JRatcli256(at)aol.com Guest
Posted: Tue Aug 04, 2009 6:47 am Post subject: Weight & Balance for certification of Mark3x |
The plans for the Mark3x say the bottom of the wing should be at +9 deg. when doing the W&B.
The form that comes with the certification guide from EAA states the aircraft should be weighted in level flight attitude.
My question to those who've had their Mark3x inspected ------ What attitude was used for your certification W&B ?
And if it was level flight attitude, what is the level flight attitude.
John Ratcliffe
NeilsenRM(at)comcast.net Guest
Posted: Tue Aug 04, 2009 7:41 am Post subject: Weight & Balance for certification of Mark3x |
John
The assumption is depending on your speed/density altitude/weight, that is level flight.
My older MKIIIC W&B plans show the same thing. My plane was inspected using that guideline. Also you don't show that information on your weight and balance sheet.
Rick Neilsen
Redrive VW powered MKIIIC
zeprep251(at)aol.com Guest
Posted: Tue Aug 04, 2009 8:56 am Post subject: Weight & Balance for certification of Mark3x |
John,
Raise the tail until the horizontal is level.That should make the wings at 9 degrees,but I think the tail is the place to start.
aslsa.rng(at)gmail.com Guest
Posted: Tue Aug 04, 2009 11:13 am Post subject: Weight & Balance for certification of Mark3x |
If you wanted to do some relatively simple math using the lift coefficient curve for a relatively thick flat bottomed air foil and the cruise speed of a Mk III you'd get the right result at an AOA of, wait for it, around 9 degrees. Set it just like the plans say, it works.
Rick Girard
On Tue, Aug 4, 2009 at 11:55 AM, <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
[quote] John,
Posted: Tue Aug 04, 2009 1:35 pm Post subject: Weight & Balance for certification of Mark3x |
The flat bottom doesn't necessarily dictate AOA at cruise. Having many hours in an aeronca I can attest to the fact that itcruised on the step with the bottom of the wing pointed slightly down. Of the features on the Kolb wing that prevents this
are: the thickness max is more forward of the aeronca's NACA 4412 and the nose is much sharper at the bottom of the leading edge.
The piper J3 airfoil is closer with the max thickness position and the flight characteristics are more like the Kolb, high lift and draggy.
(albeit a delightful low speed craft)
If you want to pick up some cruise speed with very little sacrifice in other categories, build your Kolb wing with a much more blunt nose.
That will give you more symmetry and better airflow. When you pull back and point upstairs the wind will take the easy way out and go underneath.
BB
as Ripley said, believe it or not
On 4, Aug 2009, at 3:12 PM, Richard Girard wrote:
[quote]If you wanted to do some relatively simple math using the lift coefficient curve for a relatively thick flat bottomed air foil and the cruise speed of a Mk III you'd get the right result at an AOA of, wait for it, around 9 degrees. Set it just like the plans say, it works.
Rick Girard
[quote] John,
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Wed Aug 05, 2009 3:26 pm Post subject: Re: Weight & Balance for certification of Mark3x |
I don't have the book in front of me ,but how we did it to my m3x was we put a level from the trailing edge of the wing (not the end of the flap) and brought the forword end of the level down 7 3/4 inches from the bottom of the leading edge of the wing,the raised the tail until the bubble was level.That was level flight.then dropped a plumb line down from the leading edge and that is where you measured from for all your stations.
chris ambrose
M3X/jab 43.3
N327cs
Possums
Posted: Wed Aug 05, 2009 3:43 pm Post subject: Weight & Balance for certification of Mark3x |
At 07:26 PM 8/5/2009, you wrote:
chris ambrose
M3X/jab 43.3
N327cs
Here's how we used to do it.
58.51 KB |
7241 Time(s) |
166.55 KB |
7241 Time(s) |
_________________ Possum |
ces308
Posted: Wed Aug 05, 2009 4:01 pm Post subject: Re: Weight & Balance for certification of Mark3x |
That's it ! I couldn't remember exactly if it was 7 1/2 or 7 3/4....but that is how I did it..
chris ambrose
JRatcli256(at)AOL.COM Guest
Posted: Wed Aug 05, 2009 5:24 pm Post subject: Weight & Balance for certification of Mark3x |
Photos of earlier models of the Mark3x show the bottom front of the wing set above the tubing at the top of the windshield and the front top of the horz. stabilizer at the top of the boom tube. What the angles are, I don't know.
