About those stiffening circles around the lightening holes
Site Admin
PostPosted: Fri Jul 24, 2009 3:46 pm    Post subject: About those stiffening circles around the lightening holes Reply with quote
At 10:48 AM 7/24/2009 Friday, you wrote:
Fellow RVers,
I need to mount some stuff on wing ribs. But, the ribs have holes cut out
for lightening...and around each hole is stamped a modest raised/indented
circle in the sheet metal, for stiffening I suppose.
It is the raised side that causes problems when trying to attach something
flat there. I'd like to somehow squash or flatten a portion of the raised
circle, just enough so that the things I need to mount will fit flush on the
rib. Yes, some things must go onto the rib. No, some of this I cannot mount
on the other side.
What have RVers done to solve this little problem?
Ralph Finch
Davis, California
RV-9A QB-SA
Hi Ralph,
Here's how I mounted the Gretz pitot controller PC board on my RV-8. Worked pretty good:
http://www.mykitlog.com/users/display_log.php?user=dralle&project=638&category 982&log=81657&row=132
http://www.mykitlog.com/users/display_log.php?user=dralle&project=638&category 982&log=81656&row=133
RV-8 #82880 N998RV
FWF Right Around The Corner...
