nuckollsr(at)cox.net Guest
Posted: Tue Apr 04, 2006 11:03 am Post subject: Why use starter contactor? |
At 11:18 AM 1/27/2006 -0600, you wrote:
Quote: |
<BigD(at)DaveMorris.com>
At 09:59 AM 1/27/2006, you wrote:
>If you
>get in a crash and the engine is ripped off, I don't think the battery
>cable will be you only problem. George
It may not be, but it could mean the difference between walking away doused
in gasoline, and walking away on fire, hoping somebody can get to you
quickly enough to put out the flames.
This happened to a friend of mine who would have walked away from a crash
if it had not been for that one little spark. I'm putting a starter
contactor on the firewall to absolutely shut off any possibility of the fat
wire going to the starter chafing against baffling material or anything
else in the event the engine decides to leave its normal upright, and
locked position.
What's a few bucks, guys? My experience with this friend of mine has made
me a believer in steel braided fuel hose, Earl's fittings, Nomex clothing,
and a lot of other things that may cost a few dollars extra, but could
avoid years of skin graft surgery.
The external contactor has nothing to do with crash safety.
We recommended an external starter contactor for use with
ALL starters having modern automotive style contactor/engagement
solenoids. This policy was adopted by B&C from day-one in spite
of the fact that their new light-weight offering already had
a "useful" contactor built in. The reasoning was based on starter's
need for a low impedance path between battery and the solenoid winding
for energetic engagement of pinion gear and max performance closure
of the built in contactor mechanism. The reason for this is explained
at:
http://aeroelectric.com/articles/strtctr.pdf
The external contactor recommended is MUCH less abusive of the starter
switch. Failure of many starter manufacturers to recognize this stress
is root cause of premature failures of the ACS off-l-r-both-start
ignition switch of some years back when an AD was issued to replenish
the start switch contacts within the switch and to add a diode across
the switch to mitigate inductive effects for breaking the circuit.
The original AD placed the diode in the wrong place as I've described
in . . .
http://aeroelectric.com/articles/spikecatcher.pdf
A later edition of the AD corrected the error and repositioned the
diode. The diode only mitigates the switch-break-spike condition,
not the switch-make-inrush condition. The larger than usual inrush
is still present and is still a life limiting effect on the ACS or
any other style switch.
When PM starters came along, the wiring techniques recommended by
B&C and the 'Connection were not compatible with starter motors which
generated strong energies during wind-down and caused undesirable
delays in pinion gear engagement.
This is what prompted Figure Z-22 of
http://aeroelectric.com/articles/Rev11/AppZ_R11F.pdf
where a boost relay is used to relived panel mounted starter switches
of the stresses cited. Reasoning was that I'd much rather replace a
$5 relay under the cowl than ANY switch on the panel, especially
an off-l-r-both-start keyswitch.
I'll stand by the recommendations for wiring as show in either
Z-22 (boost relay) or any other Z-figure where and external
contactor is shown. It's a system performance, service life
and cost of ownership consideration.
Here's an excerpt from an earlier post . . .
I am designing my electrical system very similar to Z-11 with the exception
of the essential bus and a keyed starter. My new Lycoming engine came
with an SkyTec starter so I assume I'll need to use a relay as shown in
Z-14. Does this mean I don't need a starter contactor? Does this relay
replace the contactor or is it additional to it? Thanks
Matt
A problem arises when the starter utilizes a permanent
magnet motor. These motors are also efficient generators
During spin-down of the motor after the starter
is de-energized, the motor puts out a substantial amount
of power sufficient to KEEP the pinion gear solenoid
ENGAGED for several seconds after you release the pushbutton.
The technique described in our wiring diagrams was
developed as a compromise between maintaining good
starter solenoid/contactor performance with a variety
of starter switches.
Problems with the philosophy didn't arise until the
permanent magnet motor showed up. Again, we sought
a solution that maintained performance of the starter's
built in solenoid/contactor system that did not
transfer the system's unique loads to the circuitry
that controls the starter. Hence, the "boost" relay
described in Figure Z-22.
One COULD choose to use the boost relay with ANY
of the modern, lightweight starters that feature
electro-mechanically engaged pinion gears. This
would move the ideal alternator b-lead feedpoint
from a contactor on the firewall down to the
main power terminal of the starter solenoid/
contactor assembly.
gmcjetpilot(at)yahoo.com Guest
Posted: Thu Apr 06, 2006 4:58 am Post subject: Why use starter contactor? |
Quote: | From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
>"The external contactor has nothing to do with
Bob, this was posted back in January. You must be bored.
First, no one said the crash safety was the ONLY
reason for having an extra starter contactor/relay
on the firewall. However its clearly a concern for
many people. I know because I asked. Personally
I don't think its an issue but understand and respect
those who do think its a concern.
From the electrical design standpoint, everyone
understands that the possible 30 amp inrush
current (6 amp continuous) requires a switch capable
of this. PERIOD, END-O-STORY. Put a 30 amp
push button switch on. Done.
A big 750 amp relay is overkill and not needed to
switch the starter's on board solenoid. I don't get
it. You make it sound as if a big secondary relay
is needed. Its like you are selling them or have
stock in the relay company or something?
Its a throw back to old Bendix style starters that
needed this device. Its time to think out of the box.
Consider modern wiring to match a modern starter.
Bob I know you only focus on electrical but I can
tell you weight is critical on a planes. You tend to
never say NO to a pound of weight if its part of
the electrical system.
