scott-p(at)texas.net Guest
Posted: Sun Aug 30, 2009 6:23 pm Post subject: Excessive R Mag Drop |
Hi Guys,
My lovely M9F (okay, "Phi", but I don't have that key on this
keyboard...<VBG>) magnetos (mounted on a Yak-55M) seem to have developed
an issue, and I need some help toubleshooting it. The problem is an
excessive mag drop on the right (#2) mag. Mag checks done between 60%
and 65% yield a 2.5-2.9% drop on the Left mag (#1) and (initially) a
9.5-9.9% drop on the Right (#2). Here is what I have done so far and the
effect:
1) Replaced the plugs (NGK BR7HS gapped at 0.25). No effect. N.B., the
ignition wires are US 8 mm automotive wires and are just over 18 months old.
2) Checked the point gap (and cleaned everything in the top of the mag
with Isopropanol). Gap correct at 0.3 mm. No effect.
3) Reset the distributor rotor to full "aft" (i.e., opposite the
direction of rotation) position. No effect.
4) Reset distributor rotor to mid-position. Decreased drop on Right mag
to about 8.5%.
5) Reset distributor rotor to full "forward" position (i.e., in
direction of rotation). Decreased drop on Right mag to about 7.7-7.9%.
This is the best that I can get. Obviously, this isn't good enough...
Any ideas on what the problem is and (more importantly to me), what the
solution is? Preferably without recourse to "buy a new mag"...
I'm stumped.
Scott Poehlmann
Yak 55M N155YK
Posted: Mon Aug 31, 2009 4:25 am Post subject: Excessive R Mag Drop |
Scott,
A couple of comments based on your post. These comments will most likely not change the mag drop. But I believe are important.
- Mag checks are typically done at 70%, although the large mag drop would most likely not change by doing the mag check at 60-65%.
- The BR7HS plugs are a "colder" plug and I would suggest changing to BR6HS plugs. Gap the new plugs to .21 -.22. We have found the BR6HS plugs to be a much better plug for the M14 than either the BR7's or 8's.
- Rotating the distributor rotor just for the sake of trying to reduce the mag drop is definitely a no-no. You are forcing the rotor point off the center contact of the mag cap ie: making the spark jump the gap. You could be damaging the mag cap. The reason the rotor has slots in it is to enable the mechanic to properly align the position of the rotor to the scribed mark on the boss of the magneto (the mag cover mating surface once the mag timing is properly set). See attached. This positions the rotor point to the center of the contact inside the magneto cap when the mag cap is installed. I would recommend you recheck the timing and after properly setting the timing, reset the rotor by placing a straight edge across the center of the rotor to the rotor point, then loosen the 3 screws and align the center and the point of the rotor to the scribe mark on the boss of the mag.
Since you are getting a large mag drop, you can possibly isolate the faulty cylinder (plug not firing) by running the mag on the BAD mag to see what cylinders are not firing. Start the engine and immediately rotate the mag switch to the #2 mag and leave it there. You said #2 was giving you the large mag drop. Now let it run for a few minutes on the bad mag. Shut the engine down. Using a laser temperature sensor which you can buy at Radio Shack, measure the temperature of each cylinder at exactly the same point on each cylinder. Pick a spot that is easy to "shoot" with the laser. Just make sure you measure the temps at the same location on every cylinder. You will likely find a cylinder that is much colder than the others. That will be the suspect wire/plug. It could also be a small crack in the mag cap between the contact points. Look for carbon traces in the mag cap. Replace the cap for testing purposes. But be sure to align the rotor point to the scribe mark before replacing the cap.
Regarding the mag drop, since you are using the 8 mm wires, you can measure the resistance of the wires from the spark plug end to the mag cap. Starting with the longest wire, (left mag #6; right mag #5) measure the resistance of the wires using a digital ohm meter. The shorter the wire, the less resistance. If you find a bad wire, (no resistance) remove the end from the mag cap, cut off about 3/8", reinstall and screw in the wire-piercing screw. Then check the resistance again. If the wire still reads completely open (no resistance), contact me off-list and I can order you a new wire.
