undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
Posted: Mon Sep 21, 2009 12:52 pm Post subject: Fuel tank for FF |
Does anyone have info on sources for buying a fuel tank for a FireFly?
Mfrs, sales outlets, websites, etc. I'd appreciate anything you could
provide with various size and shape options.
Dave Kulp
Bethlehem, PA
FireFly 11DMK
dalewhelan
Joined: 11 Nov 2008 Posts: 105 Location: USA ARIZONA fountain hills
Posted: Mon Sep 21, 2009 1:59 pm Post subject: Re: Fuel tank for FF |
Not sure this is what you want to hear. I just got one from Travis at Kolb for my Firestar II. He has 5 or 6 gallon tanks. He says he has not had troubles with the 5 gallon tank. I think that may mean they last better than the 6 gallon tanks.
Price seemed pretty good to me
_________________ Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept |
beauford
Posted: Mon Sep 21, 2009 3:08 pm Post subject: Fuel tank for FF |
Fer what it is worth...
In my experience, the 6 gallon tanks have substantially thinner and more flexible
walls than the 5 gallon items. The 6 gallon tank I got from TNK became so
"flabby" after about a year and a half that I became uneasy flying with it. It is
still in the airplane, but I don't like it.
Weak and undisciplined beauford (willing to trade life for 18 more minutes - kinda
like matrimony)...
FF-076
Brandon, FL
Posted: Mon Sep 21, 2009 3:56 pm Post subject: Fuel tank for FF |
flabby? Sure those wuz the tanks yer talking about?
BB, a few parts gone flabby too.
My 5 gal tanks have to be 20 years old. Do I think about one popping
a seam? Once in a while.
On 21, Sep 2009, at 7:10 PM, Beauford T wrote:
<beauford173(at)verizon.net>
<dalewhelan(at)earthlink.net>
that may mean
more flexible
became so
with it. It is
minutes - kinda
like matrimony)...
FF-076
Brandon, FL
Possums
Posted: Mon Sep 21, 2009 4:18 pm Post subject: Fuel tank for FF |
At 04:21 PM 9/21/2009, you wrote:
| Quote: | --> Kolb-List message posted by: Dave Kulp <undoctor(at)ptd.net>
Mfrs, sales outlets, websites, etc. I'd appreciate anything you could provide with various size and shape options.
Dave Kulp
Bethlehem, PA
FireFly 11DMKI got mine from a place in Florida called
Rotational molding Inc.Phone 914-534-1766
Don't know if they have a web site or not.
Plastic powder is poured
into a mold and then heated as it turns. Comes out in
one solid piece.They make
"Gray Water" storage tanks for RVs.
You may like this site better http://www.ronco-plastics.net/marinetanks.html
It seems to have more choices. I like to be able to design my own stuff and I can see thru it (about 1/8+ thick?)
My plane is wider than Firefly - so you would have to measure the
space you have and figure out how to get it in. The holes are drilled and the fittings have to
be spun on at the factory with some kind of machine that melts them to the tank.
They are made of the same plastic that the tanks are made of.
If you tell them you are using it on anything that flys - they won't sell it to you.
We have used these tanks for 12 years, mine for 10+ and no problems
if the fittings are done right "raised" so you can also put a
clamp on the outside of the fitting after your screw in the connections (no leaks). |
Don't have any good pictures of the tank by itself.
171.44 KB |
4036 Time(s) |
91.79 KB |
4036 Time(s) |
_________________ Possum |
elleryweld(at)aol.com Guest
Posted: Mon Sep 21, 2009 5:19 pm Post subject: Fuel tank for FF |
are you looking for the 5 gallon tank that you get with a kit? I happen to have a few of them kicking around
Ellery in Maine