There is a very simple solution; get a momentary
single pole push button switch with a 30 amp or
greater capacity as a start switch, which is easy:
A few of many choices:
http://www.reddenmarine.com/site/new-detail.cfm?id=CHRM626BP
http://www.reddenmarine.com/site/new-detail.cfm?id=CHRM490BP
http://tinyurl.com/g5r3p
If you want to use a small tiny (low amp rating)
push button and a small light 30-40 amp relay.
You can buy them, 5 for $10 on eBay.
http://www.chiefent.com/products/product_details.asp?id=3
Quote: | We recommended an external starter contactor for
use with ALL starters having modern automotive
style contactor/engagement solenoids. This
POLICY was adopted by B&C from day-one in spite
already had a "useful" contactor built in. The
reasoning was based on starter's need for a low
winding for energetic engagement of pinion gear
and max performance closure of the built in
Bob, all the conversation about impedance and key
switches is faulty logic and clouds the issue. Instead
of the *Non sequiturs*, get to the facts. Who cares
what B&C's policy is. What does that matter? You
say it like B&C is the center of the universe.
(non sequiturs = fallacy in logic, not necessarily wrong
just conclusion does not follow from the premise.)
http://en.wikipedia.org/wiki/Non_sequitur_%28logic%29
The starter is DESIGNED to work with a starter switch
or switch & (small) relay. Its a good alternative, option to
a BIG FAT firewall relay of the olden days.
There's no other real good reason for using a 750 amp
relay, other than you don't want a Hot Bat/Starter feed,
which is no big deal (according to Bob).
Just install a $12.00 switch capable of 30 amps or a
relay of 30-40 amp capacity. Use 14 awg wire.
The BIG old FAT 750 amp starter relay is an enigma
with today's modern starters with solenoids. Now if
you are uncomfortable with a hot battery cable, than
by all means keep the 750 amp relay and all the extra
connections, weight, cost, but don't do it for any other
reason than you don't like the hot Bat / Starter feed.
Start switches (+30 amp) are cheap and easy to find.
Here are some wiring diagrams that show what I mean.
-No Relay/Contactor wiring:
http://img16.imageshack.us/img16/1963/norelaysalt4qo.jpg
(optional big fuse shown. I would go the next fuse
size up, 400 amps, since PM starters can draw over
300 amps. Bussmann makes fuses up to 750 amp.)
-Traditional, with both master and starter relay:
http://img116.imageshack.us/img116/3039/altwiring5cm.jpg
(Not bad, works, nothing wrong with it, but two heavy
relays, (4) connections, weight and complication. Plus
if you ask me they relays are a big "spark" hazzard.)
Bob, you talk abut key switches of cars and planes
going bad? So what. The whole system needs to be
designed to work with these "modern starters". Here
is how Toyota (and most car makers) does it:
http://www.autoshop101.com/forms/h7.pdf
(Note: Toyota key switch uses a small start relay)
You point to some switch failure on a car or key
switch as proof of WHAT? Thats silly logic. You
make these verbose platitudes as evidence to
support your opinion. The solution is easy.
You make simple simple simple DC circuits
sound so hard. Its a switch and a coil, no biggie.
I am ready for Bob to hurl insults at me and tell
me how I don't understand and uninformed I am.
I would respectfully say Bob's way is fine, but his
reasons are obtuse and not relevant. Don't be
alarmed at Bob's reply, I am use to it and ignore
it.
Bob is right; I'm wrong. I would never dream of
arguing with him, since he has an uncanny way
of always being right. I am just saying there is
another way to consider.
I don't feel a need to argue and make large
stretches of logic and exaggerate to make my
point. Take it or leave it. I am not using big
separate firewall contactors/relays/solenoids.
One $12.00 push switch (start) and a small
solid state relay (master relay), replaces over
a pound of weight and several large connections.
With the no firewall starter relay the battery cable
goes direct to the starter, just like a car. No
extra relays to fail, no extra connections, less
weight, cost and better reliability.
Note:
Bob N is what you call an Expert, so his way is
always the best way, of course.
As far as NOT using a big firewall starter relay
safety its not issue (according to Bob).
I agree with the Expert.
Using a quality 2 awg Bat to starter cable/wire,
well routed, well supported and well protected, the
chance of sparks is small.
However each to their own.
BTW
With a HOT Bat/starter feed, the chance of it
causing a spark is nill. Also with the optional
fuse its protect it from hard dead short, but the
fuse is not needed, just an option.
Think about the firewall relays, with all those
BIG brass jump straps (un-shilded). They are
a spark hazard. There is no fusing between battery
and structure. Many people have fuel gascolators
and prime lines right next to their firewall relay!
Cheers George
DISCLAIMER: All comments are my opinion and
based on common wiring practices used in millions of
cars. However I am not an expert, nor have I written
a book on wiring so please feel free to ignore my advice,
which is provided for entertainment purposes only. Any
attempt at using this info otherwise is at your own risk.
If you agree, disagree or just want to call me names,
feel free to write me direct off list. Thanks
Posted: Thu Apr 06, 2006 8:21 am Post subject: Why use starter contactor? |
>crash safety."
If you're going to be a teacher, you have to expect
and accept the task of covering the same ground
over and over with every new class. Else why would
we need teachers? Just hand out text books, conduct
tests every few weeks and look at all the money
we would save. No teachers, no classrooms, shucks
we could get rid of whole universities. What a deal!
Never said that. That WAS the rationale for the extra
contactor when the thread started. You read things
into people's words that are not there.
Quote: | Put a 30 amp push button switch on. Done.
But suppose the builder wants to use his key-switch?
How about the guy who wants the starter button
on his stick grip (that's where many helicopters
put it)? I guess one might consider Z-22 as an
alternative to the extra contactor as I've written
many times.
