Question about (2-10) master switch
PostPosted: Tue Oct 06, 2009 8:28 am    Post subject: Question about (2-10) master switch Reply with quote
Is the 2-10 master switch a MAKE-BEFORE-BREAK switch? If yes and a standard DP3T switch was substituted, is it likely that the master contactor would drop out during the split second that the switch is moved from "alternator & battery" position to "battery only" position?
Joe
Joe Gores
PostPosted: Thu Oct 08, 2009 8:58 am    Post subject: Question about (2-10) master switch Reply with quote
The progressive transfers are exactly as described. Every
motion of the handle to another position moves only one
switch.
( -Thomas Paine 1776- )
