Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Sun Aug 30, 2009 3:35 pm Post subject: always do your preflight! |
I found this cracked tailwire tang while doing my preflight this morning. It's the one on my left-side vertical tail. I happened to have a fresh new one on hand, so a little bend on the vice and 10 minutes of work and I was good to go.
Prior to this happening, I had been thinking of a possible better way to assemble the Kolb tailwires by copying what is done on a lot of other GA planes in our hanger. They use the solid rods, threaded on both ends, with fork attachments and jam nuts. They also have tangs, but they are thicker than ours. I think I've seen one on a Kolb somewhere, just can't remember whose it was. Seems that would be better, if you never fold/unfold your plane. I have always looked very closely at those tangs on my preflights, looking for signs of a stress crack forming, but I never saw any indications on this one until I found it in this condition this morning. It had to have happened yesterday while I was out flying, because it wasn't there yesterday morning.
Jimmy Y
153.55 KB |
16641 Time(s) |
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
zeprep251(at)aol.com Guest
Posted: Sun Aug 30, 2009 3:54 pm Post subject: always do your preflight! |
Jimmy,
Do you think that failure was caused by air loads or the amount of tension?
G.Aman
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Sun Aug 30, 2009 4:11 pm Post subject: Re: always do your preflight! |
Hi Guys and Gals,
This is what this list is about...keeping everyone safe . Thanks Jimmy!
chris ambrose
m3x/jab/
N327CS
albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Sun Aug 30, 2009 4:36 pm Post subject: Re: always do your preflight! |
Why so many adjacent holes. I would think that would have something to do with the failure.
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
Posted: Sun Aug 30, 2009 5:20 pm Post subject: always do your preflight! |
That is a good point. Although Kolb supplied the original kits with
the multi-hole tangs
because that was the only adjustment (aside from a small one possible
by twisting the cable)
In this case I would fab a plain steel tang with one hole because of
the turnbarrel. (sorry, had to call it by its real name)
BB
On 30, Aug 2009, at 8:36 PM, albertakolbmk3 wrote:
<cheriebraun(at)xplornet.com>
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
http://forums.matronics.com/viewtopic.php?p 60542#260542
Posted: Sun Aug 30, 2009 5:43 pm Post subject: always do your preflight! |
| Quote: | I found this cracked tailwire tang while doing my preflight this morning.
good to go.
> Jimmy Y
Jimmy Y/Gang:
I don't like those multi-hole tangs, especially stainless steel, plus being
bent to fit.
Glad you caught that one.
I have never used that style.
I have used the SS tangs with one hole each end with good success.
My mkIII is equipped with 4130 tangs I made from strap and turn buckles to
adjust the tension.
_________________ John Hauck
Titus, Alabama |
Posted: Sun Aug 30, 2009 5:56 pm Post subject: always do your preflight! |
I'm not Jimmy Y, but I'd like to respond.
My best guess would be vibration and a stress riser where the tang was bent across punched holes in SS. SS is much less stress resistant as 4130.
Jim's photo shows two bends in the tang. One of those bends goes right through the hole that broke. If my old eyes are seeing correctly.
Jimmy,
G.Aman
| [quote][b]
Titus, Alabama |
Posted: Sun Aug 30, 2009 6:10 pm Post subject: always do your preflight! |
| Quote: | the turnbarrel. (sorry, had to call it by its real name)
BB
Bob B:
Isn't the "turnbuckle barrel" one part of the turnbuckle?
The other two parts being a pin or cable fork???
Titus, Alabama |
Posted: Sun Aug 30, 2009 6:41 pm Post subject: always do your preflight! |
The old west coast aviation guys used to call them turnbarrels as do
some UK countries. I just like to call them that
because I don't see a buckle there. I would still call the hardware
store variety a turnbuckle though.
The aeronca C-3 and some others actually used them for lift struts.
I shall now yield to common usage.
I shall also think about a design change on mine, plus closer
preflights until then.