A 30A push button is 'modern'? We had one on our
Fordson tractor when I was a kid . . . Cars have
migrated to Z-22 like features. We airplane designers
can do it too.
That's not true. I've never tossed weight out of
the mix of ingredients for design goals. But
consider this. 20 years ago OBAM aircraft were
bolting pig starters, rino alternators and big-dog
flooded batteries into their airplanes but getting
the same fat grins on their faces the first time
their projects broke ground.
Now we have alternatives that have reduced empty
weights of the same airplanes by as much as 30
pounds with improved performance. It's all a part of design
goals. If you worked for Burt Rutan, he might just
have you just hang two wires out to touch together
to get the engine started. His empty weight had
a 6x multiplier on it for gross weight at takeoff
for going around the world.
I've suggested welding cable in lieu of 22759
as low cost and a joy to work with but at some
sacrifice of the 30# savings cited. I've suggested
that one might consider rotating a 15# main battery
into an aux battery slot for a total weight of 30#
of batteries as a low cost of ownership alterative
to one big and one little battery. Your suggestion
that I'm hard over about squandering that 30# savings
is false on the face of it.
I cite B&C because it's the venue under which
I gained my earliest experiences with the OBAM
aircraft industry. I've often cited Electromech
too because it was my university of hard knocks
in the certified world. George, you read far too
much into what I say. If it distresses you so much
to have me mention my various employers, I'll try to
avoid the practice.
You've acknowledged the starter control loop
impedance issue by your own recommendation of
a 14AWG wire . . . how was my citation of the
concern "faulty" or an obscuration of the
facts?
Yeah, that was the DESIRE of the designers but after
a few years in the field, many of the automobiles
that incorporated the new two-stage contactors
were burning up starter switch contacts just as
described in the AD against the ACS key-switch.
The start switch wasn't going to change so they
did exactly what's described in Z-22 and added
the relay.
Is it a 'big deal'? How? The battery contactor is
tasked with making the airplane max-cold in a pre-
crash condition. I've never even considered making
the starter feed a component of crash safety analysis.
It's truly not a big deal but not because of anything
I said about it. It's the WAY THINGS ARE in airplanes
because they have battery master contactors.
Some folks on the List have advocated wiring
airplanes just like cars and dumping the battery
master contactor idea completely . . . don't recall
now who was championing that architecture. That
idea WOULD raise new concerns for configuring an
electrical system for landing on unfriendly terrain.
Interesting. Fusing the starter feed line is a new
concept for light aircraft. I've never seen this done before.
Can you elaborate on the supporting simple-ideas that
support this feature? What new hazards have been deduced
to suggest this ADDED WEIGHT and cost is a useful
thing to do?
Hmmm . . . explosion hazard. That's a new one. Perhaps
we should consider flame arresters on our exhaust
stacks? How about the contactor built into the starter
itself? You know those brushes in the starter really
spark good too. Perhaps some beads of RTV around
all the seams for DIY hermetic sealing? May we assume
that both WEIGHT and SPARKS are now decision drivers?
Where have I argued with that? George, the 'Connection
is loaded with alternatives. You've painted my words
as if I'm trying to drive folks toward singular
goals. If that were true, the 'Connection could be
replaced with a single drawing, a bill of materials
and I could rant about how folks are not following
MY recommendations by not using MY design. The 'Connection
is a shopping mall of designs. As a teacher I'm obligated to
consider every alternative that comes to light
and explain the simple-ideas that help a builder
choose the most attractive direction that fits
his/her desires and mission.
Yes, we know sir. In Failure Mode Effects Analysis
according to George, failures of parts are not proof
of anything. You've said that puffed up batteries,
smoked radios and burned wires are not good indicators
of a runaway alternator - these are all 'unsubstantiated'
stories. Stories cited only to support my wild-eyed notions
that no piece of electronics is perfect and that some
items hold the keys to severe consequences worthy of
consideration in the FMEA. I must continue to beg your
indulgence for my alternate reality.
Quote: | Thats silly logic.
. . . hmmmm . . . should I be insulted here?
Was that intended to be an insult or was it
just a considered observation? Let's see . . . what
adjective might I use to describe your position
on OV failures in the field that won't insult you.
I'll have to think about it.
Please cite any insult I've hurled at you or
anyone else . . .
it.
George, allow me to be really alarming here and suggest
that you've accurately described an alternative design
goal that's been illustrated and explained in my writings
for years.
Note:
Are you being insulting here George? I can't tell.
Are we being teachers here or is this a script
for a Mythbusters show?
>crash safety."
"To each their own?" I thought the thrust of
your missive was to explain the silliness of my
logic and that a savings of under a pound of weight
is an overriding concern. However, you seem to suggest
that when all is said, what anyone does is a matter of
comfort. Help us understand your recommendations.
Quote: |
BTW With a HOT Bat/starter feed, the chance of it
Under what design considerations would you say the
fuse is a good option? Are there other locations
where adding some fuses is a good or better option?
If you're going to toss that idea on the table sir,
please be a teacher and explain when and why it makes
sense and what hazard condition is being mitigated.
Have you ever seen how much "sparking" can be generated
downstream of a 300A current limiter without opening
the limiter? I'm having trouble understanding when
the 'option' would be deemed useful.
Let us 'think' also that we sit between at least two tanks
filled with gallons of fuel plumbed with dozens of fittings
and moved with pumps that put lots of pressure on
a flammable liquid. May I suggest these are part-n-parcel
of systems design and integration were selection of materials
and techniques reduce risks?
