Fuel System Diagram
squishyoleo(at)yahoo.ca
PostPosted: Mon Sep 28, 2009 5:24 am    Post subject: Fuel System Diagram Reply with quote
Hi All,
Here's a preliminary fuel system overview diagram for those who are interested. It's for an IO-320 with the Precision Airmotive fuel injection system. It's very simple - a lot more simplistic than I thought the whole system would be. I still haven't decided if I'm going with the Van's boost pump kit or the one from Andair yet. Any suggestions? Smile
Mike
__________________________________________________________________
Looking for the perfect gift? Give the gift of Flickr!
http://www.flickr.com/gift/
FuelSystem.pdf
 Filename:  FuelSystem.pdf
 Filesize:  27.43 KB
 Downloaded:  333 Time(s)
JohnInReno
PostPosted: Mon Sep 28, 2009 7:11 am    Post subject: Fuel System Diagram Reply with quote
My plans are similar but I don't understand the benefit of the gas collator.
John Morgensen
RV4 - Flying
RV9A - wiring
Grumman AA1B-150 For Sale
Mike De Lange wrote:
Hi All,
Mike
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
rvpilot(at)embarqmail.com
PostPosted: Mon Sep 28, 2009 9:11 am    Post subject: Fuel System Diagram Reply with quote
Hi Mike,
I suggest that you eliminate the gascolator. It is totally
unnecessary and a real source of potential leaks.
It cannot be the lowest point in the system, the lowest points are
the tank drains, and the filter will take care
of any debris. Personally, I would put the flow transducer inside
the firewall down stream of
the boost pump. This gives you a better chance to get a straight run
up stream of it, helps to eliminate
bubbles. This set-up has worked well for me through 4 RV's
Bill
On Sep 28, 2009, at 9:23 AM, Mike De Lange wrote:
Hi All,
Mike
http://www.flickr.com/gift/<FuelSystem.pdf>
peterlaurence6(at)gmail.c
PostPosted: Mon Sep 28, 2009 9:42 am    Post subject: Fuel System Diagram Reply with quote
Mike,
I made my fuel manifold for my RV9A. Bought  an Auto racing pump, which in my opinion is as good as Van's. I picked up the check valve and the pressure valve at Sun N Fun a couple of years ago.I think the AN fittings ended up costing more that the rest of the components.
However, After seeing Andair's pump, I going going with it and eliminating all those fittings and parts.
Peter
On Mon, Sep 28, 2009 at 9:23 AM, Mike De Lange <squishyoleo(at)yahoo.ca (squishyoleo(at)yahoo.ca)> wrote:
[quote]Hi All,
Mike
http://www.flickr.com/gift/[b]
rgf(at)dcn.davis.ca.us
PostPosted: Mon Sep 28, 2009 5:14 pm    Post subject: Fuel System Diagram Reply with quote
Thanks for this, I hope to be at this stage in a year...or two. Or longer,
well, I hope to be there.
Ralph Finch
Davis, California
RV-9A QB-SA
ceengland(at)bellsouth.ne
PostPosted: Mon Sep 28, 2009 7:12 pm    Post subject: Fuel System Diagram Reply with quote
Hi All,
Mike
Uh... I know that the Andair pump is bound to be perfect (at around 600
American dollars), but the specs say 16gph (at) 25psi. Any good running
180-200hp Lyc will flow more than that at sea level full power.....
Charlie
Vanremog(at)aol.com
PostPosted: Mon Sep 28, 2009 7:53 pm    Post subject: Fuel System Diagram Reply with quote
I'm always baffled by this same misleading statement that has been trotted out on the RV List time and time again. Read my lips, "a gascolator doesn't have to be the lowest point in the system in order to do its job".
Where did this crazy idea come from? Look at a gascolator closely and pretend you understand the physics of a heavier and more viscous fluid (water) settling out by gravity with the help of a screen tight enough to let the lighter less viscous fluid (fuel) preferentially float/flow thru. All a gascolator needs to work is to be installed correctly (with the bowl facing down and the curtis valve accesible for draining).
You don't have to shake a rattle, do a chant or pray.
It's science.
-GV
In a message dated 9/28/2009 10:12:53 A.M. Pacific Daylight Time, rvpilot(at)embarqmail.com writes:
of any debris.
