jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Wed Apr 22, 2009 8:49 am Post subject: Report no. 2 from Sun n Fun - The Heintz clan reactions to. |
On Wed, Apr 22, 2009 at 12:13:38AM -0400, JohnDRead(at)aol.com wrote:
| Quote: | Can some body tell me what a ZBAG is? Is it some foreign group who do not
like Zenith aircraft or what?
The Zenith Builders Analysis Group is a group of concerned Zodiac builders,
owners, and pilots who banded together to commission an independent
engineering study of the Zodiac. It was formed in response to what was seen
at the time as Zenair's reluctance to do full engineering studies of the
Zodiac's structure, both static and dynamic.
I am a contributing member of ZBAG. I can assure you that I love my Zodiac,
and would like nothing more than to see the cloud over it removed - whatever
that takes.
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
jmaynard
Posted: Thu Apr 23, 2009 6:42 am Post subject: Report no. 2 from Sun n Fun - The Heintz clan reactions to. |
On Thu, Apr 23, 2009 at 12:29:57AM -0400, JohnDRead(at)aol.com wrote:
| Quote: | The problem with zbaggers is that even though they have hired a
"professional engineer" they still keep spouting hearsay and inuendo which
is just clouding any issues that Zenith aircraft MAY or may not have. As I
have said before, if you "know " so much about what is wrong with the 601
why do you not design your own airplanes and leave Zenith aircraft to
those of us who are comfortable with the designs of a person of the
stature and experience of Chris Heintz.
Aw, cmon, John. The next thing you'll tell us is that the only reason Chris
Heintz does not take regular walks across Lake Geneva is because he doesn't
like having wet shoes!
Nobody's perfect. Not even Chris Heintz.
Until an explanation is found, everything is suspect. Even the aircraft's
design. Recognizing the facts is not hysteria. It's an essential component
of a calm, sober analysis of the problem and its resolution.
Until the facts can be explained, we'll continue to have to deal with the
fallout of 6 inflight breakups in 2 years. We don't have a choice in the
matter. We can't stick our heads...in the sand, no matter how much we wish
the problem will simply go away. It won't.
I'm not an aircraft designer. I'm a computer geek. I'm not going to presume
for a moment that aileron mass balances are the one and only answer. I'm not
qualified to make that call. However, when every aeronautical engineer I've
spoken with has said that cable tension alone is not sufficient to prevent
flutter, and when every bit of FAA guidance on the subject says that it's
not, I'm going to come to the conclusion that adding mass balances is a
Good Thing unless it's demonstrated conclusively to me that the Zodiac
design is not susceptible to it.
I don't know if that's the fix. That's why I, along with others, asked a
couple of engineers to look at the design and come up with recommendations.
I'm highly disappointed that there's a segment of the Zenith community that
has chosen to demonize those of us who saw a need for an independent look at
the design and put our own money where our mouths are, just as I'm
disappointed that ZBAG has chosen, so far, not to release the results that
it furnished to the NTSB. Neither action is helpful to the overall goal: to
make sure we have aircraft that are safe to fly throughout their entire
envelope.
jmaynard
Posted: Fri Apr 24, 2009 7:15 am Post subject: Report no. 2 from Sun n Fun - The Heintz clan reactions to. |
On Thu, Apr 23, 2009 at 12:01:14PM -0400, JohnDRead(at)aol.com wrote:
| Quote: | I was not intending to infer the Chris Heintz is perfect either, no body
is BUT he has a good record in aviation engineering.
Good? Yes. Infallible? No. However, there are folks acting as though he is.
| Quote: | While six planes having a problem in two year is troublesome it is quite
a low failure rate.
It's much higher than average, and high enough that it's caused folks
responsible for aviation safety to sit up and take notice. That's all that
matters.
| Quote: | So far the only common failure is that something caused the wings to
separate, now as has been pointed out there are several possible causes,
pilot error; flying the aircraft outside design limits, showing off and
over speeding or overloading the airframe. Inadequate construction.
Inappropriate modifications, flutter, improper adjustment of control
cables and so on.
However, there's at least one accident where the airplane was built in a
certified factory and not flown outside the aircraft's design limits. That
leaves other causes that are far less easy to handwave away.
| Quote: | The zbaggers are not an "official" group so why are they not being
transparent with the alleged information they have? Let's see the
qualifications of those who claim to be doing structural analysis and
verify their calculations.
I agree. I've been trying to get this to happen, so far without much
success.
rpf(at)wi.rr.com Guest
Posted: Fri Apr 24, 2009 2:40 pm Post subject: Report no. 2 from Sun n Fun - The Heintz clan reactions to. |
| Quote: | However, there's at least one accident where the >airplane was built in a
certified factory and not flown outside the aircraft's >design limits. That
leaves other causes that are far less easy to handwave >away.
Jay,
I'm wondering how in the heck you can make this statement. Do you know for
sure that every hour put on that plane it was not flown outside the design
limits? It was never in rough tourbolence and never over controlled? Did
you personally witness that plane fly for the total hours it was flown?
Come on man,
Randy
jimysymonds
Posted: Thu Sep 03, 2009 10:07 pm Post subject: Re: Report no. 2 from Sun n Fun - The Heintz clan reactions |
It seems like it might if my foot was now at an angle to the pedal which is causing more pressure on the inside of my foot versus across the whole.
_________________ Size 12 shoes |
