jay(at)horriblehyde.com Guest
Posted: Tue Sep 08, 2009 1:46 pm Post subject: 24V Systems and Contactors |
Hey there Bob,
I see that the contactors that B&C supply are only for use on 12V systems; any idea of where to get 24V ones for use in the Z-Diagrams? Or can one adapt the 12V ones to use in a 24V system? It looks to me as if I would have to use a 15 ohm 10W or higher resistor to drop the voltage to the contactor coil.
Jay
Bruce(at)glasair.org Guest
Posted: Tue Sep 08, 2009 2:15 pm Post subject: 24V Systems and Contactors |
http://www.gigavac.com/products/contactors/datasheets/gx11/index.htm
Bruce
www.Glasair.org
mrspudandcompany(at)veriz Guest
Posted: Tue Sep 08, 2009 2:42 pm Post subject: 24V Systems and Contactors |
Hey there Bob,
Jay
Aircraft spruce has a 24V master contactor.
Roger | [b]
Posted: Tue Sep 08, 2009 4:20 pm Post subject: 24V Systems and Contactors |
At 04:43 PM 9/8/2009, you wrote:
| Quote: | Hey there Bob,
I see that the contactors that B&C supply are only for use on 12V systems; any idea of where to get 24V ones for use in the Z-Diagrams? Or can one adapt the 12V ones to use in a 24V system? It looks to me as if I would have to use a 15 ohm 10W or higher resistor to drop the voltage to the contactor coil. |
That style of contactor (as are most other styles) available
in a variety of operating voltages. Check out the
various catalogs under "Contactors" at:
http://aeroelectric.com/Mfgr_Data.html
You can get many of those devices from a number of
sources including:
http://www.alliedelec.com
http://www.newark.com
http://www.mouser.com
. . . and no doubt others.
By the way, our 9024 series power monitoring and
management devices will be available in both 12
and 24 volt versions.
( -Thomas Paine 1776- )