You've accused me of being trivial with respect to starter
switch selection. Please consider that my suggestions
allow the design goal of using of ANY starter switch (key,
toggle, push-button, etc.).
I DO confess to adding between 0.2 and 0.9 pounds to the airplane
depending on whether the builder uses Z-22 or the external
contactor. But if you're going to add the ANL limiter for
about 0.5 pounds more, perhaps the drive to save weight by not
having an external contactor becomes even less significant.
You have tossed lack of explosion proofing and new current limiters
into the discussion. Are you suggesting these are useful points of
consideration for our airplane building brothers?
Cheers to you too George, and please know that no
words I've written were intended to insult or demean.
We're only trying to understand . . . I've explained the
rationale behind the external contactor recommendation
and 'fessed up to the added weight for this and MANY
other system features we've discussed for years.
The best understanding I have of your present missive is that
I'm perhaps 0.4 pounds heavier than your recommendations
when the builder opts for the ANL limiter.
I will suggest that your design recommendation for
a fat starter push button is restrictive compared to what
I've suggested in the 'Connection and here on the List.
However, if the builder is shaving ounces and buys into the
appropriately sized, independent starter button, then your
recommendations are spot on. But I'll have to think about those
sparks some more.
Hmmmm . . . for ounce shavers, keep in mind that moving an
under-the-cowl starter contactor from firewall out to the
starter will, on airplanes with rear mounted batteries,
add ounces of wire for the bus feeders that used to
tie onto the firewall starter contactor. Gee, every decision
has so many consequences to consider! Kinda makes one's head
feel tight.
rvbuilder(at)sausen.net Guest
Posted: Thu Apr 06, 2006 12:35 pm Post subject: Why use starter contactor? |
Outside of the usual bickering between you two, I have to say that George has added one of the most useful pieces of information I have personally seen in weeks, even if Bob did glaze over it below. The idea of replacing the big and heavy starter relay with a very reliable Bosch style for 1/5th the price and weight is an excellent idea when going with a starter that already has a solenoid to handle the heavy lifting.
I'm a simple guy that doesn't need a Unified Theory to understand risks and benefits. So let's keep the rhetoric out guys, the explanations concise and straight forward, and I think everyone will benefit all the more.
Michael Sausen
-10 #352 Fuselage
rdunhamtn(at)hotmail.com Guest
klehman(at)albedo.net Guest
Posted: Thu Apr 06, 2006 2:58 pm Post subject: Why use starter contactor? |
Possibly because the pros and cons of that have been discussed at length
several times here Michael. Several folks related experiences with stuck
on automotive starters when I've brought up the subject. Nevertheless I
went with a 25 amp rated marine key starter switch which I believe is
less likely to cause problems than an additional small relay. A cheap 40
amp relay is not imune from sticking either in this kind of service. Got
to admit though my key switch will be a bear to change out compared to a
contactor or a small relay when/if it ever fails, and it cost more than
either.
Ken
Posted: Fri Apr 07, 2006 7:42 am Post subject: Why use starter contactor? |
Quote: | From: Ken <klehman(at)albedo.net>
Subject: Re: Why use starter contactor?
>amp relay is not immune from sticking either in this kind of service. Got
>either.
>Ken
Ken:
Thanks for the thoughtful reply.
My postulation is if you use a BIG FAT start button and no extra firewall relay/
solenoids/contactors, chance of starter run-on / spontaneous engagement is nil.
Has this happened in a car you know of? To the config I suggest in a plane?
Your comment about *several folks* who claim they had problems is great, but
with out details its like the OV alternator thing, just rumor or irrelevant.
There are reasons a starter can run-on. I suspect you are either talking a
old Bendix drive starters or OLD firewall Cessna or Piper firewall solenoids,
which do stick when they get old. Neither apply to our conversation.
People who switched to new starters have got run-ons because the OLD firewall
solenoid was retained and stuck; its NOT an issue of the starter itself.
This supports my claim that LESS IS MORE. Get rid of that old solenoid and
get a big 60 amp start button.
I researched this thoroughly. I talked to SkyTec. The chance of sticking starter
is next to nothing. I also asked about the no secondary solenoid and guess
what? They said its made that way and will work fine. Let's say you did get
a run-on, it would be during start, you would shut down. SkyTec shows how
to wire a run-on light if you like. Chance of it engaging in flight? never.
Skytec has more starters flying than anyone. I think they know what's up.
QUOTE:
What about the Bendix? Maybe it stuck?
**Since Sky-Tec starters do not use mechanical Bendix drives to actuate the
starter, this is actually nearly impossible for a Sky-Tec starter to keep itself
engaged with the aircraft ring gear. Sky-Tec starters are electromechanically
engaged therefore requiring voltage to engage the starter's drive pinion gear with
the ring gear. Without voltage, the pinion simply cannot remain in the flywheel.
A spring and a helical return will both force the drive pinion back out of the ring
gear and into the rest position.**
Ref: http://www.skytecair.com/Cessna_Solenoids.htm
Cessna (mostly) and Piper, apparently have a history of Firewall Solenoids
sticking, so actually even a factory solenoid (relay) can stick. That is WHY
I suggest a big OLD fat start button, like a race car. (w/ catch diode of course)
All the $60,000-$200,000 Luxury and Sport cars are going to no key push
button start switches.
Here is some other good info from SkyTec:
Troubleshooting Diagram: guide to Gen & spacific (to run on) issues:
http://www.skytecair.com/Troubleshooting.htm
Here is two wiring diagrams from SkyTec:
http://www.skytecair.com/Wiring_diag.htm
Here is a guide to wiring, with specifics to starters:
http://www.skytecair.com/Wiring_Experimental.pdf
To be fair to Bob, if it ain't broke don't fix it. Nothing WRONG with the
Z diagram xyz, just suggesting if you want a lean mean electrical system
with more than adequate or even superior reliability and safety, while
lowering weight and complexity, consider trashing the BIG fw contactor.