Kellym
PostPosted: Mon Sep 28, 2009 9:22 pm    Post subject: Fuel System Diagram Reply with quote
My 200 hp IO 360 Mooney flows about 16.8 to 17.5 on takeoff depending on
temperature and how close to sea level elevation. 16 gph capacity would
be more than enough for 160 hp IO320.
> Hi All,
> suggestions? Smile
> Mike
Charlie
Kelly McMullen
KCHD
Kellym
PostPosted: Mon Sep 28, 2009 9:28 pm    Post subject: Fuel System Diagram Reply with quote
And you are going to guarantee that an engine pump designed to generate
25 psi isn't going to have enough suction to lift the
gascolator(designed for low pressure carb systems) valve off its seat
and suck air??? Why do you need another water separator when the tanks
should do the job at the quick drains?
do its job".
It's science.
-GV
of any debris.
Kelly McMullen
KCHD
chaskuss(at)yahoo.com
PostPosted: Tue Sep 29, 2009 1:44 am    Post subject: Fuel System Diagram Reply with quote
Mike,
Most folks don't use a gascolator on a fuel injected engine. Unless you plan to use an Andair gascolator, most others are NOT designed for the sealing surfaces to withstand the 25 psi of a fuel injected system. That means you'll probably have fuel leaks with the electric pump turned on.
I would suggest that you do one of three things.
#1 Simply eliminate the gascolator
#2 Swap places between your gascolator and the 6ILA fuel filter.
#3 Install a gascolator [or 4ILA fuel filter] in each wing root and eliminate the fuel filter and gascolator in the positions shown in your diagram. The 4ILA is a slightly smaller version of the 6ILA fuel filter. It is easier to fit into the wing root area. The Flow Ezy 6ILA is sold by both Vans and Airflow Performance. RV-9A builder Chris Heitman's company, Pegasus Auto Racing carries the 4ILA filter. See
http://www.pegasusautoracing.com/productdetails.asp?RecID=3469
Charlie Kuss
> Hi All,
> Mike
PostPosted: Tue Sep 29, 2009 3:22 am    Post subject: Fuel System Diagram Reply with quote
Mike,
I would strongly suggest you read the post on the VAF WWW site by Don Rivera [owner of Airflow Performance] at the link below. See
http://www.vansairforce.com/community/showpost.php?p=354763&postcount=4
The entire thread can be found below
http://www.vansairforce.com/community/showthread.php?t=47463
Charlie Kuss
--- On Tue, 9/29/09, Charles Kuss <chaskuss(at)yahoo.com> wrote:
Subject: Re: Fuel System Diagram
To: rv-list(at)matronics.com
Date: Tuesday, September 29, 2009, 5:35 AM
Mike,
turned on.
filter.
Charlie Kuss
> > Hi All,
for
the
very
whole
going
> > Mike
aerobubba(at)earthlink.ne
PostPosted: Tue Sep 29, 2009 6:10 am    Post subject: Fuel System Diagram Reply with quote
Although one can argue they "should" do the job, I have drained quite a bit of trash and water out of gascolators over the years. Especially from planes with flush fuel caps. Throw in some acro to stir things up, and now there is water in the fuel injection system.
To each his own, but my money (and rear end) is on the simple physics of a gascolator.
Glen Matejcek
panamared505(at)brier.net
PostPosted: Tue Sep 29, 2009 8:27 am    Post subject: Fuel System Diagram Reply with quote
gascolator.
Simple physics of the gascolator may get one killed while in sustained
inverted flight!
Bob
RV6 "Wicked Witch of the West"
PostPosted: Tue Sep 29, 2009 8:38 am    Post subject: Fuel System Diagram Reply with quote
I've heard good points and bad about the usage of a gascolator from many people. But regardless of what I may think about it one way or the other, here in Canada it's law to install one so I really have no choice.
As for the placement of the fuel flow transducer, if your boost pump is off does that affect your fuel flow reading at all? I can see the benefit of putting it where you suggest since it also eliminates another run through the firewall.
Mike
PostPosted: Tue Sep 29, 2009 5:04 pm    Post subject: Fuel System Diagram Reply with quote
Mike,
If you gotta have that thing, then figure out some way to mount it
upstream of the boost pump. The boost pump being on or off
will not affect the fuel flow reading other than a momentary blip
when it goes on.
Bill
have no choice.
Mike
Vanremog(at)aol.com
PostPosted: Tue Sep 29, 2009 6:43 pm    Post subject: Fuel System Diagram Reply with quote
Bob-
Please explain how this would occur provided that the device were properly installed and purged of water before flight.
