Posted: Wed Sep 02, 2009 8:12 am Post subject: New Z-figure (Corvair) |
I've just uploaded a new Z-Figure intended to address the
unique requirements of automotive conversions that use the
Kettering points/coil/distributor ignition systems.
In this case, the drawing is tailored to the design philosophy
of Wm. Wynn at Flycorvair.com with additional attention
to minimizing single points of failure for both systems
-AND- observance of contemporary philosophies for handling
always hot wires off the battery bus.
This drawing also introduces a new product from the 'Connection.
We've got about a dozen new products in the pipe but I needed
a good training program for my kids who are getting geared up
to take over the business side of the AeroElectric Connection.
The AEC9024
( -Thomas Paine 1776- )
Posted: Wed Sep 02, 2009 8:28 am Post subject: New Z-figure (Corvair) |
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z09A.pdf
The AEC9024
. . . OOPS . . . got tangled around that SEND button again . . .
The AEC9024 series product offers 4 functions in a single device
that uses a packaging scheme much like the crowbar OV modules.
In this case, the device incorporates a microprocessor and
10 other components that can be used to effect . . .
Contactor Power Management (make el-cheeso battery contactors
operate luke-warm).
Alternator OV disconnect relay driver for PM alternators
LV Warning module for LED or Incandescant lamps.
Aux Battery Management Module.
Figure Z-9 illustrates three of the four functions for
the AEC9024
The 9024 will be shipped with instructions for wiring
to accomplish any of these functions. You program the
device to the intended task by clipping jumpers. This
critter is an attractive training product and equally
attractive merchandising opportunity. One product
of only 11 components helps keep inventory costs low.
The critter will sell for under $30.
Software is under development and the board artwork will
go to the board shop next week. My chamber is up an
running so testing won't take long.
mrspudandcompany(at)veriz Guest
Posted: Wed Sep 02, 2009 10:21 am Post subject: New Z-figure (Corvair) |
| Quote: | I've just uploaded a new Z-Figure intended to address the
Bob,
Is there a reason why you are using a single ignition switch, with a single
point of failure, for the dual ignition?
Roger
Posted: Wed Sep 02, 2009 12:05 pm Post subject: New Z-figure (Corvair) |
Bob,
Is there a reason why you are using a single ignition switch, with a single point of failure, for the dual ignition?
Roger |
Yup, that's a William Wynn design philosophy described
in Chapter 5 of his installation documentation:
http://tinyurl.com/nd42op
I would have opted for a pair of independent switches
but his rationale for the single switch is well
articulated. I did expand to 4-poles so that I could
protect each power lead on it's own fuse. Getting into
a one versus two switch argument wasn't going to be
very productive.
Of course, any builder could split to a pair of
switches at their own choosing. This Z-figure offers
an "AeroElectric Connection" style power distribution
diagram that assists his builders in crafting an installation
consistent with his well thought out design goals.
raymondj(at)frontiernet.n Guest
Posted: Wed Sep 02, 2009 1:58 pm Post subject: New Z-figure (Corvair) |
Given that both sides of the discussion have merit, does any know if
they still make the blocks that clamp over a pair of toggle switches.
Much of the stock video footage of missile launches and control rooms
show someone flipping one. They usually had yellow and black diagonal
stripes.
Is there a modern equivalent To that type of setup.
Raymond Julian
| Quote: | >
> Bob,
> Roger
* http://tinyurl.com/nd42op*
very productive.
franz(at)lastfrontierheli Guest
Posted: Wed Sep 02, 2009 2:51 pm Post subject: New Z-figure (Corvair) |
I have seen them at Stein Air
Franz
On 02/09/09 2:47 PM, "ray" <raymondj(at)frontiernet.net> wrote:
stripes.
Raymond Julian
>> Bob,
>> Roger
> very productive.
> Bob . . .
Franz Fux
Director of Operations
Last Frontier Heliskiing Ltd.
Bell 2 Lodge
P.O. Box 1237
Vernon, BC, V1T 6N6
CANADA
Office Contact
T: (250) 558-7980
F: (250) 558-7981
http://www.lastfrontierheli.com
Lodge Contact
T: (250) 275-4770
F: (250) 275-4912
http://www.bell2lodge.com
Posted: Wed Sep 02, 2009 4:28 pm Post subject: New Z-figure (Corvair) |
At 04:47 PM 9/2/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: ray <raymondj(at)frontiernet.net>
Given that both sides of the discussion have merit, does any know if they still make the blocks that clamp over a pair of toggle switches. Much of the stock video footage of missile launches and control rooms show someone flipping one. They usually had yellow and black diagonal stripes.
Is there a modern equivalent To that type of setup. |
There's a variety of hinged covers that can be
used over the bat-handled toggle switches.
http://tinyurl.com/mnoc55
These are readily available from a lot of sources.
Know that they come in a lot of dash numbers for
spring loaded closed, stable in open position,
and cams on the inside of the cover to force the
handle into a certian position when the cover is
closed.
OH . . . a PAIR of toggle switches? Inadvertent
operation fences? I think Eric Jones offers some
off of his website.
Are you talking about those honk'en big covers
with a hinged lid? Why would you want such a thing
on your panel?
Posted: Wed Sep 02, 2009 5:35 pm Post subject: New Z-figure (Corvair) |
I think we've had a little data dropout. What I'm asking about is a way
to physically tie the 2 handles together so that the 2 switches must be
operated together. The idea being to eliminate a single point of
failure while still implementing the 1 switch philosophy from WW.
Raymond Julian
> stripes.
* http://tinyurl.com/mnoc55*
closed.
off of his website.
on your panel?
n8zg(at)mchsi.com Guest
Posted: Wed Sep 02, 2009 6:45 pm Post subject: New Z-figure (Corvair) |
Raymond -
The switch-tie device you describe would be easy to fabricate.
A chunk of 0.250 or 0.3125 aluminum, a drill press and a little time with a
file...
neal
Subject: Re: New Z-figure (Corvair)
Raymond Julian
echristley(at)nc.rr.com Guest
Posted: Wed Sep 02, 2009 7:08 pm Post subject: New Z-figure (Corvair) |
ray wrote:
stripes.
mpja.com has been giving them away for the almost the cost of shipping
for a while now.
Ernest Christley, President
Ernest(at)TechnicalTakedown.com
TechnicalTakedown, LLC
www.TechnicalTakedown.com
101 Steep Bank Dr.
Cary, NC 27518
(919) 741-9397
Posted: Wed Sep 02, 2009 7:14 pm Post subject: New Z-figure (Corvair) |
At 09:43 PM 9/2/2009, you wrote:
Raymond -
file...
neal
Aha! But of course. Neal's suggestion works. I've not
seen those as a catalog item but they're not hard to
make. Some aluminum bar stock, drills, taps, set screws,
and some sculpting on the sander would work good. I think
I would sand some flats on the switch handles for the set
screws to grip and run screws in from both sides . . . not
unlike
http://www.aeroelectric.com/articles/Tech_Tips/FlapSwitch/FlapSw2.jpg
jindoguy(at)gmail.com Guest
Posted: Thu Sep 03, 2009 5:48 am Post subject: New Z-figure (Corvair) |
Ray, If you're talking about the flip up covers over the toggle switches, they can be had at your local auto parts store. At least in red. About $5 each at O'Rielly's.
Rick Girard
On Wed, Sep 2, 2009 at 4:47 PM, ray <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)> wrote:
[quote] --> AeroElectric-List message posted by: ray <raymondj(at)frontiernet.net>
Raymond Julian
| Quote: | | Quote: |
Bob,
Roger
very productive.
le, List Admin.