I hope this helps.
Magneto_points_and_fine_timing_adjustments.doc |
244 KB |
264 Time(s) |
william(at)netpros.net Guest
Posted: Mon Aug 31, 2009 6:52 am Post subject: Excessive R Mag Drop |
When I try to do my run up at 70% RPM my brakes won't hold. Details are 400HP, MTV 3 blade prop, and Cleveland 6" wheels/brakes.
Anybody else have that problem? I would think the 440 HP engine makes it even worse ...
Thanks!
William Halverson
YAK55
At 05:24 AM 8/31/2009, A. Dennis Savarese wrote:
[quote]Scott,
- Mag checks are typically done at 70%, although the large mag drop would most likely not change by doing the mag check at 60-65%.[b]
Posted: Mon Aug 31, 2009 7:10 am Post subject: Excessive R Mag Drop |
Good point William. Thanks for sharing that because it is important.
Dennis
dougsappllc(at)gmail.com Guest
Posted: Mon Aug 31, 2009 8:12 am Post subject: Excessive R Mag Drop |
Bill,When we run the big 30 inch tires and the borer super prop on the cubs we have a similar problem. We solved it by using a oil squirt can full of what ever type of brake fluid your fond of, this is the type of oil can with the "squeeze it" handle, squirts across the shop with each pull. (tape a lazer pointer to it and it's wonderful for killing wasps and yellow jackets--messy though) Use a piece of clear plastic tubing big enough to fit tightly over the nozzle, the other end should be just big enough to slip over the bleeder valve on the brake housing,(which should be on the upper side of the housing.) Pump the hose full of fluid to remove the possibilities of any bubbles, slightly loosen the bleeder valve, you should see a slight bit of fluid appear, quickly skip the tube over the bleeder valve taking care not to trap any bubbles in the line. Pump the lever on the oil can until you see the pucks in the brake housing start to move outward. Stop pumping just before the pucks contact the surface of the disc on your Clevelands, pause a moment keeping the clear plastic tube vertical and any air bubbles rise up in the line, next close the bleeder valve, disconnect the hose and your done. It is best to do this when the aircraft is jacked up enough to spin the tires to check for a dragging brake. This is the theory: The brake pucks force the pads out against the disc when the brake is applied, then they retreat to the "at rest" position when the brakes are released. Any wear in the pads or on the disk will require more fluid being needed to make the puck extend and firmly grip the disk than it did when these parts were new, "back pressuring" the brakes replaces this fluid. Note that this will make your brakes "touchy" if you pump them up to much. Give it a try, it just might solve your problem.
Best,
Doug
On Mon, Aug 31, 2009 at 7:48 AM, William Halverson <william(at)netpros.net (william(at)netpros.net)> wrote:
Thanks!
William Halverson
YAK55
| Quote: | Scott,
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
You cannot legislate the poor into prosperity by legislating the wealthy out of prosperity. What one person receives without working for, another person must work for without receiving. The government cannot give to anybody anything that the government does not first take from somebody else. When half of the people get the idea that they do not have to work because the other half is going to take care of them, and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for, that my dear friend, is the beginning of the end of any nation. You cannot multiply wealth by dividing it."*
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
Posted: Mon Aug 31, 2009 7:13 pm Post subject: Excessive R Mag Drop |
Hi Dennis,
Thanks for the usual thorough and thoughtful info. I will do all of your
suggestions. I was under the misapprehension that the slots in the rotor
were to allow for synchronization between the two mags, which led me to
the idea of checking a variety of positions. Hopefully I have not
damaged the caps, although I have only run the engine for a total of
perhaps 15 minutes since varying the rotor position. I will reset it to
the boss mark (which I hopefully can find...) as specified in your
e-mail. Please confirm that it is the CENTER LINE of the rotor (which
has two contacts on it, one in front of the other, separated by perhaps
0.5 cm; thus the center line is between the two contacts...) which is to
be aligned with the scribe mark.
