intercom ground loop?
rv8ch
PostPosted: Tue Apr 04, 2006 11:56 am    Post subject: intercom ground loop? Reply with quote
My flightcom 403 intercom has a ground wire, and the
case itself is grounded. Will I be creating a ground
loop if the case itself is grounded to the airframe
via the panel? Should I try to isolate the intercom
from the panel?
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
nuckollsr(at)cox.net
PostPosted: Wed Apr 05, 2006 5:36 am    Post subject: intercom ground loop? Reply with quote
At 09:52 PM 4/4/2006 +0200, you wrote:
<mick-matronics(at)rv8.ch>
from the panel?
No way to know right now. Depending on how the intercom
is wired within, the possibility of a ground loop exists.
Wait until you've flown the airplane and see what turns
up. Your astute observation and consideration of the
possibilities will point to potential remedies if something
pops up.
< with experiment. >
< --Lawrence M. Krauss >
