ruruny(at)aol.com Guest
Posted: Mon Aug 24, 2009 6:14 pm Post subject: Weight and balance 701 |
A friend and I are working on a spreadsheet for W&B for my 701. It is attached for your enjoyment
Zenith, on their weight and balance form says the baggage area arm is 1050mm and the weight is 40 lbs.
Does this include the extended baggage area? My baggage area is separated by a cargo net.
Do I measure to the center of each area?
Just finished my oil access panel on the cowl completing construction.
 Download |
| Filename: |
Zenith_Aircraft_STOL_CH701_CG_CALCULATIONS.XLS |
23 KB |
| Downloaded: |
324 Time(s) |
