Tail shaking
jlsk1(at)frontiernet.net
PostPosted: Fri Sep 04, 2009 1:49 pm    Post subject: Tail shaking Reply with quote
Hi All,
I was talking Offlist with a few fellow Kolbers about the tail wire tension, (and the Kolblist tension), and a question was posed to me about how much tailshaking is normal, so, if you guys don`t mind, how about looking over your shoulder the next time you fly & report back on this topic please?
With all the talk about the wire attach tangs lately, What We`re specifically looking for is several things.:
How much , if any, is the leading edges of the horizontal & vertical stabilizers vibrating in flight? And, If they are any worse or better at any power settings & or airspeeds?
For instance, does power matter? or Airspeed in a descent with no power? I will chime in too, but later.
I`m posting this because there are a SEVERAL of Kolb Owner newbies that have been in touch with me & are reluctant to post to the list, because of all of the negative comments that have been thrown by a certain member of this list, & didn't want to stir up more crap. (Sad, Huh?)
The owners are MK-3C & MK-3X pilots, but I`m sure we all may learn.
Of course, we will all have to understand that the tail wires are as tight as the owners are comfortable flying with, or they wouldn't` fly.
I know this topics was touched on earlier, `cuz an archive search yielded John H`s response, but we`d like an up to date comment.
Thanks in advance
Jim Kmet
Cookeville, TN
912 MK-3C
slyck(at)frontiernet.net
PostPosted: Fri Sep 04, 2009 5:41 pm    Post subject: Tail shaking Reply with quote
Jim, my tail wires have never been very tight. They are more so now than originally but not "twangy"I have never noticed any problems with vibration or rudder flutter. The cable thimbles are starting to show
a little wear and will have to be checked closely before next season.
I'm still a little shy about picking up too much speed in a long power off dive because of the aileron flutter I once had.
(pre-balancers) and pay close attention to what's going on. Seems good now.
BB
MkIIIc
On 4, Sep 2009, at 5:14 PM, Jim Kmet wrote:
Hi All,
Thanks in advance
Jim Kmet
Cookeville, TN
912 MK-3C
planecrazzzy
PostPosted: Fri Sep 04, 2009 5:56 pm    Post subject: Re: Tail shaking Reply with quote
I don't tighten my wires THAT much.... they're tight ... but a dull twang
My tail is steady.... I know I had a bad wiggle/shimmy ( still do)
But I found out it's those cheap outa round tires I got ( Chin?)
I hit my brakes after take-off and it solves it.... Once these wear
a little more... I'll buy better tires... I like the ones I bought for
my other plane... Same wheel size , but taller ( Still 6 X 6.00 )
Gotta Fly...
Mike & "Jaz" in MN
New Kolb Forum - http://groups.yahoo.com/group/kolbaircraft/
h20maule(at)hotmail.com
PostPosted: Fri Sep 04, 2009 6:00 pm    Post subject: Tail shaking Reply with quote
Jim C the first time I noticed mine it scared me so bad and called my friend Jack. He said it was normal C so I kept going. Is yours shaking? or swaying?
Subject: Re: Tail shaking
Date: Fri C 4 Sep 2009 21:40:04 -0400
Jim C  my tail wires have never been very tight.  They are more so now than originally but not "twangy" I have never noticed any problems with vibration or rudder flutter.  The cable thimbles are starting to show
BB
MkIIIc
On 4 C Sep 2009 C at 5:14 PM C Jim Kmet wrote:
Hi All C
 I was talking Offlist with a few fellow Kolbers about the tail wire tension C (and the Kolblist tension) C and a question was posed to me about how much tailshaking is normal C so C if you guys don`t mind C how about looking over your shoulder the next time you fly & report back on this topic please?
With all the talk about the wire attach tangs lately C What We`re specifically looking for is several things.:
How much C if any C is the leading edges of the horizontal & vertical stabilizers  vibrating in flight? And C If they are any worse or better at any power settings & or airspeeds?
 For instance C does power matter? or Airspeed in a descent with no power? I will chime in too C but later.
I`m posting this because there are a SEVERAL of Kolb Owner newbies that have been in touch with me & are reluctant to post to the list C because of all of the negative comments that have been thrown by a certain member of this list C & didn't want to stir up more crap. (Sad C Huh?)
 The owners are MK-3C & MK-3X pilots C but I`m sure we all may learn.
Of course C we will all have to understand that the tail wires are as tight as the owners are comfortable flying with C or they wouldn't` fly.
 I know this topics was touched on earlier C `cuz an archive search yielded John H`s response C but we`d like an up to date comment.
