scc_ron(at)yahoo.com Guest
Posted: Thu Sep 03, 2009 1:57 pm Post subject: Fried Master Wires |
This is another example of how adding a ground
power jack (with ov and reverse polarity protection)
would have proved useful. I'm pleased that the
outcome of your experience was so benign . . . it
could have been much worse.
I'm mystified about the microphone jack. What
kind of voltage regulator does your airplane have?
If it's a built in regulator and it shifted in
regulation set point as a consequence of this
event, then it HAS been affected and is now suspect.
Thanks Bob for helping me understan what happened and why with my starting system. To answer your question, I have a new ND alternator off a forklift (35 amp) with internal regulator and "supposed" to have internal over voltage protection....can't swear to that, but that is what got me to purchase it over the 45 amp suzuki one that others have used.
Question. Will my new Odessey battery slowly discharge because the voltage output at 13.9 is now at least 0.3 volts lower than the 14.2 that the literature says one needs to charge it properly?
Ron
Posted: Thu Sep 03, 2009 2:44 pm Post subject: Fried Master Wires |
| Quote: | Thanks Bob for helping me understan what happened and why with my
others have used.
I can tell you with great confidence that there
is NO internally regulated alternator that features
more than an OV WARNING. Further, NONE have independent,
OV PROTECTION that is part and parcel of legacy
design goals for aircraft.
It will be prevented from achieving 100% state of
charge after cranking the engine for each flight.
It will probably perform as expected in terms of
getting an engine started but its energy content
as a standby power source will be degraded to some
extent. If you take LONG flights, it WILL get to
full charge at 13.9 but looking at my own log shows
that average flight cycle times are on the order of
1 hour.
So the battery won't "slowly discharge" it just wont
get fully charged on short flights.
susanspy
Posted: Mon Sep 14, 2009 6:15 am Post subject: Re: Fried Master Wires |
hello all,
i am Susan here, i am fun of this place thanks alot for the great informative post do some more post here.
thanks a lot!!!!!!!!!!!!!!!!!!!!
_________________ keyword tools~search keywords
Keyword Tracking Tool~overture tool |
