lwinger
Posted: Wed Aug 12, 2009 1:15 pm Post subject: Canopy vents |
What have you used for in-canopy vents? Source info would also help.
Thanks.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Gig Giacona
bryanmmartin
Posted: Wed Aug 12, 2009 2:18 pm Post subject: Canopy vents |
I have a pair of eyeball vents installed in the panel connected to the
NACA vents on the side of the canopy. They help some but didn't
provide enough cooling on hot sunny days. I installed a pair of Vista
Vents from ACS last summer and these work really well. I still have to
prop the canopy open while taxiing. I also have a Koger sunshade
installed that helps shield the cabin from the sun.
On Aug 12, 2009, at 4:15 PM, lwinger wrote:
Thanks.
Larry Winger
Tustin, CA
Fuselage on gear
Canopy nearly complete
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
tigerrick(at)mindspring.c Guest
Posted: Wed Aug 12, 2009 3:37 pm Post subject: Canopy vents |
Hi, Larry.
Rich Vetterli used some really nice, large round vents in his canopy that not only snap out into the airstream, but also covered up a canopy crack quite nicely! I don't have a picture handy in the archive, but I'll keep looking. I think he got them from ACS.
I'm using a pair of the really nice Aveo ball vents that fit neatly right in the outlet of the NACA duct. The 1.75" inch sleeve size is almost a perfect fit, it nests right in without need of much of a shim. A layer or two of gaffer's tape sealed them up well.
Rick Lindstrom
pdn8r(at)yahoo.com Guest
Posted: Wed Aug 12, 2009 3:48 pm Post subject: Canopy vents |
What are y'all using to cut the plexi for the 2.5" hole?
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
jaybannist(at)cs.com Guest
Posted: Wed Aug 12, 2009 4:28 pm Post subject: Canopy vents |
Bill,
I cut the hole with a Dremel. It was fitted with a special Dremel attachment that has a center point and mounts the Dremel and cutter at a specific radius (Dremel part no. 678-01 Circle Cutter & Straight Edge Guide) The cutter was a tiny drum with spiral cutting edges. I think the cutter is bit no. 194. Worked like a charm !
I used this same bit to do a whole lot of detailed aluminum cutting. It will also work on thin steel, but wears out rather quickly.
Jay Bannister
leo.gates
Posted: Wed Aug 12, 2009 4:33 pm Post subject: Canopy vents |
Larry,
I used two Plastic Eyeball Air Vents from ACS, $17.95 each in gray,
black, white or beige. These are connected to NACA vents on the side of
the fuselage, per ZAC, and connected via scat tubing. I installed a 120
mm square 12 volt muffin/exhaust fan, with a metal finger guard on the
rear of the baggage compartment. The muffin fan is p/n
707-GDA1238-12BB, cost is $20.12, Finger Guard is p/n 5912-LZ30, cost
$5.55 from Mouser Electronics, www.mouser.com.
I live in South Texas, 20 miles from San Antonio, so have several HOT
summers proof of concept experience.
Before engine start, canopy closed, turn on muffin/exhaust fan and point
left eye ball vent at my face. Slight breeze. Start engine, air is
now blowing nicely on my face/upper body. The air blowing on my face is
probably 95 - 100 degrees but it still cools. End of climb check list
has: Turn off exhaust fan. Before landing checklist has: Turn on
exhaust fan.
Leo Gates
N601Z
CH601HDS TDO
lwinger wrote:
Thanks.
Larry Winger
Tustin, CA
Fuselage on gear
Posted: Wed Aug 12, 2009 4:36 pm Post subject: Canopy vents |
Rich used a standard hole saw gently turned (slowly) by hand on warmed up plex, attacking it from both sides. It took awhile, but the results were pretty good.
Rick Lindstrom
bryanmmartin
Posted: Wed Aug 12, 2009 5:57 pm Post subject: Canopy vents |
I used a circle cutter like this: http://www.amazon.com/General-Hardware-1-3-Hole-Cutter/dp/B00004T7P1
These are also available at Home depot and Aircraft Spruce.
I have it chucked into a hand brace and turned it very carefully. I
started on one side of the plexiglas and cut part way through and
switched to the other side to finish it off. I did this on a warm day.
On Aug 12, 2009, at 6:44 PM, Bill Pagan wrote:
| Quote: | What are y'all using to cut the plexi for the 2.5" hole?
Bill Pagan
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
Posted: Wed Aug 12, 2009 7:43 pm Post subject: Canopy vents |
I saw Doug Dugger of Quality Sport Planes do the same in his XL canopy with the snap vent (). He lubes the cutter with WD-40 as I recall. Spruce p/n CC3251 or 05-01179.
-- Craig
lwinger
Posted: Wed Aug 12, 2009 8:04 pm Post subject: Re: Canopy vents |
Thanks for all the great input and practical ideas!
Tustin, CA
