Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Wed Sep 16, 2009 1:51 pm Post subject: Leaking |
Hi Bert:
If I recall correctly, there is a technique where you use a Loctite product (the name escapes me) that is green in color where you put a dab of it in the area of the leak and then apply suction to the tank with a vacuum. The sealer gets sucked into the leak.
Do a search in the archives and you should be able to find the specific Loctite product to use.
Jeff Orear
RV6A N782P
Peshtigo, WI
On Sep 16, 2009, at 4:03 PM, Robert Murillo wrote:
[quote]Hi:
My right tank, on my rv6a is leaking, I tried puting Pro seal on the out side , that does
not work.
Need the best way of doing this, and of course, if possible the easiest...
Is a pain removing all thos bolts..
Thanks for sugestions,
Bert
______________________________________ | Quote: |
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronics.com/Navigator?RV6-List
| [b]
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
maurice609(at)live.com Guest
Posted: Fri Sep 18, 2009 9:39 am Post subject: Leaking |
thanks Jeff: I will check on that
robert
To: rv6-list(at)matronics.com
Subject: Re: RV6-List: Leaking
Date: Wed C 16 Sep 2009 16:17:24 -0500
Hi Bert:
If I recall correctly C there is a technique where you use a Loctite product (the name escapes me) that is green in color where you put a dab of it in the area of the leak and then apply suction to the tank with a vacuum. The sealer gets sucked into the leak.
Regards C
Jeff Orear
RV6A N782P
Peshtigo C WI
On Sep 16 C 2009 C at 4:03 PM C Robert Murillo wrote:
| Quote: | Hi:
My right tank C on my rv6a is leaking C I tried puting Pro seal on the out side C that does
not work.
Need the best way of doing this C and of course C if possible the easiest...
Thanks for sugestions C
Bert
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
ronics.com
ww.matronics.com/contribution
| Lauren found her dream laptop. Find the PC that’s right for you. [quote][b]
robertrv09(at)yahoo.com Guest
Posted: Sat Sep 19, 2009 2:52 pm Post subject: Leaking |
Thanks I will look into
robert
--- On Wed, 9/16/09, Jeff Orear <jorear(at)new.rr.com> wrote:
Subject: Re: Leaking
Date: Wednesday, September 16, 2009, 9:17 PM
Hi Bert:
Jeff Orear
RV6A N782P
Peshtigo, WI
| Quote: | Hi:
not work.
Bert
=nofollow target=_blank>http://www.matronics.com/Navigator?RV6-List
et=_blank>http://forums.matronics.com
rledwards9(at)yahoo.com Guest
Posted: Sat Sep 19, 2009 6:40 pm Post subject: Leaking |
Yes, I used to use that on my Mooney and it works good on weeps but not running leaks. Not sure it's from Loctite though. Aircraft Spruce?
--- On Sat, 9/19/09, Robert Murillo <robertrv09(at)yahoo.com> wrote:
| Quote: | From: Robert Murillo <robertrv09(at)yahoo.com>
Date: Saturday, September 19, 2009, 6:49 PM
robert
Hi Bert:
Jeff Orear
RV6A N782P
Peshtigo, WI
wrote:
Hi:
not work.
Bert
=nofollow