For that reason, what attitude that puts the aircraft in when the wing is at 9 deg. for W&B calculations, I don't know. It may be in level flight attitude. Also the horz. stabilizer may be level ??? Can someone supply the angles for reference ?
My Mark3x, with the engine mount level --- Wing incidence is +2.8 deg. (Front bottom of wing is about 3" below the top of the windshield tubing bow), the horz stabilizer is at -4.8 deg. ( the bottom of the front tube of the stabilizer 1/4" above centerline of the boom tube). I think these changes were made to help alleviate the problem of "Kolb Quit"
When I position the aircraft at 9 deg. for W&B calculations, the attitude appears to me, to be in a three point landing attitude with the tail wheel about 5" above the floor.
Surely this isn't level flight attitude.
If I put the horz. stabilizer level, that puts the bottom of the wing at -2 deg.
Because of the change in wing and horz. stabilizer incidences, wouldn't that change the angle of the wing for W&B calculations ?
Again your thoughts ???
John Ratcliffe
russ(at)rkiphoto.com Guest
Posted: Wed Aug 05, 2009 5:40 pm Post subject: Weight & Balance for certification of Mark3x |
Chris
How long was your level?
On Aug 5, 2009, at 7:26 PM, ces308 wrote:
chris ambrose
M3X/jab 43.3
N327cs
http://forums.matronics.com/viewtopic.php?p 56248#256248
ces308
Posted: Wed Aug 05, 2009 5:49 pm Post subject: Re: Weight & Balance for certification of Mark3x |
It was a 4 feet level....it went from the wing trailing edge to the leading edge. I would not go buy the horz stab....do the wing thing...my tali wheel was up quite a ways...
chris ambrose
Posted: Wed Aug 05, 2009 6:40 pm Post subject: Weight & Balance for certification of Mark3x |
On 5, Aug 2009, at 9:23 PM, JRatcli256(at)aol.com (JRatcli256(at)aol.com) wrote:
Wouldn't this position be close to a normal attitude near stall? That's what W&B is all about.
BB
ces308
Posted: Wed Aug 05, 2009 6:59 pm Post subject: Re: Weight & Balance for certification of Mark3x |
you will never full stall land that airplane....atleast not without slamming the mains on the ground....don't second guess the instruction manual...
chris ambrose
Posted: Thu Aug 06, 2009 8:43 am Post subject: Weight & Balance for certification of Mark3x |
John C
I have done some research on this subject C and have some thoughts C too. They will have to wait till this evening C tho C when I have more time......I've just came in for a work break (from building my house).
More later....
Mike Welch
MkIII
Date: Wed C 5 Aug 2009 21:23:44 -0400
Subject: Re: Weight & Balance for certification of Mark3x
Photos of earlier models of the Mark3x show the bottom front of the wing set above the tubing at the top of the windshield and the front top of the horz. stabilizer at the top of the boom tube. What the angles are C I don't know.
For that reason C what attitude that puts the aircraft in when the wing is at 9 deg. for W&B calculations C I don't know. It may be in level flight attitude. Also the horz. stabilizer may be level ??? Can someone supply the angles for reference ?
My Mark3x C with the engine mount level --- Wing incidence is +2.8 deg. (Front bottom of wing is about 3" below the top of the windshield tubing bow) C the horz stabilizer is at -4.8 deg. ( the bottom of the front tube of the stabilizer 1/4" above centerline of the boom tube). I think these changes were made to help alleviate the problem of "Kolb Quit"
When I position the aircraft at 9 deg. for W&B calculations C the attitude appears to me C to be in a three point landing attitude with the tail wheel about 5" above the floor.
If I put the horz. stabilizer level C that puts the bottom of the wing at -2 deg.
Because of the change in wing and horz. stabilizer incidences C wouldn't that change the angle of the wing for W&B calculations ?
John Ratcliffe
Windows Live™: Keep your life in sync. Check it out. [quote][b]
