tc1917(at)bellsouth.net Guest
Posted: Sun Aug 02, 2009 2:52 am Post subject: FSII |
Just might be me but I would think 650-700 fpm climb would be bad. I mean,
a FSII with 60 or so horses up top would have a whole lot better climb. I
have access to a FSII with a 503 and it climbs better than 1000 fpm. Maybe
even closer to 1200 most of the time. I had an original FS with a 447 that
climbed a whole lot better than that. What gives? Ted Cowan, Alabama,
Slingshot 912 ul.
frank.goodnight(at)att.ne Guest
Posted: Sun Aug 02, 2009 3:20 am Post subject: FSII |
Hi Ted,
My firestar 2 with the 60 hp HKS and at gros wt. of 725 lbs climbs at
somewhere around 700 ft per min on a 100 degree day with a relitive
humidity about 90%I would like to have the numbers you have
but just don"t. tjere are a couple of other HKS firestars around.,
wonder how they do?
Frank goodnight
Firestar2 HKS
Brownsville TX
On Aug 2, 2009, at 5:41 AM, Ted Cowan wrote:
I mean, a FSII with 60 or so horses up top would have a whole lot
better climb. I have access to a FSII with a 503 and it climbs
better than 1000 fpm. Maybe even closer to 1200 most of the time.
I had an original FS with a 447 that climbed a whole lot better than
that. What gives? Ted Cowan, Alabama, Slingshot 912 ul.
lcottrell
Posted: Sun Aug 02, 2009 6:05 am Post subject: FSII |
I have flown my Firestar II with a 447, first at 280 lbs empty weight. It flew well, but I had no way to tell what the climb rate was. Then with a 503, but by that time I had powder coated the cage, put on enough auto paint to fill the weave of the fabric and a lot of more stuff to add weight. At my altitude with a Garmin 196 as the only way to measure my climb, and I never saw more than 350 fpm. Now with a HKS and a plane that apparently weighs in at 460 I can see climbs of 4 to 500 fpm. This is all at 4000 feet altitude.
Larry
Posted: Sun Aug 02, 2009 7:28 am Post subject: FSII |
Larry C:
Hard for folks, that fly at sea level, to fully grasp the degradation of performance caused by altitude and density altitude.
Us flat land, sea level guys are always in for a rude awakening the first few days we spend on our trips out West. My airplane, with seemingly unlimited performance at sea level, suddenly will not leap off the ground, barely climbs, and has a habit of dropping out of the sky during higher altitude approaches.
Based on cargo weight and altitude, I think Frank G's FSII performed admirably at Monument Valley, UT, this year, flying off a strip at 5,200 feet ASL.
Larry
_________________ John Hauck
Titus, Alabama |
lcottrell
Posted: Sun Aug 02, 2009 8:43 am Post subject: FSII |
You will be happy to know that this time I already have my winter wood supply, split and put up. The only thing that can interfere with my gypsy ways is the two birds that I will
have to be flying. [img]cid:FE0CAAECA77F4FCC9908D94C47AC5F23(at)larryPC[/img]
Larry
114.07 KB |
7499 Time(s) |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Sun Aug 02, 2009 11:01 am Post subject: Re: FSII |
| tc1917(at)bellsouth.net wrote: | Just might be me but I would think 650-700 fpm climb would be bad. I mean,
Slingshot 912 ul. |
At sea level, that's not too bad. Tho my FSII with the 503, 3.47:1 C box and 68" WD 3 blade taper tip did around 1000 fpm at about 2000' MSL density altitude. Plane was 440lbs empty so a little on the heavy side.
The plane is pretty much tailor-made for the 503 so that motor probably gives the best performance unless you overpower it with something else.
But 700 fpm is not that bad. I'm assuming you're talking about Jimmy's report with his with the new HKS fitted? There's a little more weight and probably more drag with the extra surface area on top, but still that's pretty decent.
At high density altitudes, tho, I dunno. I got between 300 and 400 fpm here in northern NM at density altitudes of about 8000' MSL with the 503 leaned out as much as I dared. Flyable, but a little nerve-wracking until the houses started getting a little smaller. I don't know how an HKS equipped one would do....
LS
_________________ LS
Titan II SS |
lucien
Posted: Sun Aug 02, 2009 11:10 am Post subject: Re: FSII |
| John Hauck wrote: | Larry C:
A 503 equipped FS II will do ok at high DA's. Like I said, the typical DA where I fly is around 8000' MSL (it'll drop to 6000 to 7000' in winter) and my FS II was always flyable.
Course we got super long runways all over the place up here, usually a mile long or more, because of our general lack of air. So I always still had runway underneath by the time I got to a safe altitude to turn away from the airport.
Best performance was the first new years day I lived here, it was 11F and I recorded 400fpm. Worst was about 300fpm one evening in late summer where it was about 75F with density altitude around 8500' MSL.
Landing and takeoff ground speeds are also noticeably higher at those density altitudes so that takes a little getting used to also....
LS
Titan II SS |
lcottrell
Posted: Sun Aug 02, 2009 11:18 am Post subject: FSII |
Even with the heavier weight, it would improve the 503's performance by about 2-300 fpm.
[quote] Larry
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=255674#255674
http://www.matronicp; via the Web href="http://forums.matronics.com">http://forums.matronics.com
_p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
- www.avg.com
Version: 8.5.392 / Virus Database: 270.13.41/2277 - Release Date: 08/02/09 05:56:00
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Sun Aug 02, 2009 5:13 pm Post subject: Re: FSII |
Cowan writes:
Slingshot 912 ul.<
Ted,
Don't know what gives, but I've never gotten the cruise speeds some of the Firestar owners claim. I've got big tundra tires, my plane weighs 750 lbs. with me and 13 gal of fuel in it, I've got a heavier thicker tailwheel, I don't have a full enclosure, it's 100 degrees with 75 degree dew points here when I'm flying, so all those items figure into the equation. I'm sure some of the Firestars are lighter & more aerodynamic than mine, and I'm glad for them that they can get that kind of performance. But, I like the big tires and the wide tailwheel and they are staying on. I do wonder if installing the gull-wing type doors on my enclosure would help clean up my profile some, and wouldn't mind trying that some day.
I remember when I had the 503 on, and the climb rates and cruise speeds were about the same with the 503 as what I've got now with the HKS.
I flew today to the old airstrip I used to hanger at, and there is an 800 ft. strip there with 25 ft. trees at the end. I took off into a left-quartering wind, and was up and out easily. I'll probably never need to take off out of a strip tighter than that, so I'm tickled pink. I haven't used that runway since back when I had the 503 on.
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
Posted: Sun Aug 02, 2009 5:31 pm Post subject: FSII |
Jimmy Young
Good news, Jimmy.
Now you can breeze out of Nauga Field.
Titus, Alabama |
