Firewall fuel shut-off (was: glide ratios)
brian
PostPosted: Thu Apr 06, 2006 12:24 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
A. Dennis Savarese wrote:
<dsavarese(at)elmore.rr.com>
Brian,
On the 52 the emergency air is on the opposite side of the cockpit. Not
chance of messing up there.
A great way to check and see if the fire control/fuel shutoff is
functioning properly without running the engine is to pull the fire
control/fuel shut off back, then turn the primer pump to the left
(system side) and attempt to pressurize the fuel system. After a few
strokes, if the fuel shut off is properly adjusted, it will be virtually
impossible to push the primer pump in. Now move the fuel shut off
forward and pump the primer pump at the same time you are doing this.
The primer pump should now pump normally immediately. If after pulling
the fuel shut off closed and you begin to pump the primer to the system
side and it never feels any different than usual, your fuel shut off arm
and cable are improperly adjusted.
With the firewall fuel shut-off closed you can't pump fuel to the carb.
Makes sense to me.
Brian
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
PostPosted: Thu Apr 06, 2006 1:42 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
But if it won't shut off with the fire control handle at the rear position,
in an emergency you won't be able shut the fuel off to the carb either.
That's why it's a great little test that's easily done.
Dennis
dave(at)davelaird.com
PostPosted: Thu Apr 06, 2006 2:28 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
> Brian,
> cockpit. Not
It's the same on the CJ, Brain said "alternate air", not "emergency
air".
It's the carb heat air, or alternate air, lever that in the CJ is
right next to the fuel cutoff lever...
I was under the impression that yak 50's and Sukhoi's don't have carb
heat/alternate air control....I'm not sure about -52's.
comments?
Dave Laird
N63536 1983 CJ6A "Betty"
Dallas
brian
PostPosted: Thu Apr 06, 2006 2:34 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
position, in an emergency you won't be able shut the fuel off to the
carb either. That's why it's a great little test that's easily done.
Dennis
Oh, I understand why you might want to ensure that it not only turns on
but also shuts off. I bet hardly anyone has tested this on their airplane.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
Brian Lloyd
rogerbyak(at)yahoo.com
PostPosted: Thu Apr 06, 2006 6:37 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
The previous posts got me to questioning.....why do we shut down the CJ engine with the mag switch while we shut down Cessnas with the fuel shut off?
Brian Lloyd <brian-yak(at)lloyd.com> wrote: [quote]--> Yak-List message posted by: Brian Lloyd
--> Yak-List message posted by: "A. Dennis Savarese"
Dennis
Brian Lloyd 361 Catterline Yahoo! Messenger with Voice. [url=http://us.rd.yahoo.com/mail_us/taglines/postman1/*http://us.rd.yahoo.com/evt=39663/*http://voice.yahoo.com]Make PC-to-Phone Calls[/url] to the US (and 30+ countries) for 2¢/min or less.
JOE HOWSE
PostPosted: Thu Apr 06, 2006 7:08 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
We do not shut down the Cessna by shutting off the fuel,
We stop, the engine with the mixture control idle cut-off.
Joe
J.C. HOWSE
viperdoc(at)mindspring.co
PostPosted: Thu Apr 06, 2006 7:22 pm    Post subject: Firewall fuel shut-off (was: glide ratios) Reply with quote
It can be shut down with the fuel cutoff lever. The problem comes when you get ready to light her off for the next flight. You cavitated the fuel pump and it relies to some extent on the fuel passing by the impreller to lubricate it along with probably cooling it to Also your start time is prolonged by the amount of priming you have to do to get enought fuel back into the system to light it off. You will find you are pumping that primer for a while too.
Doc
brian
off?
We don't shut off the spam cans with the fuel shut-off. We shut them off
with the idle cut-off feature of the mixture control.
But shutting off the engine with the firewall fuel shut off should be
pretty quick. I am not sure how good it is for the fuel pump to be
sucking hard against that valve. The fuel in the line should vaporize
with the low pressure but will the fuel line collapse? I am not sure it
is all that good for the fuel system.
Brian Lloyd