I am going to try the BR6 plugs and see if that fixes the problem, and
will also see if I can identify a "cold" cylinder. Failing that I'll
measure the resistances of the plug wires.
As to doing the run-up at 65%, I was taught this (I think by Nik...)
when I first transitioned into an Su-29 about 7 years ago and frankly
have never given it any thought since then.
Thanks again.
Scott
[quote] Scott,
boss of the mag.
I hope this helps.
jan.mevis(at)informavia.b Guest
Posted: Mon Aug 31, 2009 10:25 pm Post subject: Excessive R Mag Drop |
I had the same problem with my Yak50, MTV prop, M14R with 450 HP. Now with new brake pads, problem is solved. It should be possible to adjust the brake settings though.
Jan
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: maandag 31 augustus 2009 17:06
To: yak-list(at)matronics.com
Subject: Re: Excessive R Mag Drop
Dennis
----- Original Message -----
Sent: Monday, August 31, 2009 9:48 AM
Subject: Re: Yak-List: Excessive R Mag Drop
Thanks!
William Halverson
YAK55
Scott,
- Mag checks are typically done at 70%, although the large mag drop would most likely not change by doing the mag check at 60-65%. | Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List | 4
Posted: Tue Sep 01, 2009 3:40 am Post subject: Excessive R Mag Drop |
Hi Scott,
There are 3 points to line up with the rotor. 1- the center of the rotor; 2- the contact point on the rotor; 3- the scribe mark on the boss of the mag. First set the point gap to .25 to .35 mm or .010-.014. Then check the timing using your timing box or "buzz box", which should be between 14.5 and 16.5 degrees BTDC. Once the timing is set, NOW check the rotor position to make sure the 3 points line up. The leading (rotating counter clockwise) point on the rotor is the one that is used during normal operation. This point should be lined up with the scribe mark when the timing is set. The trailing point is for the starting coil. Finally, when synchronizing the mags, use what I call the "fine" timing adjustment eccentric which I pointed out in the diagram. This eccentric is on the opposite side of the points. Using your timing box connected to both mags, you can tweak one mag to the other using this fine timing adjustment.
I doubt the BR6's will solve the problem. But the engine will run much more efficiently with them.
I believe someone made an excellent post yesterday about doing the run-up at 60-65% on the Yak 55 because the brakes would not hold at 70%. Makes perfect sense to me.
Let me know how you make out.
Dennis
Posted: Tue Sep 01, 2009 7:21 pm Post subject: Excessive R Mag Drop |
Hi Dennis,
Actually, my brakes do hold at 70% (Matco's)... But that didn't fix the
problem. I don't think that the brakes on the Su29 did hold at 70%, so I
suspect that is ultimately the reason for the 60-65%.
I completely reset the mags back to spec as per your description and the
installation task card, and... (drum roll...) drop on the L mag went to
about 1.9% and on the R mag to 8.5%, which is certainly better than
almost 10% but still not quite right. I didn't have the ability to
synchronize between them (no timing box--but I have access to one), but
will try that. I have a temp sensor on the way, and will shoot the
cylinders to make sure all are firing on the R mag, but since the engine
runs smoothly (albeit at a lower rpm) I _doubt_ that I have a bad plug
wire. If synchronizing them doesn't fix the problem, and there aren't
any cold cylinders (and the resistances on the wires all check) then I
am out of ideas and guess I'll need to find a replacement mag.
Thanks for being patient with me...<VBG>
Scott
[quote] Hi Scott,
Dennis
Posted: Wed Sep 02, 2009 3:17 am Post subject: Excessive R Mag Drop |
Hi Scott,
Once you get your hands on the timing box and properly set the timing, then we'll see what the mag drop is. If you have any questions on how to set the timing, contact me off-list or call me and I will try to help.
Dennis