The next step is get rid of the BIG master contactor. You only need a
30-60 amp relay if you don't run the starter load through it.
Cheers George
altoq(at)cebridge.net Guest
Posted: Fri Apr 07, 2006 1:51 pm Post subject: Why use starter contactor? |
TWIMC (Which is probaly only me),
(1) Electrial Solenoid engaged starters,as used on Lycoming, Chevrolet,BMW,
and Porsche, do stick.
(2) Solenoid engaged starters are disengaged by a spring and an over running
mechanism in the starter gear.
(3) I have personally seen three out of the four named, stick .
(4) They stick and continue to crank the engine, they stick and don't crank
the engine, and all modes of stick in between.
(5) They stick when they are new or old, clean or dirty but mostly they
stick because they are misaligned or have not been lubricated.
(6) One of these starters that fail in the "CRANK the engine mode" with the
+12VDC wired directly to the solenoid has a great big wire as big around as
your index finger HOT and you can't turn it off.
(7) There are many light weight relays capable of eliminating this problem
by attaching the +12VDC first to it and then on to the starter solenoid. No
device that controls the starter directly through its solenoid control
circuit can do this.
( I have had multiple experiences with these type failures. Allow me to
pass these experiences on to you and eliminate the time and aggravation it
would take for you to accumulate them yourself. Use the information as you
will.
(9) DO NOT ARCHIVE
John D.
Posted: Fri Apr 07, 2006 1:53 pm Post subject: Why use starter contactor? |
length
stuck
Nevertheless I
cheap 40
service. Got
compared to a
than
>either.
>Ken
Ken:
firewall relay/
nil.
great, but
Wasn't rumor. Had many customers report the phenomenon and we demonstrated
it on the bench . . .
Nope, we were talking about modern PM starters . . .
firewall
Not so. "Run on" in the context of PM starters and airplanes had
nothing to do with the selection of contactors.
Unlike wound-field motors supplied on B&C (and perhaps other)
starters, the PM offerings by Skytec (and perhaps others) are
efficient GENERATORS of electrical power while the armatures are
spinning down. When the pilot releases the starter button after
the engine fires, connection between the starter motor and battery
was being opened just fine. However, IF the starter was wired for
external contactor, voltage being generated by the coasting armature
was still applied to the solenoid engagement windings thus keeping
the pinion gear engaged for some period of time (perhaps 2-5 seconds)
after the button was released. The starter's overrun clutch prevented
damage but it was obviously an undesirable operating quality.
One fix was to go to Figure Z-22 such that the starter's built
in contactor became the primary electrical switching device. The relay
allowed any starter switch selected by the builder to stay in place.
Adding the relay broke power to the solenoid's hold-coil and effected
immediate release of the pinion gear in spite of the armature's
spin-down voltage. Another option was described in October of 2004
when this sketch was published on my website:
http://www.aeroelectric.com/articles/StarterWiring.pdf
Figure 3 suggests using the "I" terminal of the external contactor
to exert absolute control over the solenoid's hold coil.
Of course, the forth options is Figure 1, a 30A push button and
14AWG wire to replace the relay shown in Z-22 for what has been
described as the simplest approach. This approach is also electrically
acceptable but offers the least number of options for selection
of start switches. The "run-on" or delayed disengagement phenomenon
is unique to PM starters and has nothing to do with sticking contactors.
starter
is next to nothing.
But not zero . . .
Yup, ask them about sticking contactors and they can accurately
report no big problems as will every other starter manufacturer.
Ask them about delayed disengagement or run-on of their starters
when wired like B&C starters, and they'll confirm what I've stated
above.
No rumors, hard repeatable experiments.
itself
electromechanically
gear with
flywheel.
the ring
This is true of every brand of starter using direct engagement of the
pinion gear by a solenoid that also happens to drive a set of contacts for
control of armature current.
course)
The sticking contactors on production airplanes is a well known
phenomenon when OEM's were using the intermittent duty versions
of the RBM/White-Rogers/Stancore contactors. These looked
just like the battery contactor shown at:
http://www.aeroelectric.com/Pictures/Contactors/s701-1.jpg
These contactors had large area, low pressure contacts
like:
http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg
http://www.aeroelectric.com/Pictures/Contactors/S701-1b.jpg
. . . not the best way to control high inrush devices like
starters. In later years, the car guys showed us small-area,
high-pressure intermittent duty contactors like:
http://www.aeroelectric.com/Pictures/Contactors/s702-1l.jpg
http://www.aeroelectric.com/Pictures/Contactors/S702-1a.jpg
Contactor sticking was virtually eliminated for systems
where the battery was kept in good shape. The only cases
we've seen where an owner was able to weld a small-area,
high-pressure contactor was with a soggy battery that
barely managed to get the contactor closed but with
insufficient pressure to get good conduction, hence burned
and welded contacts.
We've seen starters wired with the big fat push button
(or Z-22 relay) weld the built-in contacts too. If the
battery is soggy or the engagement signal to the contactor
is tentative, welding risks go up markedly IRRESPECTIVE of
who's contactor is doing what to who's starter. I've had
several builders report this phenomenon where rapping the
contactor housing on the side of the starter with a
screwdriver handle would cause it to become unstuck.
