undercarriage selector in neutral (with one exception which I will explain shortly) is because when you put the selector in neutral, the actuators are totally depressurized. That is the "woosh" sound you hear when the selector is moved to neutral. If you move the selector to the DOWN position for landing from NEUTRAL, the undercarriage will slam into the down position because there is no backpressure on the actuator from the UP side. This is not good for the undercarriage, or the actuators. The pressure on the UP side of the actuator acts as a "shock absorber" when the selector is put in the down position.
The ONLY way moving the selector to neutral is acceptable is if BEFORE you move the selector to DOWN you first move the selector to the position the undercarriage is already in. In this case, back to the UP position. By doing this, you re-pressurize the actuators and then you can move the selector to the down position. Unless you get into the habit to do this every time you cycle the undercarriage, leave the selector in the UP position.
Dennis
Posted: Mon Oct 05, 2009 1:16 pm Post subject: Gear uplock piston |
Just a note. The YAK-50 does not use UP LOCK actuators. Instead, the
uplock is controlled by a spring and movement of the main gear actuator
itself.
All the corrosion issues are the same as has been reported, but there
are just two main actuators to worry about.
Mark Bitterlich
Posted: Mon Oct 05, 2009 1:22 pm Post subject: Gear uplock piston |
There is one more occasion when it is actually smart to move the
actuator level to neutral and this is if you have a bad bad air leak.
It is entirely possible to have a leak in your landing gear system where
it only leaks when the landing gear is selected UP or selected DOWN.
If that happens, you can end up bleeding out your whole air bottle and
not have normal air available for landing.
I had this happen on a YAK-50 that I was ferrying out to California. In
that case, the leak only happened with the gear in the DOWN position.
Keep in mind that the landing gear on a YAK-50 does NOT work the same
way as the YAK-52, and in the 50, the down and lock system is fully
mechanical. If the gear is down and locked, it does not require air
pressure to KEEP it down and locked. The 52 uses actuator locking balls
I think (Dennis? Anyone?) but the 50 has a stand alone mechanism.
Anyway, it is possible to lower the gear... Put the handle back to
neutral, then allow the air to pump back up, and actually LAND with the
actuator in neutral. My leak was so bad, I had to do this, or I would
have had no brakes on landing. Of course, if you could, the better move
would be to select DOWN right before you landed.
Point being, putting the landing gear handle in neutral can ISOLATE a
bad leak and allow you to regain full air pressure.
Mark Bitterlich
