vk3eka(at)bigpond.net.au Guest
Posted: Mon Aug 17, 2009 4:44 pm Post subject: First Start of an O-200 |
Hi Guys,
I am about to start my rebuilt O-200 for the first time. The Overhaul Manual calls for “Pre-oil the lubrication system using an external pre-oiling pressure system”. I don’t have one. What is the best way to ensure I have oil pressure if the motor magically starts on the first key?
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
ashleyw(at)gvtc.com Guest
Posted: Mon Aug 17, 2009 5:36 pm Post subject: First Start of an O-200 |
Peter,
Do you have an oil filter on the motor?
I unscrewed the filter and pumped oil into the center hole of the filter adaptor. Unless the oil pump is primed (the above procedure will prime the pump) there is a large chance you will not get oil pressure.
I removed the top spark plugs and then used the starter to turn the engine over until oil pressure was indicated. Put the plugs in and you are good to go.
Floyd Wilkes
601XL O-200
Ron Lendon
Posted: Mon Aug 17, 2009 5:38 pm Post subject: Re: First Start of an O-200 |
Prime the oil pump and turn it to pressurize the system. I don't know how to do this on your particular engine.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Posted: Mon Aug 17, 2009 8:12 pm Post subject: First Start of an O-200 |
Floyd,
Did you actually “pump” oil into the center hole or just fill it with an oil can? (If you pumped, did you make up a pump of some sort?)
I have fitted the oil filter adapter so I could get some oil into the oil pump that way.
Peter
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Ashley
Sent: Tuesday, 18 August 2009 11:30 AM
Subject: Re: First Start of an O-200
Peter,
Floyd Wilkes
601XL O-200
n4546v(at)mindspring.com Guest
Hello Peter:
We went through this a couple of months ago when we overhauled the Cont. C-145 engine in our flying club 1958 Cessna 172. Go to www.eaa163.com click on flying club link.
A C-145 is a early version of the O-300 which is really a O-200 with two more cylinders. The cyls. and many parts are identical.
I have a Franklin engine OH manual which says that if you don't have the "pressure pre-oil system" then you remove the top spark plugs and manually turn the engine over via the prop 200 revs.
We tried that on the C-145 and were unsuccessful in getting oil pressure to show. It may work on your O-200. Do you have a tube type oil pressure gauge that senses oil pressure from the engine clear up to the instrument? Do you have an electric starter?
We apparently were not able to get the oil pump to prime by turning the prop by hand. We used the electric starter to spin the engine (spark plugs removed). This finally primed the pump and we had oil pressure indications.
We have a oil filter adapter, but we did not have the advice that you could prime the oil pump back through the filter adapter.
There are three other places to get evidence that the pump is primed and oil is pumping through the engine.
1. If you have the tube type oil pressure gauge, disconnect the oil pressure instrument line where it connects to the firewall bulkhead fitting. When the oil pump starts pumping, oil will squirt out there.
2. Face the front of the engine, look at the engine case on either side of the crank prop flange. On both the left and right, there is a pipe plug on the front of the engine case. These plugs "plug" the front end of the main oil galleries. Loosen, preferable the left plug facing the prop flange, and when oil pressure comes up, oil will come out around this plug.
3. Remove the Rocker arm cover of a front cylinder, when oil pressure comes up, it will travel through the hollow push rods and drip around the rocker shaft, etc.
On our C-145, we used the oil pressure gauge tube and the front galley plug. We already had all the baffles installed making it difficult to remove a valve cover.
Spinning the engine (spark plugs removed) with the electric starter, it didn't take long before oil was spurting out the oil pressure tube, and around the front gallery plug. Both were tightened and we spun the engine once more and oil pressure was indicated on the oil pressure gauge. We had a short meeting on whether there was any reason NOT to start the engine. Couldn't think of a thing. So we fired it off and it's run perfectly for over a hundred flight hours so far.
We also have a first issue Cessna 150 (1959) which is currently in my back yard with a newly OH O-200 hanging on it. It's not ready for sartup yet, but when we do, we will use the above system for pre-oiling.
Let us know how this works out for you.
Randy, Las Vegas
sabrina
Posted: Mon Aug 17, 2009 9:55 pm Post subject: Re: First Start of an O-200 |
Posted: Tue Aug 18, 2009 1:23 am Post subject: First Start of an O-200 |
Peter,
I used a Harbor Freight hand pump ( about $5.00) but I believe if you stick a tube into the oil filter adapter and pour the oil in it should work. You just need to get some oil to the pump. You are only putting oil to the pump which is about 5 inches from the oil filter so not much oil is required. The engine should have been put together with lubrication on the internal parts.
Floyd
Posted: Tue Aug 18, 2009 4:43 am Post subject: First Start of an O-200 |
Thanks Guys (and Gals).
I feel a lot better about the start up now. I did find something on the net from Fram Filters about priming the oil pump.
I did use a lot of lube when I rebuilt the engine so nothing should be dry.
I’ll let you know how it goes.
Cheers
Peter
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Randy L. Thwing
Sent: Tuesday, 18 August 2009 2:05 PM
Hello Peter:
Randy, Las Vegas
z601a(at)anemicaardvark.c Guest
Posted: Tue Aug 18, 2009 5:38 am Post subject: First Start of an O-200 |
When I was an A&P in training, the guy who trained me had me lubricate all the
engine bearings with Lubriplate during assembly. He stated we were doing this
to provide lubricant before the oil system kicked in, and in case we never
built oil pressure.
We (I) have never had a problem as a result of this procedure, although we
never happened to have an oil system that did not built pressure. It is a
critical time, and it is important to monitor the oil pressure very closely.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Posted: Tue Aug 18, 2009 9:35 pm Post subject: First Start of an O-200 |
Hi Guys,
I made up a pressure oiler and fed it into the pressure gauge outlet. I have oil coming out of both the front oil gallery plugs so looks like were good to go. If the weather is OK tomorrow I’ll see if she starts (and has some good oil pressure readings!).
Peter
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of dennis hettrick
Sent: Wednesday, 19 August 2009 12:29 PM
Subject: RE: First Start of an O-200
I used a pressure can set up. I took a plug out I knew was open to oil galleys. I attached a hose from can and used regulator on air hose to pressurize can until the oil flowed. I kept adding pressure [no more than 25 lbs util panel guage read 10 lbs. I left it like this a while then turned prop some hoping to get oil smoothed across bearings. When I started it had pressure in 3 seconds. It worked. This was suggested by old guy who worked on military equpment in Korean war including small planes. dennis
[quote] [b]
planes_by_ken(at)bellsout Guest
Posted: Wed Aug 19, 2009 6:55 am Post subject: First Start of an O-200 |
Spinning up the engine with the plugs removed is a procedure that is
referenced in AC65-12A. This procedure also clears excess oil and
preservatives out of the cylinder. Make sure to ground the magnetos or
plug wires or the mag coil can be damaged. The engine will slow down
quite a bit when the oil pump starts pumping oil. During engine buildup
there is no such thing as too much oil!
Ken Lilja
Posted: Sat Aug 22, 2009 2:21 am Post subject: First Start of an O-200 |
Hi Guys,
I managed a milestone today in starting the engine for the first time. I
made up a pressure oiler and pressurised the system through the oil pressure
gauge output fitting. I also primed the oil pump through the filter housing.
A couple of turns and she was away. Pressure was up in seconds and managed
to get to 40 psi at around 1300rpm.
Not quite as smooth as the Corvair but all is good to go.
Cheers
Peter
Wonthaggi Australia