To be fair to me or anyone else, we need to be talking about
the same problem. The run-on problem described was identified
in a timely manner, demonstrated, explained, and fixed. It
had nothing to do with sticking contactors and was unique to
PM starters.
The sticking contactors of an earlier design was tolerated for
decades (from about 1946 through the mid 70's) because when a starter
contactor did stick, it was backed up by the battery master contactor.
While every airplane using the old style starter contactor suffered
the phenomenon, it wasn't a big deal. When the automotive designers
crafted the high-pressure design, it was welcomed by all.
Quote: | The next step is get rid of the BIG master contactor. You only need a
Anyone is completely free to get rid of any parts they wish
and indeed many builders have done just that. The only thing
I'll suggest is that the decisions to do so exploit
the experience and thought processes behind 60+ years
aircraft electrical systems. An accurate sense of history
combined with an understanding of applicable simple-ideas helps us avoid
potentially unhappy and unintended consequences of "the next step."
If you're ready to hang your hat on an always hot, fat
feeder from battery to starter mounted contactor/solenoid,
keep in mind that the starter's built-in contactor can stick
too. Further, you loose pilot control over making the airplane's
electrical system max-cold. If those design goals are acceptable
then so be it. It's your airplane and it's experimental.
Fly in peace.
Posted: Fri Apr 07, 2006 2:08 pm Post subject: Why use starter contactor? |
John,
Thank you for sharing this info. It tracks with what we understand
about the huge list of variables that affect starter and associated
contactor performance. Bottom line is that ALL starters of ANY brand
are subject to undesirable behavior for a host of reasons. None
of these events needs to be more than a frustrating maintenance item
if we leave certain "Plan-B" options in place for dealing with them
if and when they arise.
will.
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Fri Apr 07, 2006 3:02 pm Post subject: Why use starter contactor? |
Robert L. Nuckolls, III wrote:
Quote: | Unlike wound-field motors supplied on B&C (and perhaps other)
I found this problem another way. After installation of one of these PM
starters my Comanche got hard to start when warm where it hadn't been
before. I didn't notice because at the time my father was flying it more
than I was and had several incidents of almost running the battery down
trying to start the engine when it was hot (carbureted engine, not fuel
injection). This was doubly surprising as the engine was equipped with a
shower of sparks ignition system. It would fire but then wouldn't
'catch' and keep running when the start button was released. The engine
would spin down and seem to 'catch' just before it quit turning. It was
very perplexing.
(You have enough information to solve this puzzle but just for fun I
will post the real problem and the fix in the next message so you can
think about it for just a moment.)
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
brian
Posted: Fri Apr 07, 2006 3:41 pm Post subject: Why use starter contactor? |
OK, where was I ... oh yeah, the hard starting Comanche after installing
a PM starter.
It seems that someone had wired the start lead to the shower-of-sparks
system to the starter side of the start solenoid. When the start button
was release the EMF generated by the still-turning PM starter would hold
the shower-of-sparks relay in and that would continue to disable the
right mag and keep the left mag on the retard breaker but it wouldn't
provide enough voltage to get the shower-of-sparks vibrator to really do
its thing. When cold the engine would freewheel better when the start
button was released and the shower-of-sparks start relay would drop out
before the engine lost too much RPM and it would start fine.
When trying to start after just a bit of a cool down the engine was
extra tight and would not freewheel so the engine spun down before the
starter did.
The solution? Move the start lead for the shower-of-sparks system from
the starter side of the solenoid to the start button itself. Now the
power went away instantly when the start button was released and the
engine would catch and run just fine.
BTW, this problem drove me nuts for about 6 months until I finally
figured it out.
Posted: Fri Apr 07, 2006 7:01 pm Post subject: Why use starter contactor? |
Isn't it amazing how those simple-ideas stack up sometimes?
At 04:40 PM 4/7/2006 -0700, you wrote:
a PM starter.
starter did.
figured it out.
glcasey(at)adelphia.net Guest
Posted: Sat Apr 08, 2006 6:06 am Post subject: Why use starter contactor? |
Just another data point in this discussion: Many years ago (make
that many, many years...), when I was at GM and working with Delco-
Remy The subject of stuck solenoids was known. The system was
designed so that all the components were sized appropriately and the
battery would run down before any of the other devices, like the
starter or wire would fail. The idea was that the starter would
stick so the driver would turn the key off and it would revert to
cranking a dead engine. If it stuck and the driver didn't know
enough to shut the engine off then the starter would likely fail
along with the overrunning clutch. Not pleasant. On my
experiemental I used a "big fat" starter push-button switch wired
directly to the solenoid on the B+C series-wound starter solenoid.
the starter is powered through the master contactor. I admit it was
tempting to run the starter hot from the battery, but I finally
backed off from that concept. I would guess that if the starter
stuck on and the engine was shut off the battery would run down
before anything bad would happen. If it sticks with the engine
running I guess the only detection would be by looking at the battery
voltage (no ammeter installed). The good thing is that this type of
failure occurs on the ground; the bad thing is that this stuff is
very expensive.
And then for redundancy I simply wired two "master" relays off the
battery - one "master" to power the big stuff, including the starter,
and one "avionics" relay to power the radios. I probably should have
wired one of the radios off the master.
Gary Casey
ps: I just fired the engine for the first time and the performance
of the B+C starter was very impressive. I do have a firewall-mounted
battery, but with an IO-540 with 10:1 compression and a composite
prop, the starter spun the engine with AUTHORITY and there was not
even a hint of cogging over TDC. The starter was also very quiet,
implying that the drive gear is well-designed and all the alignments
were very well done. I was impressed.
