door lock size requirement
rv10builder(at)verizon.ne
PostPosted: Tue Sep 08, 2009 7:50 pm    Post subject: door lock size requirement Reply with quote
This is what I referenced.
Basically, measure the length of the rod. Drill a hole in the door and install. The reinforcement plate basically sits on the bottom ridge/flush with the front door so that it can not be twisted (forced out as the pressure is applied to the lock from the hinge- another way to explain this is with the door laying flat the plate sits on the outside door and low enough to touch the bottom ridge of the door). I pop riveted the plate to the door, drilled the hole for the lock centered on the plate.
Feel free to send me questions and I'll do my darnest to assist. Really wasn't too hard however.
Pascal
Sent: Wednesday, August 13, 2008 7:39 PM
Subject: Re: door lock size requirement
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Jesse,
Is this what you mean?
[img]cid:F9476C5966E44F24A63D870A53A25804(at)dell[/img]
Good idea. Wish I had done it this way.
Thank you,
Roger
 Filesize:  1.54 KB
 Viewed:  1267 Time(s)