-GV
In a message dated 9/29/2009 9:28:37 A.M. Pacific Daylight Time, panamared505(at)brier.net writes:
--> RV-List message posted by: "Panama Red" <panamared505(at)brier.net>
gascolator.
inverted flight!
Bob
RV6 "Wicked Witch of the West" ======================== ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
PostPosted: Wed Sep 30, 2009 7:05 am    Post subject: Fuel System Diagram Reply with quote
Bob-
-GV
In a message dated 9/29/2009 9:28:37 A.M. Pacific Daylight Time, panamared505(at)brier.net (panamared505(at)brier.net) writes:
--> RV-List message posted by: "Panama Red" <panamared505(at)brier.net (panamared505(at)brier.net)>
gascolator.
inverted flight!
Bob
I agree if properly installed and the entire fuel system is purged of water prior to flight. So then what is the purpose of a gascolator? <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
In my fuel injected system and most others that I know of, there is a very fine fuel filter prior to the high pressure boost pump, to protect the boost pump. Therefore if one had a gascolator after the fuel filter, the gascolator would not filter out any large debris. On the other hand, if one did not have a fuel filter prior to the cascolator the possible debris caught by the gascolator may then end up back in the fuel flow once gravity is reversed in reference to the gascolator (inverted flight).
I assume, but may be wrong, if the gascolator did collect water while upright, then wouldn’t this water then enter the fuel system while inverted? I have always thought that the force that made the gascolator work was gravity, reverse gravity and it does not work? How many pilots are able to do an engine restart while inverted? The obvious answer is to roll upright and attempt to start the engine, but trust me, when the engine quits while inverted, it gets real exciting, especially if one is foolish enough to be at a critically low altitude.
In my 30 years of flying, I have only found water in the fuel once. That was after I left the RV out in the rain with the fuel caps removed from the tank (a long story). I keep looking for water in my tanks, especially since I hanger my RV with tanks 1/4 to 1/2 full. Disappointed am I, that l find no water in the tanks. I have found the entire outside of the aircraft wet from sweat/humidity on rainy days while in the hanger. I have often opined that the RV would be dryer if I parked it in the rain rather than in the hanger! But still no water in the fuel tanks!
Back to the original question, if there is no water in the fuel system and the fuel filter eliminates all the fuel debris in the system, what is the purpose of the gascolator?
Bob
rembree(at)sympatico.ca
PostPosted: Thu Oct 01, 2009 2:20 am    Post subject: Fuel System Diagram Reply with quote
Panama Red wrote:
Bob-
-GV
> gascolator.
inverted flight!
Bob
Bob
We had this discussion a long time ago.
Rain does not have to be the source of the water. Water that is dissolved in gasoline forms ice crystals when exposed to very cold temperatures. It is difficult to remove all of the ice crystals through the drains, and not possible if they form while flying. Small ice crystals will plug filters but not gascolators. Gary Legare experimented with putting water in a filter and freezing it. He said that he was still able to flow fuel through the frozen filter but that was not a true model of ice crystals being deposited on the surface of a filter.
Forgetting about acro or any other unusual circumstances, very cold temperatures equals the need for a gascolator.
Roger Embree
PostPosted: Thu Oct 01, 2009 7:23 am    Post subject: Fuel System Diagram Reply with quote
Bob-
upright, then wouldn't this water then enter the fuel system while
inverted?
Nope. The last gascolator I was in had a screen that would protect against
that, as well as the outflow port being configured as a bit of a standpipe
when inverted.
engine quits while inverted, it gets real exciting....
That was a standard training exercise.
Sounds like you've been in the enviable position of only flying airplanes
that've been hangared.
To the first part, water can be laying along the juncture of ribs and the
bottom skin. It won't always readily move to the sump, and you can tap
clear samples on preflight and still have water and other trash in the
tanks. Acro, or even the vibration of normal flight can cause it to
migrate to the pick ups. This was a documented issue with certain
certificated aircraft, especially one with flush fuel caps.
To the second part, the filter doesn't eliminate the debris, it collects it
at one non-drainable point. I can't imagine a scenario where there'd be
enough trash to plug a filter, but water is another story.
Most people will never experience power loss due to contaminants, but it
has happened. Most people won't experience a spar failure, but I still
prefer to wear a parachute while flying acro. To each his own, as long as
an objective risk analysis has been made.
glen matejcek
aerobubba(at)earthlink.net
