Charles Heathco
Posted: Sat Aug 29, 2009 2:35 am Post subject: Viton o-rings |
I thought I had the part # someone gave me in reply to my sticking left brake problem, but as sometimes happens It seems to have gotten lost in the shuffel. This is for my RV6A. Can you repeat it pls? Im also going to strongly consider changing to the high temmp fluid. I assume a qt will do the job? Tnaks, Charlie Heathco
Tailgummer(at)AOL.COM Guest
Posted: Sat Aug 29, 2009 5:43 am Post subject: Viton o-rings |
From Randy Lervold's site:
Standard MS replacement O-rings areMS28775-218; 2-218V-75 are the Viton O-rings. Try Ace Seal: http://www.aceseal.com.
The High temp fluid is: . MIL-H-83282. Google Royco 782 or Aeroshell 31.
John D
In a message dated 8/29/2009 3:36:52 A.M. Pacific Daylight Time, cheathco(at)cox.net writes:
| Quote: | I thought I had the part # someone gave me in reply to my sticking left brake problem, but as sometimes happens It seems to have gotten lost in the shuffel. This is for my RV6A. Can you repeat it pls? Im also going to strongly consider changing to the high temmp fluid. I assume a qt will do the job? Tnaks, Charlie Heathco
rv9jim(at)juno.com Guest
Charles Heathco
Posted: Sun Aug 30, 2009 4:38 am Post subject: Viton o-rings |
Ok, thanks a bunch for those numbers. Chalrie
