swivel tailwheel for Kolbs
Thom Riddle
PostPosted: Fri Jul 24, 2009 8:01 am    Post subject: swivel tailwheel for Kolbs Reply with quote
If any on you with standard Kolb tailwheels have been thinking about moving to a swivel tailwheel, I have one ready to bolt-on to the standard Kolb tailwheel stinger. It is a 4" diameter full swivel with some use mostly on grass but in perfect working order with only a little wear on the rubber. A new one is $288.95 from Aircraft Spruce. I'll sell mine for a lot less.
This one came off of BB's MkIII when he went to a 6 inch wheel. He sold it to me for my FS but after breaking the FS and selling the remains, I no longer need the swivel tailwheel. The SS I'm buying has one already.
If you are interested, make me a reasonable offer. Contact me off-list, directly via email.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Fri Jul 24, 2009 8:20 am    Post subject: swivel tailwheel for Kolbs Reply with quote
> Thom Riddle
May want to hang on to it. Sling Shots have a lot of weight on the
tailwheel, similar to what I deal with on my mkIII. If you fly a lot, it
may wear out sooner than you expect.
Thom Riddle
PostPosted: Fri Jul 24, 2009 8:34 am    Post subject: Re: swivel tailwheel for Kolbs Reply with quote
John,
Luray already replaced the stinger type tailwheel with a leaf spring tailwheel (6" I think), so it should be good for awhile. The wheels are replaceable. Attached is a photo of the one on Luray's SS.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Thom Riddle
PostPosted: Fri Jul 24, 2009 8:37 am    Post subject: Re: swivel tailwheel for Kolbs Reply with quote
Ooops! Forgot the attached photo. Here it is.
SS with leaf spring type tailwheel attachment
 Filesize:  390.41 KB
 Viewed:  9450 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dana
PostPosted: Fri Jul 24, 2009 8:57 am    Post subject: swivel tailwheel for Kolbs Reply with quote
a lot less....
Thom, do you have a picture of it, and know how much it weighs? I'm
wondering if it would be too big or heavy for my UltraStar...
-Dana
Only two things are infinite, the universe and human stupidity, and I'm
not sure about the former.-- Albert Einstein
Thom Riddle
PostPosted: Fri Jul 24, 2009 9:13 am    Post subject: Re: swivel tailwheel for Kolbs Reply with quote
Dana,
I don't have a photo and have not weighed it, yet. Next time I go to the hangar, I'll bring it home, weight it and shoot a photo of it. This much I can tell you for certain: it is a good bit heavier than the standard Kolb tailwheel but it sure improves ground handling. How close to aft CG limit are you? If you are very close, it could be iffy.
I'll let you know its weight as soon as I know it.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Thom Riddle
PostPosted: Sat Jul 25, 2009 8:33 am    Post subject: Re: swivel tailwheel for Kolbs Reply with quote
Dana,
Attached are two photos of the 4" full swivel tailwheel. I weighed it an was surprised that it weighs only 2 lb 12 oz. That is the good news. The bad news for you is that another Kolber has already committed to buy it for an agreeable price. Unless he reneges (very unlikely), it is sold. Thanks for your interest.
 Filesize:  839.25 KB
 Viewed:  9392 Time(s)
4" full swivel tailwheel drilled for Kolb stinger
 Filesize:  914.19 KB
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dana
PostPosted: Mon Jul 27, 2009 2:49 pm    Post subject: swivel tailwheel for Kolbs Reply with quote
Thanks Thom,
Probably best as money is real tight here right now anyway... but good
information for a future upgrade. The weight probably isn't a problem as I
think my US is a bit nose heavy; takes significant trim tabs to keep the
nose up. I have yet to do a formal W&B but it's on my list of things to do...
-Dana
Q. What's the difference between Mechanical and Civil Engineers?
A. Mechanical Engineers build weapons; Civil Engineers build targets.
JetPilot
PostPosted: Mon Jul 27, 2009 4:23 pm    Post subject: Re: swivel tailwheel for Kolbs Reply with quote
That tialwheel is great ! That is the type of tailwheel that came stanard on my MK III Xtra and it works very well. I fly from a grass field and the tailwheel has been working flawlessly for 3 years now.
I did replace the wheel with a 6 inch wheel, but kept the same housing. I have been very happy with it.
Mike
Kolb MK-III Xtra, 912-S