Posted: Sat Apr 08, 2006 7:49 am Post subject: Why use starter contactor? |
Sizing of components to enhance predictability and therefore
push failures off toward more acceptable ends is one of
many tools in the system designer's toolbox. The exercise
you've cited is generally applied when rudimentary
techniques are not applicable. For example, there's no
fuse or circuit breaker that might be expected to bring
a runaway starter to heel. So the FMEA drives designers
to consider limiting the ability of a system fault to
bring the whole to ruin. Limiting battery size such that
sticking contactor events would come to graceful conclusion
was a valid approach.
In the aircraft world, we might utilize this approach with
better assurance of success because we have regulatory
control over the components used. Unlike cars in the pubic
domain, we have better assurances that an airplane won't
get fitted with a bigger battery and that airplane looses
benefits of the original designed in limits.
Suppose we had the task of mitigating this event today?
For under $1 I can buy a microprocessor that can be
programmed to watch start signal from the panel, compare
with power applied to the starter, watch battery voltage
for potentially damaging attempts to start with a soggy
battery, and I might even filter the start signal through
the processor so that a dirty start switch and/or tentative
operation of the switch doesn't tease the starter contactor
into welding. If any undesired condition is detected,
I at least have an opportunity to annunciate it to the
operator and in some cases terminate the start attempt
-AND- annunciate the condition.
Had a Glassair stick an always hot starter wire and the brand
new RG battery was cranking merrily away long enough for
the builder to get out, remove the cowl and disconnect
the battery. The starter survived (although no doubt
short on future service life). The builder subsequently
moved his starter feed to the downstream side of the
very expensive.
I was at OSH one year when a story flashed around the field
about one of the airshow performers having landed and discovering
that his starter and ring gear were all chewed up. The off-hand
diagnosis was that high g-loading during his performance caused
a tentative closure and subsequent welding of his starter
contactor. I would have given $100 to get my hands on all the
parts and to see how they were installed.
I would guess that it's far more likely that the starter
stuck on initial cranking of the engine and the pilot
was mentally concentrating on the performance task before
him. He might have made good use of the $1 processor.
Quote: | And then for redundancy I simply wired two "master" relays off the
. . . or supplied a normal-feed diode from main bus to
the avionics bus and you could now call it an e-bus.
That starter was in development for years before it hit the market.
Early endurance issues were pretty much limited to high stress
points in the castings which were identified and fixed early on.
We were on a trip to CA to participate in Voyager support activities
at Mojave when Bill stopped by Robinson to meet their president
and discuss starter issues.
I believe to this day, the B&C starter still goes out on 100% of
Robinson products. Starters are pulled off of Robinson helicopters
when they come back for 2,000 hour overhaul. This is one of
VERY few instances where a manufacturer has an orchestrated
opportunity to track a product's field performance. Many returned
starters look like junk yard dogs having suffered the rigors
of various duties in the field. However, when opened up wear rates
indicate that the starters would easily run another 2,000
hours without further attention. Continental gave up trying
to 'kill' a B&C starter after 5,000+ starts on the test stand.
Odds of you being a satisfied user of this starter are very good
but I applaud your decision to run the starter downstream of
Posted: Sun Apr 09, 2006 9:02 am Post subject: Why use starter contactor? |
Bob:
Don't you there's a good chance the firewall solenoid was mounted
in a manner that positive G's caused it to close. This is common on
acro planes with firewall contactors mounted where pos G's close them.
Van's aircraft found this and than recommended the contactor be mounted
sideways. Well that also turned out to be a bad idea. Because the solenoid
Van's sells is not made for sideways mounting, the solenoid galled and
failed.
The ultimate solution was to mount the start solenoid so Positive G's
would keep the contacts open, since negative G's are less critical,
the way to mount was with the metal cap down (on typical contactor).
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1144596827-336-39&browse=electrical&product=start-sw
(as shown)
Here is some more goodies from SkyTec's site:
As far as unknown run-on? starter backdriving. Why not
install a run-on light if possible (think it applies to HT model):
http://www.skytecair.com/images/warning%20lights%202.JPG
http://www.skytecair.com/images/Starter_RunOn_Doc.pdf
(also see note below on Robinson HT skytec starter)
How to wire a starter push button:
http://www.skytecair.com/images/ST2_Wiring.pdf
Interesting SkyTec standard or replacing B&C on Robinson Helicopters?
http://www.skytecair.com/images/HT%20Robinson%20Convert.pdf
Also the new SkyTec NL starter NEEDS a firewall solenoid:
(No choice, you must use a FW solenoid with the new NL starter)
New NL starter, cool animation on reset of shear pin
http://www.skytecair.com/NL%20Shear%20Pin.htm
http://www.skytecair.com/Lycoming.htm
Interesting note on shower of sparks and helicopter wiring:
http://www.skytecair.com/Helicopter_wiring.htm
(some one commented on a problem, I think this is relative)
George
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Mon Apr 10, 2006 6:06 am Post subject: Re: Why use starter contactor? |
A dump of what I think I know and some vaguely suspicions--
Stuck Starters--The starter motor pinion is 1.2 inch in diameter, the ring gear is about 12 inches in diameter--a 1:10 ratio. The starter (non-geared type) turns at several thousand RPM to turn the engine at several hundred RPM. When the engine is running at maybe 4000 RPM, an engaged pinion would turn the starter at 40,000 RPM.
1) Is this even possible?
2) Since a PM starter would be a generator, what would be the effect?
3) Would not a pilot have any way to know this?
