Lee Steensland
Joined: 10 Apr 2008 Posts: 18 Location: Spokane-ish- WA
Posted: Sun Aug 02, 2009 1:37 pm Post subject: upper and lower elevator horn doubler location |
Folks,
Perhaps I'm being particularly thick today but I could use a hand. I am starting on the elevator horns and something appears to be amiss. I haven't cut any metal yet so I'm safe, but I can't figure out from the plans where to make the triangular cutout in the elevator for 6-t-3-6.
As near as I can figure it's at least the length of the top flange on the skin (20mm) rearward from the front of the elevator, and at least big enough to take the 3/4 inch piece of extrusion (20mm).
How did you guys come up with that dimension?
Thanks!
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sun Aug 02, 2009 6:12 pm Post subject: upper and lower elevator horn doubler location |
Lee,
Check your builders guide 6-T-3A page 11. Third and fourth photo show where
it goes.
Floyd Wilkes
601XL O-200
_________________ Floyd Wilkes |
Lee Steensland
Posted: Sun Aug 02, 2009 7:22 pm Post subject: Re: upper and lower elevator horn doubler location |
Awesome I found it there.
One more question, kind of nit picking now I suppose.
The bottom hole says "8 mm from the bottom bend". I basically laid a straightedge on the front spar and measured my 8mm from there. Is that right or should I start measuring 8mm from the flat, (after the bend)?
floyd wilkes
Posted: Mon Aug 03, 2009 3:20 am Post subject: upper and lower elevator horn doubler location |
Lee
I believe you are correct..
Floyd Wilkes