BB
On 30, Aug 2009, at 10:05 PM, John Hauck wrote:
> BB
Bob B:
WhiskeyVictor36(at)aol.co Guest
Posted: Sun Aug 30, 2009 7:12 pm Post subject: always do your preflight! |
In a message dated 8/30/2009 8:38:10 P.M. Eastern Daylight Time, cheriebraun(at)xplornet.com writes:
| Quote: | Why so many adjacent holes. I would think that would have something to do with the failure.
cherie/all
The tang with several holes was designed so as to be able to adjust the length of the cable for proper tension. By moving the bolt from one hole to another, it will either tighten or loosen the cable.
On the tangs with only one hole (at each end of course) they could be adjusted by installing or removing washers placed under the tang. My builders manual mentioned this and suggested installing at least one washer between the tang and the tail surface when being built so if adjustment was needed later it could be done as described.
Bill Varnes
Original Kolb FireStar
Audubon NJ
flykolb(at)pa.net Guest
Posted: Sun Aug 30, 2009 7:50 pm Post subject: always do your preflight! |
Jimmy,
It looks like the clevis end of the turnbuckle may have been pressing on the
tang as there appears to be an indented marking on the tang matching the
curvature of the clevis end. (Sometimes photos are deceiving, but it does
give this appearance.) I don't know if at some point in the life of the
airplane that when the wings were folded the turnbuckle was leveraging the
tang and flexed it ... possibly when folding the tail, the turnbuckle had
some pressure on it and in turn flexed the tang?
I know the tang is not 4130 and there are holes in it - but even still there
is a lot of strength in the tang. I have a hard time thinking that the crack
resulted from tension loads alone.
The tang is designed to replace a turnbuckle and consequently most Kolbs
would not have the turnbuckle. So this is probably a relatively rare set-up
and possibly the turnbuckle and tail folding had something to do with it?
Dennis
Fran Losey
Joined: 21 Feb 2009 Posts: 61 Location: Boca Raton, FL
Posted: Mon Aug 31, 2009 3:24 am Post subject: always do your preflight! |
Has anyone else experienced this?
Do you have a photo of where the failure occurred? I am in process of building, info as you supplied sure tells me to beef up the tangs if this is not an isolated case.
Thanks for sharing this!
_________________ Fran Losey
N62FL (reserved)
loseyf@comcast.net |
Posted: Mon Aug 31, 2009 3:48 am Post subject: always do your preflight! |
Fran C
Did you miss Jimmy's photo link C in his original post C at the bottom of his email?? It has a photo of his broken tang. Scary stuff C BTW!!!
Mike Welch
MkIII
Do you have a photo of where the failure occurred? I am in process of building C info as you supplied sure tells me to beef up the tangs if this is not an isolated case.
With Windows Live C you can organize C edit C and share your photos. Click here.
Posted: Mon Aug 31, 2009 4:05 am Post subject: always do your preflight! |
| Quote: | It looks like the clevis end of the turnbuckle may have been pressing on
the
set-up
Dennis
Dennis/Gang:
You may have something there. Would be easy to side load the tang with the
turnbuckle (turnbarrel for BB) during tail folding and handling.
I use four turnbuckles on my mkIII tail wires. Normally, I do not fold, but
if I do, all the wires come off the tail section first.
Looking at the photo, looks like there may be some scoring/scratching by
wrench or socket around the high temp lock nut in the area of the break.
Doesn't look like there is a washer under the nut either.
If the tail wires were loose in flight, would induce a lot of vibration to
the SS tang.
Another thought from my foggy old mind, the further the bend from the
attaching bolt, the more side load at the bolt. When I make up my tail wire
tangs, I bend them at the edge of the washer under the nut or bolt head to
reduce possibility of side load.
My thoughts prior to my first cup of coffee this morning, as I contemplate
finishing loading and heading to the Rock House, this morning, to harass
Larry Cottrell for a few weeks, along with the jack rabbits, coyotes, and
antelope.
Titus, Alabama |
Posted: Mon Aug 31, 2009 4:06 am Post subject: always do your preflight! |
Fran/Gang:
The url for the photo is at the bottom of Jimmy Y's msg.