Thanks in advance
Jim Kmet
Cookeville C TN
912 MK-3C
ttp://www.matronics.com/Navigator?Kolb-List
ronics.com
ww.matronics.com/contribution
Windows Live: Make it easier for your friends to see what you’re up to on Facebook. Find out more. [quote][b]
JetPilot
PostPosted: Fri Sep 04, 2009 7:44 pm    Post subject: Re: Tail shaking Reply with quote
Jim Kmet
Cookeville, TN
912 MK-3C
Its obvious from your comment that you just cant let your bitterness go or even respect what Matt asked of us, and end this. Here, instead of just post your question, you just had to take the opportunity to try to post a negative comment even after everything had pretty much blown over. You were so desperate to throw out some negative comments and insults that you resorted to doing it in a new thread. You are nothing but a hypocrite that is saying how sad it is to have crap stirred up, when you take every opportunity to stir it up yourself. I am tired of bitter and vindictive and bitter hypocrites like yourself blaming me for your bad behavior.
As far as newbies on the list, I have been talking to a lot of them myself and many are afraid to post because of the likes of yourself and your little gang that try to intimidate and silence the opinions of those on this list you don't like. What is really sad is that even after Matt Dralle asked nicely, you are so bitter you have to try to start shit again in a new thread. No is one responsible for you trying to stir up shit and hard feelings on the list but yourself. Your nasty and negative comments in this thread were unsolicited and uncalled for. People must be getting tired of this crap, I am sure you will not get much support for starting it up again.
Mike
Kolb MK-III Xtra, 912-S
aoldman(at)xtra.co.nz
PostPosted: Fri Sep 04, 2009 11:15 pm    Post subject: Tail shaking Reply with quote
I have the same out of ballance tyres . Jab on the brakes fixes the problem.
Also have one that slowly goes down. A real pain taking the spats off to
pump up, about every 6 months.
TonyDownuder
MK111c
PostPosted: Sat Sep 05, 2009 4:10 am    Post subject: Tail shaking Reply with quote
I never mentioned a name, why did you did you take it personal?
Jim Kmet
JetPilot
PostPosted: Sat Sep 05, 2009 5:19 am    Post subject: Re: Tail shaking Reply with quote
Jim Kmet
It is very obvious who this post was directed at, given you and your recent posts in other threads directed at myself. You authored a post and included negative comments that were uncalled for and designed stir up trouble again. Are you now trying to lie to everyone on this list ? Are you saying that posting negative and provocative crap is OK if you don't say a name ? Pretty sad people like you are giving the Kolb list a bad name.
Mike
PostPosted: Sat Sep 05, 2009 5:43 am    Post subject: Tail shaking Reply with quote
Got a suggestion. My suggestion does not have anything to do with this
thread or the subject line. Neither does the personal messages that have
overwhelmed the Kolb List in the past few days.
If it ain't related to building and flying Kolbs, take it back copy. The
majority of this List are not interested in a few of you acting like kids.
Take time to pull up Matt Dralles commandments on how to conduct yourself on
this List.
Don't let someone else control your feelings. Every time you react, you are
being controlled.
Quit grading others and try to learn something or share some information
about building and flying Kolbs.
mkIII - Back to vacation mode.
Rock Springs, WY
PostPosted: Sat Sep 05, 2009 12:57 pm    Post subject: Tail shaking Reply with quote
Daniel, BB, & all, , here`s my experience with the Tail shaking:
Mine is comfortably solid, except the leading edges of both horizontal stabs.They do vibrate. I twist around to see when they are doing it the worst. Full power climb out , they are fine. low power , slow flying, they are fine.
Seem to me they are the worst when I`m trying to cover ground, 5000 rpm & higher, in level flight, BUT, they will do it also, when I`m in a relatively high, (like cruise speed), descent with idle power. That makes me think it is more of a result of turbulent air coming around the cockpit, than of the thrust from the prop.
Yea, the whole rear end of the plane will shake a little too., but so does the 182 I fly. When the Piper Tomahawk came out, that big visible tail scared alot of people when they saw it shaking.
I do have a plan to try, but will take some time to do & I`ll report back on that later, after I see results. In the mean time, I`d like to hear more from pilots after they twist around in the coming weeks, & report back.
Jim Kmet
912-MK3C
Cookeville, TN
Richard Pike
PostPosted: Sat Sep 05, 2009 1:42 pm    Post subject: Re: Tail shaking Reply with quote
[quote="jlsk1(at)frontiernet.net"]Hi All,
<snip>
Jim Kmet
Cookeville, TN
912 MK-3C
Jim, haven't had a chance to check mine recently, checked it years ago, and it did do some wiggling and shaking.
