Ed Godfrey
Posted: Sat Aug 08, 2009 8:42 am Post subject: Crimpers |
Listers,
Can anyone offer up an opinion as to what would be a good choice of
a crimper for wire terminals? Would like to start with the ring
terminals and then work up to the pins for DB connectors.
Ed Godfrey
40717
Posted: Sat Aug 08, 2009 9:51 am Post subject: Crimpers |
I'd go to http://www.steinair.com/ for things electrical.
Linn
Ed Godfrey wrote:
Listers,
Can anyone offer up an opinion as to what would be a good choice of a
crimper for wire terminals? Would like to start with the ring terminals
Ed Godfrey
40717
rv(at)thelefflers.com Guest
Posted: Sat Aug 08, 2009 10:44 am Post subject: Crimpers |
If you're not in a real hurry, you can usually get a good deal on AMP and
DMC crimpers on Ebay. Just set a firm price when you start bidding.
Occasionally, the bidding goes crazy. It did take me 4-6 weeks to get all
the positioners I needed for the DMC.
You'll want the AMP 59250 Red Blue Certi-Crimp T-Head Hand Crimper for
terminals and the Daniels AFM8 Crimp tool for the DB25s. You can see the
DMC tool and the various positioners on Stein's site. Pictures of both are
on my Kitlog site
(http://www.mykitlog.com/users/display_log.php?user=rleffler&project 60&cat
egory 196&log=46591&row=1)
I was able to pick up both in good condition for about $80 each. There are
crimpers that are less expensive, but these are what most of the
professional shops use.
bob
paul(at)bwbco.com Guest
Posted: Sun Aug 09, 2009 8:57 am Post subject: Crimpers |
Here is a crimper sold by Plane Innovations LLC for $96.00. Call them at
(435) 826-4662
Paul Bowmar
N67KB RV-4
982.08 KB |
3911 Time(s) |
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Mon Aug 10, 2009 4:57 pm Post subject: Re: Crimpers |
Wire crimpers for ring terminals, fast-ons, and the like can be bought from several sources. The important thing is to make sure they are the ratcheting type. The crimper does not release until it gets a full squeeze. These crimpers usually have three different dies on them: red, blue and yellow. This corresponds to the color code on the terminals (wire sizes). Get the best terminals you can (AMP are good) and don't go cheap on the tool.
Connector pins work differently and depend on the type. The advice to check with Stein is a good one.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