This is the first failure of these particular SS tangs that I have knowledge
of. I believe it is an isolated case.
Titus, Alabama |
Jimmy Young
Posted: Mon Aug 31, 2009 4:31 am Post subject: Re: always do your preflight! |
I agree it looks like a combination of the bend being too close to the holes and the weakness caused by the holes being close together that helped get the failure going.
To Dennis' reply, I have not to my knowledge ever folded up the tail causing the turnbarrel to leverage some tension on the tang, but it could have happened with a previous owner. I think the main thing to learn is, regardless of what caused it, the crack developed at the weakest point of the tang where the holes are all close together.
I'm going to locate some SS single hole tangs and wil be replacing the entire tail wire assembly.
Missouri City, TX
Fran Losey
Posted: Mon Aug 31, 2009 4:40 am Post subject: always do your preflight! |
Thanks John, safe journey!
N62FL (reserved)
Posted: Mon Aug 31, 2009 5:20 am Post subject: always do your preflight! |
Jimmy and others with turnbuckles (or barrels),
John mentioned that he was not aware of any such tang failure previously and
I have none either, these are not just used on Kolb, they are extensively in
all sorts of ultralight aircraft. So, logic would seem to indicate that the
that the presence of the turnbuckle is probably related to the failure in
some way.
The tang, I feel certain, is quite strong enough for its intended tensions
loading. So all this to say, make sure you don't replicate a scenario that
would not eliminate the real problem. Any tang will fail if flexed sideways
a sufficient number of times.
I would not put the turnbuckle on the top wires for several reasons:
(A) These are the wires that will get you home when all else would fail. The
bottoms are really along for the ride - the tops carry the downward force on
the horizontal stabilizers. If the top wire support fails, you probably
will not make it home. So keep the failure modes for the top wires as few
as possible. The turnbuckle itself represents several failure modes: (1)
whatever happened to yours (2) the turnbuckle could fail itself (3) there is
an additional connection points/links to come apart(4) the safety wire could
fail if incorrectly done or forgotten (5) the turnbuckle could be
incorrectly assembled with too few threads inserted. These are all
potential failure modes - most not likely - but how likely was your tang
failure when none has failed before?
(B) The upper wires are the longest and therefore subject to the most
in-flight vibration and movement in general and adding mass to these will
likely increase any in-flight vibrations, etc.
I can understand why someone would want them: its more traditional and it
makes adjustment easier. But given all the additional failure modes (and
things to check on preflight). I would not have the turnbuckles on my
airplane.
If you do include turnbuckles and fold your tail, you should consider,
having wire on both sides of the turnbuckle to eliminate any potential
binding, or (remove the bolts thru the stabilizer(s). If you remove the
bolt(s), putting it back may be a challenge - if you fold regularly you
probably don't want to do it this way.
Dennis
Posted: Mon Aug 31, 2009 5:53 am Post subject: always do your preflight! |
Thanks Dennis. Good points to consider. In addition we may want to
look at
the dinky little bolts that do the pass-through. The threads would
be the weak area. -both on the nut and the bolt.
Because of the angle they are in both tension and shear.
The loads on these wires are not great. Vibration and work-hardening
with hours of run time would be the real culprit.
BB
previously and
extensively in
that the
failure in
some way.
tensions
scenario that
sideways
fail. The
force on
probably
as few
modes: (1)
there is
wire could
tang
these will
and it
modes (and
airplane.
remove the
you
Dennis
NeilsenRM(at)comcast.net Guest
Posted: Mon Aug 31, 2009 6:53 am Post subject: always do your preflight! |
Jimmy / All
The turnbuckles add mass to those wires so that if there is any in-flight
vibrations or side loading it would compound the issue. Add to that the V
twin engine that was bolted solid to your engine mount would have added to
the issue by transmitting engine vibrations.
I would suggest you give your plane a very close going over to check for
other vibration related metal fatigue.
Rick Neilsen
Redrive VW Powered MKIIIC
