tc1917(at)bellsouth.net Guest
Posted: Mon Aug 17, 2009 2:56 am Post subject: clear filters |
My experience has shown there is or was three types of clear glass filters
to which you were speaking. One type has a flat cast or alum stem in the
inside which screws up into the cap. The flat threads in there will quickly
disintegrate and will come apart with vibration. The second is more scare
with more meat and I dont know how well that hangs in. The third and best
has a round threaded hollow rod, chrome plated I think and has holes to wire
tie the filter twister nut to keep it in place. That is the best. Had a
couple of the flat ones come apart if you tighten them much. I always wire
tie the filter inside just in case. Ted Cowan
