dsvs(at)comcast.net Guest
Posted: Fri Apr 07, 2006 10:30 am Post subject: Air Speed Switch |
Bob and Others
I need to purchase an airspeed switch that is closed when stationary and opens at roughly 15 knots. An adjustable unit is fine as long as the adjustment point can be set for fairly low (15-20 knot) range. Any idea of a vendor for this device. ACS has only one and the adjustment point is above 80 knots. Thanks in advance. Don
nuckollsr(at)cox.net Guest
Posted: Sat Apr 08, 2006 3:05 pm Post subject: Air Speed Switch |
At 06:25 PM 4/7/2006 +0000, you wrote:
Quote: |
Bob and Others
Recall that dynamic pressure (pitot pressure, or "q") varies
as the square of velocity. At 200 mph you get 20" of water
pressure. So for 1/10th that velocity or 20 MPH, you get
1/100th the pressure or 0.2" of H20. 20Kts would be 23
MPH so .2" is right in the ballpark.
That is an exceedingly small pressure to sense. I doubt
that anyone has a switch that will operate directly
from that kind of pressure.
What are you wanting to do with it? Parhaps there's
a more rugged and less expensive way to get at the
functionality.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Sat Apr 08, 2006 6:43 pm Post subject: Air Speed Switch |
Bob,
The switch is recomended by Avidyne for use with their TCAS systems. It is
to take the device out of ground mode and into airborne mode. I used to fly
a piper twin that had the same type of switch to start the "air hobbs"
meter. BTW Avidyne does not have a source, that is why I am hoping that you
had one. Thanks. Don
frank.hinde(at)hp.com Guest
Posted: Sat Apr 08, 2006 7:30 pm Post subject: Air Speed Switch |
At 07:37 PM 4/8/2006 -0700, you wrote:
Quote: |
Bob,
Hmmmm . . . Frank knows of some devices with that sensitivity.
As one might expect, it's pretty big. How about an RPM switch
set at something like 1500 rpm. You could even put a timer
in the loop so that the air mode happens after say 30 seconds
above 1500. This would let you do mag-chex, etc without triggering
the air mode. Signal would come from the tach output on an ignition
or p-lead on mag.
Have you called Avidyne?
Posted: Sat Apr 08, 2006 7:50 pm Post subject: Air Speed Switch |
Called Avidyne, they say buy from Cirrus. Cirrus has one but will not sell
it to home builders. Still looking for a Cirrus repair facility that will
sell one. I,m running P-mags so I have two seperate tach hall effect sensors
built in. Was planning on using both to run seperate tach outputs, just
because I have two instruments that will show RPM. Where do I get an RPM
switch? Thanks. Don
richard(at)RILEY.NET Guest
Posted: Sat Apr 08, 2006 8:45 pm Post subject: Air Speed Switch |
At 07:37 PM 4/8/2006, you wrote:
Quote: |
Bob,
Velocity has one, it's pretty inexpensive but works fine. I think
it's an industrial part adapted from a clothes dryer.
There's a nice (much more expensive) one available from:
Airspeed Switch
Value Engineered Products
3541 Old Conejo Road, Ste #117
Newbury Park, CA 91320
(805) 499-1959
(805) 499-1955
email: vep1(at)pacbell.net
www.veproducts.com
Part #654A53.2
Jim Baker
Posted: Sat Apr 08, 2006 8:51 pm Post subject: Air Speed Switch |
Quote: | The switch is recomended by Avidyne for use with their TCAS
systems.
Quote: | It is to take the device out of ground mode and into airborne mode.
Sure beats me whay they didn't just use a GPS signal to run the
system...sorta like the setting for a KLN series GPS that only starts
timing above 30kts....say, use a $GPRMC string, and parse out the
speed with a PIC and some code (or a BASIC stamp) and use
that to drive a relay.
Jim Baker
580.788.2779
Elmore City, OK
BigD(at)DaveMorris.com Guest
ivor(at)ivorphillips.flye Guest
Posted: Sun Apr 09, 2006 3:02 am Post subject: Air Speed Switch |
http://rswww.com/cgi-bin/bv/initSession.jsp?goto=/rswww/subRangeAction.do&catoid=-1600769365&store=uk
Quote: |
It works well as a stall warner, If you reverse the Inlet pipe it will
work as a pressure switch, And its ajustable!
The previous link didnt seem to work, But this one should!
Ivor Phillips
glastar(at)gmx.net Guest
Posted: Sun Apr 09, 2006 3:29 am Post subject: Air Speed Switch |
DonVS wrote:
Bob,
klehman(at)albedo.net Guest
Posted: Sun Apr 09, 2006 4:46 am Post subject: Air Speed Switch |
Wouldn't a switch on the landing gear be easier and more reliable?
Ken
Dave Morris \"BigD\" wrote:
Quote: |
Why don't you just buy a cheap microswitch and keep sticking larger
and larger surface area on it until it triggers at the desired speed
while it's being hung out the window of your car?
Posted: Sun Apr 09, 2006 7:05 am Post subject: Air Speed Switch |
At 05:38 AM 4/9/2006, you wrote:
Ken
Depending on the geometry of the landing gear it may not be possible,
unless you're talking about dragging a feeler on the ground. And in
that case, no, I think an airspeed switch would be simpler and more reliable.
BobsV35B(at)aol.com Guest
Posted: Sun Apr 09, 2006 8:46 am Post subject: Air Speed Switch |
In a message dated 4/9/2006 1:18:29 A.M. Central Standard Time,
BigD(at)DaveMorris.com writes:
Why don't you just buy a cheap micro switch and keep sticking larger
Dave Morris
Good Morning Dave,
That should work, but if you are going to rely on a plate that is out in the
breeze, it will add drag to the aircraft. If you place a switch in the
pitot system that reacts to the pressure, there will be no additional drag added
to the flying machine.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
psychden(at)sonic.net Guest
Posted: Sun Apr 09, 2006 11:55 am Post subject: Air Speed Switch |
Take a look at the World Magnetics line available thru Digikey at www.designflexswitches.com . There's a new Goldtech line that looks promising for the application. This also looks favorable for a pitot based "squat" switch or a gear warning sensor based on airspeed. The previously available switches were either normally open (PSF102), weren't sensitive below 2" H20 (PSF 103). This new switch appears to be able to handle switching loads for the landing gear solenoid in the application where you would prevent gear retraction for airspeeds below 70 knots (3.159" H20) with the switch in series. I've been waiting for something like this! What do you gurus think? Larry Ford Glasair I RG N149LF
jan.de.jong(at)xs4all.nl Guest
Posted: Sun Apr 09, 2006 12:35 pm Post subject: Air Speed Switch |
World Magnetics would seem to make a useful switch?
See http://dkc3.digikey.com/PDF/T061/1703.pdf
Jan de Jong
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun Apr 09, 2006 12:39 pm Post subject: Air Speed Switch |
Larry Ford wrote:
Quote: | What do you gurus think? Larry Ford Glasair I RG N149LF
I think that I have been annoyed with every kind of landing gear warning
system I have ever used. Piper had their automatic system that put the
gear down when you slowed down and that just about drove everyone nuts.
The only system I have really liked is to do my GUMP check twice: once
on downwind to get all the stuff done and again on final to make sure I
didn't forget anything. If on instruments putting the gear down at the
FAF usually sets my descent rate to the runway.
I know, it's not high tech. OTOH it is KISS.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
lhelming(at)sigecom.net Guest
Posted: Mon Apr 10, 2006 3:45 am Post subject: Air Speed Switch |
Operating temperature range is a problem unless you have a stable
environment to put it in. Larry in Indiana
