airlincoln(at)sbcglobal.n Guest
Posted: Wed Sep 09, 2009 8:21 am Post subject: RG58 vs. RG59 |
I am assembling an APRS system. I have created an J-pole antenna out of 300 ohm twin-lead cable (designed to send out short 144.39 MHz data transmissions) and have soldered onto that a short (18 inch) length of RG-58 coax..I note that AEC recommends RG-58 over RG-59 due to the latter's higher impedance. To connect the coax to the APRS module requires a female SMA connector -- I found one at Radio Shack that says it is designed for crimping onto RG-58 cable...so far so good. I've been to three local stores and can only find strippers/crimpers for RG-59 cable. However, the ones I find online make it sound like tools for RG-58 and RG-59 cable are interchangeable. I also note from Wikipedia [http://en.wikipedia.org/wiki/Coaxial_cable] that RG-58 and RG-59 cable have slight differences in their inner, outer and dielectric diameters.
Question #1: Can I successfully use an RG-59 stripper/crimper to attach an SMA connector to RG-58 cable or do I need to find a tool specifically designed for RG-58 cable?
Question #2: Will a crimping tool work equally well with BNC and SMA connectors or do I need separate tools for each?
Bonus question: Would my J-pole antenna perform better laying flat (horizontal) in my fiberglass wingtip or looped around the leading edge so it has some "vertical polarization"?
Thanks to whoever can provide guidance.
Lincoln Keill
RV-7A Fuselage
frank.hinde(at)hp.com Guest
Posted: Wed Sep 09, 2009 8:46 am Post subject: RG58 vs. RG59 |
I bought my RG 58 BNC crimper from Radio Shack for about 11 bucks I think..Just in case that will work.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Lincoln Keill
Sent: Wednesday, September 09, 2009 9:17 AM
Subject: RG58 vs. RG59
Lincoln Keill
RV-7A Fuselage
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
Posted: Wed Sep 09, 2009 10:08 am Post subject: RG58 vs. RG59 |
At 11:17 AM 9/9/2009, you wrote:
| Quote: | I am assembling an APRS system. I have created an J-pole antenna
Why so mechanically complex an antenna in an airplane?
We're talking VHF which is line of sight. What leads
you to believe that this device will perform any better
than a simple 1/4-wave vertical used in VHF communications
applications?
| Quote: | and have soldered onto that a short (18 inch) length of RG-58
RG58's 50 ohm characteristic impedance has been
generally adopted by the electronics industry
as the design of choice for power handling capability
while the RG58's 75 ohm impedance is favored for
lower loss. The later is used in television and
low level signal situations.
| Quote: | To connect the coax to the APRS module requires a female SMA
Yes, connectors, strippers and application tools are
specific to the dimensions of the coax . . .
| Quote: | Question #1: Can I successfully use an RG-59 stripper/crimper to
You need the right tool . . .
| Quote: | Question #2: Will a crimping tool work equally well with BNC and
It's brand and part number specific. While MOST
manufacturer's of RG58 compatible connectors will
crimp the shield/pin grips with a .068"/.113" hexes,
it's not automatic. You need to match the tool with the
connector.
| Quote: | Bonus question: Would my J-pole antenna perform better laying flat
Please consider a single run of RG400 from the accessory
to a simple 1/4-wave antenna on a ground plane fabricated
as described in many resources including the chapter
on antennas in the AeroElectric Connection.
You can get a compatible SMA male here:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ACX1192-ND
You can get a BNC male and the tool to install both
connectors at:
http://bandc.biz
( -Thomas Paine 1776- )
