Installing New Brake Lines ... Questions
Jerry Grimmonpre'
PostPosted: Wed Sep 02, 2009 7:39 am    Post subject: Installing New Brake Lines ... Questions Reply with quote
Dear Listers,
I'm replacing nylon lines with stainless braid/teflon tube.
Is there any braking effectiveness difference between the -3 size and the -4 size lines?
Is it true that the -3 lines cost more to fabricate because they are smaller therefore harder to fabricate?
What does the list suggest to order ... the -3 or the -4 lines and why is one better than the other?
Where is the best place, for price and service, to have the lines fabricated?
Many thanks for the vast experience of this list ..
Jerry
Vanremog(at)aol.com
PostPosted: Wed Sep 02, 2009 7:49 am    Post subject: Installing New Brake Lines ... Questions Reply with quote
I had my Earl's lines fabricated at a speed shop and I prefer the smaller size line. There is very little flow in braking systems and the smaller size will give a firmer feel because of the reduction in internal surface area.
-N1GV
In a message dated 9/2/2009 8:40:51 A.M. Pacific Daylight Time, jerry(at)mc.net writes:
Neal.George(at)hurlburt.a
PostPosted: Wed Sep 02, 2009 7:56 am    Post subject: Installing New Brake Lines ... Questions Reply with quote
Jerry -
The good folks at Bonaco (www.bonacoinc.com) provide exceptional service at
low cost.
neal
Subject: Installing New Brake Lines ... Questions
Dear Listers,
size lines?
Many thanks for the vast experience of this list ...
Jerry
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.04 KB
 Downloaded:  597 Time(s)
bmeyette
PostPosted: Wed Sep 02, 2009 8:20 am    Post subject: Installing New Brake Lines ... Questions Reply with quote
on pressure side, smaller is better - less fluid to move & smaller size transfers the pressure more efficently
on supply side, larger is better - less resistance
in motorcycle roadracing, we usually use -2 lines for brakes
not sure if you can get them custom-made, though
if i was going to get s/s braided brake lines, I'd first look at a motorcycle supplier like Street & Competition
http://www.streetandcomp.com/
or here
http://tinyurl.com/lyctk8
only issue might be if they can't do the 37 degree fitting we need
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry Grimmonpre
Sent: Wednesday, September 02, 2009 11:39 AM
To: rv-list(at)matronics.com
Dear Listers,
Jerry
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
No virus found in this incoming message. Checked by AVG - www.avg.com 270.13.74/2339 - Release Date: 09/02/09 05:50:00 [quote][b]
Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm
Bret Smith
PostPosted: Wed Sep 02, 2009 9:55 am    Post subject: Installing New Brake Lines ... Questions Reply with quote
Call Brett at www.Bonacoinc.com. He has the sets for every make of RV. All braided Teflon lines with colored liners. Reasonable prices and excellent customer service.
Bret Smith
RV-9A N16BL
Blue Ridge, GA
www.FlightInnovations.com
Bret Smith
RV-9A (Emp)
