lwinger
Posted: Mon Sep 21, 2009 6:10 pm Post subject: Throttle and mixture control |
I'm using a single center throttle and mixture control arrangement on a 650 with a Corvair /MA3SPA carb.
Any recommendations on part numbers would be appreciated. I believe I want a vernier (not a friction lock) unless someone convinces me otherwise.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Gig Giacona
Posted: Tue Sep 22, 2009 5:08 am Post subject: Re: Throttle and mixture control |
Vernier is great for mixture. Not so much for throttle.
Here are the ACS Parts numbers I used...
Mixture 05-07848 A-750 CONTROL 48" RED KNOB
Throttle 05-08660 A-800 CONTROL 5 BLACK KNOB
Carb Heat 05-14300 PLAIN DURAL KNOB CONTROL 8
I could have gotten away with a shorter carb heat but it was very easy to adjust the length.
601XL Under Construction
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Tue Sep 22, 2009 1:17 pm Post subject: Re: Throttle and mixture control |
Hey Gig - would those cables you ordered have been long enough if you'd wanted to install just a single set of controls on the left side? You're going with the Corvair and MA3-SPA, right?
I plan to install a single set of these controls on the left side.
How feasible is it to adjust the length of the other two controls (throttle, mixture) if need be? Is it just a simple matter of cutting them to size, or do they have some kind of fancy end...?
Patrick
N63PZ
XL/650/Corvair
Gig Giacona
Posted: Wed Sep 23, 2009 8:05 am Post subject: Re: Throttle and mixture control |
Throttle probably. Mixture, if mounted on the left side of the panel would need to be shorter. How much I don't know.
The only adjustment in length (other than fine end adjustment) on those is how you order it from ACS or how you route it. The throttle has to make a 180 degree turn anywhere you put in on the panel.
| PatrickW wrote: | Hey Gig - would those cables you ordered have been long enough if you'd wanted to install just a single set of controls on the left side? You're going with the Corvair and MA3-SPA, right?
Patrick
N63PZ
XL/650/Corvair |