Contactors Generally--The Stancor White Rogers etc. B&C was a wimpy return spring because a beefy return spring would require too much power to hold compressed. I suspect the thing will re-close at only a few G's. Bob N. had access to a G-force test rig. Please Bob can you run some tests for us? A Kilovac EV200 would be good too. A shake table would yield good data too.
Starting Contactors Specifically--I side with Jet Pilot George. A 20A pushbutton switch is simple, reliable, lightweight...and heck if it sticks the button won't pop back out.
Consideration of contact-arcing prevention and transient voltages need to be addressed, too. There are big sparks to lasso.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
frank.hinde(at)hp.com Guest
Posted: Mon Apr 10, 2006 6:29 am Post subject: Why use starter contactor? |
My extremly limited knowledge of stuck starters comes from a friend who
flew 250 miles at night in a C172 with the starter engaged the whole
way...I was amazed...And so was the owner at the repair bill!
I do like the simple warning light idea wired to the starter side of the
contactor and will be retrofitting a 'Radio Shaft' mini 12V LED to my
panel
Frank
RV7a...Almost at paint stage.
rv8ch
Posted: Mon Apr 10, 2006 7:00 am Post subject: Why use starter contactor? |
Quote: | Contactors Generally--The Stancor White Rogers etc. B&C was a wimpy
It seems like you could energize one with a bit of wire, and
swing your arm around round and round like a propeller, like
you used to do as a kid, to generate some Gs. My battery
contactors are laying on their side, so the only G force that
will cause them to open will be acceleration, and my engine
won't have that much power.
In any case, if this were a real problem, wouldn't all
those aerobatic guys be complaining a lot?
BTW, what's the status on your solid-state contactors?
Once those are available, the "hand grenade" contactors
will go the way of the vacuum tube.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Mon Apr 10, 2006 8:05 am Post subject: Why use starter contactor? |
For a short period of time . ..
Quote: | 2) Since a PM starter would be a generator, what would be the effect?
All starters have over-run clutches to prevent the engine from driving
the starter. While the pinion is indeed spinning fast, the starter
is turning MUCH slower.
Quote: | 3) Would not a pilot have any way to know this?
If it's an electrical 'stick' a light will tell you that
it's happening. A mechanical stick generally goes unnoticed.
Quote: | Contactors Generally--The Stancor White Rogers etc. B&C was a wimpy return
spring . . .
Don't understand the reference to B&C. They
don't sell a starter contactor with a "whimpy
return spring" . . .
Quote: | . . . because a beefy return spring would require too much power to
data too.
Spring rates are selected for trade offs for pull-in voltage,
contact opening force and contact spreading velocity. Once a contactor
is energized, the holding force on the seated plunger is huge.
Spring rates are not a consideration for energy required to
KEEP the contactor closed, only voltage required to get it
closed in the first place.
I have tested the S-W-R contactors on the centrifuge and was able
to close a continuous duty contactor (light spring) at about
4-5 g's. Of course, continuous duty contactors are used only for
battery contactors and are ALREADY closed in flight so g-loading
is not a matter for consideration.
An intermittent duty S-W-R contactor wasn't available to me
for testing but one might safely assume that the springs
are stronger and might take more g-force to close them. But
this begs the REAL question . . . why would anyone use
a S-W-R contactor for a starter contactor in the first place?
The problems cited by Skytec for replacing starters on older
airplanes focused on intermittent duty versions of the S-W-R
contactor used on tens of thousands of older airplanes
originally fitted with wound field starters . . . demonstrably
gentler on a starter contactor but STILL prone to sticking.
When the wound-field starter was replaced with a PM machine,
inrush currents went up by as much as 2 times that of
conditions prevailing when the S-W-R designs were fitted
to those airplanes decades ago.
The sad fact was a recommendation to replace the S-W-R,
high area, low pressure contactor with a high-dollar, Eaton-CH
6041H series contactor. These are fine, mil-spec contactors
but completely unnecessary.
We've discussed the advantages of the newer low-area,
high-pressure starter contactors used in the automotive world
for decades. This is the style of contactor that was offered
by the B&C in their original starter installation kits
and later by the AeroElectric Connection when we had the
parts business. It's been used on millions of cars having
PM starters . . . while it can STILL stick due to external
effects of soggy battery or tentative control signals, the
overall service life of this device has been satisfactory
and cost of ownership is very attractive.
This modern starter contactor will not be closed by g-loads
any of us hope to experience and would probably pull the
wings off before the contacts close. Further, if one installs
the S702-1 style contactor on the firewall as recommended,
orientation of the plunger motion is such that you would
have to fly into a mountainside to effect an unintended
closure of the starter contactor.
The whole g-loading concerns for starter contactors
thing was a tempest in a teapot from the get-go. It's easily
analyzed, understood and DESIGNED out by judicious
selection of modern, low cost contactors.
Quote: | Starting Contactors Specifically--I side with Jet Pilot George. A 20A
Yup, the S702-1 and it's close cousins have slain these
dragons too. Contact spreading velocity is fast enough to
keep arcing to a satisfactory level and transients were
never a threat to contactors . . . but the S702-1 comes
with it's spike catcher built right in.
The Kilovac and 6041H contactors are truly fine devices
and there are cases where their application makes good
sense . . . but they to0 have their vulnerabilities
and limitations. See:
http://www.aeroelectric.com/Pictures/Failures/6041_Contactor_Failure.jpg
http://www.aeroelectric.com/Pictures/Failures/Kilovolt_Contactor_Lightning_Damage.jpg
These discussions have been long on hip-shot recommendations
based on ill-conceived worries and short on systems integration
analysis based on design goals for low cost of ownership,
failure tolerant design and an understanding of all the
ingredients in the recipe for elegant solutions.