Back in the days when I was flying a Hummer, which had a 5" boom tube like the FS, when you turned around and looked at the tail, it didn't look good, that thing wiggled and twitched around in the prop blast something fierce. Maxair Drifter was about the same way. But it never seemed to bother it. IMO, a certain amount of twitching and wiggling is normal.
How about this: adjust your wires a tad looser than normal, tie the tail wheel to something secure and run the engine up full throttle and watch it for a while. Then tighten the wires up snug and try it again. Which ever you like the most, make that your normal.
Richard Pike
MKIII N420P (420ldPoops)
zeprep251(at)aol.com
PostPosted: Sat Sep 05, 2009 4:31 pm    Post subject: Tail shaking Reply with quote
Guys,
I like them tight too.But if you fold and unfold you have some difficulty getting that little wing nut started if the tension is too high.Had to compromise on it some.The tangs on my MK-3 were all bent well past the holes, so far so good 470hrs and I lube the area where the tangs and thimble touch.Saw some red"smoke "there and thought lubing was in order
G.Aman
WhiskeyVictor36(at)aol.co
PostPosted: Sat Sep 05, 2009 8:13 pm    Post subject: Tail shaking Reply with quote
In a message dated 9/4/2009 9:56:44 P.M. Eastern Daylight Time, planecrazzzy(at)yahoo.com writes:
Mike & Jazz,
I had the same problem with cheap made ying yang chin tires. I also did the 'hit the brakes thing' to stop rotation and vibration after take-off. But then one day I got over excited and hit the brakes while still on the ground. Since I only have those go-kart drum brakes, there was no danger of nosing over, but it did get my attention. I have since used some home made lead weights to balance the wheel/tire assembly.  Used double sided tape to attach to inner part of wheel rim. Tried to use auto weights but they wouldn't fit the wheel barrow rims.
Bill Varnes
Original Kolb FireStar
Audubon NJ
ces308
PostPosted: Mon Sep 07, 2009 12:27 pm    Post subject: Re: Tail shaking Reply with quote
Hello all....I took another video out the back with the doors and windows off and this is what I got. The video is not the best ,but it doesn't seem that bad...looks worse on the ground that in the air...
Anyway...for what it's worth....
http://www.youtube.com/watch?v=LU-Hr6HigcQ
chris ambrose
M3X/Jab 60+hrs
N327CS
PostPosted: Mon Sep 07, 2009 5:55 pm    Post subject: Tail shaking Reply with quote
is what I got.
chris ambrose
Chris A/Gang:
The 6" tail boom is a very flexible tube.
Most of the prop blast is hitting the side of the tail section.
Prop blast knocks it one way and relative wind is pushing it back.
Amazing how stable the tail section is considering the environment it lives.
West Yellowstone, Montana - Forecasting 29F tonight with rain and snow.
pj.ladd(at)btinternet.com
PostPosted: Tue Sep 08, 2009 1:52 am    Post subject: Tail shaking Reply with quote
West Yellowstone, Montana - Forecasting 29F tonight with rain and snow. >>
Hi John,
Dont envy you the weather but I certainly do the country. Up there about 5
years ago. Superb
Cheers
Pat
Richard Pike
PostPosted: Tue Sep 08, 2009 5:48 am    Post subject: Re: Tail shaking Reply with quote
chris ambrose
M3X/Jab 60+hrs
N327CS
Based on your video, the tail is going to get way more abuse on the ground taxiing than in the air. I am adding a "Hauck tailwheel brace" to mine and not worrying about it.
Richard Pike
Ralph B
PostPosted: Tue Sep 08, 2009 6:28 am    Post subject: Re: Tail shaking Reply with quote
The problem with loose tail wires is the the stainless thimbles will wear a "notch" into it over time. This happened on my Original Firestar with the wingnut used to tighten it at the bottom of the rudder post. After replacing with new wires, I decided to use a lock nut and wrench to get it tighter. The old wires shook while flying as I could see them well. After tightening with the new ones, the tail still shakes, but not as much. The kit used a wingnut because Homer wanted to keep the setup simple without the use of tools. The wingnut just didn't get it tight enough.
The Kolbra uses turnbuckles to tighten and they are reasonably tight with no tail shake with the 6" fuse tube (Firestar uses a 5" fuse tube).
Ralph B
 Filesize:  65.74 KB
 Viewed:  14743 Time(s)
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
Dana
PostPosted: Tue Sep 08, 2009 3:13 pm    Post subject: Tail shaking Reply with quote
I've never noticed it in the air, but the tail of my UltraStar shakes alarmingly on the ground when I do a preflight runup.
-Dana
The most important and least understood aspect of life in America is stupidity.
-- F.Zappa [quote][b]
