al38kit
Posted: Wed Jul 22, 2009 8:31 am Post subject: EV200 |
It appears the EV200 is a good master relay...anyone know why it should not be used as a starter relay...also...?
Al
Posted: Wed Jul 22, 2009 3:31 pm Post subject: EV200 |
At 11:31 AM 7/22/2009, you wrote:
To what advantage? This is a contactor that operates for
a few seconds per flight cycle. The el-cheeso parts
have performed well and demonstrated good value. The
EV200 may function well too . . . but what's the
expected return on investment for the more expensive
purchase?
( -Thomas Paine 1776- )
al38kit
Posted: Wed Jul 22, 2009 4:52 pm Post subject: Re: EV200 |
If I could get the parts cheap enough, the benefit for me, with two planes, would be interchangeability...or just having one spare on the shelf.
Thanks for the initial lead, it looks like a great relay, but like you say, can be pricey...I think I can get them at a little over $40.
Al
retasker(at)optonline.net Guest
Posted: Wed Jul 22, 2009 5:10 pm Post subject: EV200 |
Uuuh... Because a much cheaper and perfectly adequate solution is
available - the normal el-cheapo starter relay.
The only reason I can see for ever using the EV200 is that it uses less
current when it is energized which might be justifiable for the master
relay. But for the starter relay - how long would it be on when
starting - 2-5 seconds?
Save the money and spend it on gas...
My $0.02
Dick Tasker
al38kit wrote:
Al
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Thu Jul 23, 2009 1:03 pm Post subject: Re: Contactors |
(some repost here...) I have railed against these Type-70 contactors for years. But they are almost obsolete. Most electronics distributors have dropped them from their lines.
Problems--
1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in Death Valley in May and take off in October. Maybe. This is primarily due to the Nylon innards. This is a drop-dead reason to avoid the part.
2) Not sealed. Not dust proof, or fuel proof.
3) Low interrupt capacity.
4) High hold current---16 ohm coil. Almost one amp.
5) Low hold force. The specifications call for specific orientation. 2G rating?
6) Wildly wrong for B&C to use coil suppression diodes on these. This causes short lifetimes on the B&C parts.
7) Not designed to open against voltages above 36 volts. (So forget the B-lead applications)
See: www.stancor.com
There are better ways to go. Omron's line of automotive contactors (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but preferred.
Can you use them? Sure. Should you use them?....not on my bird, Bubela.
Better yet, avoid all contactors and use manual switches if you can.
"Facts do not cease to exist because they are ignored."
---Aldous Huxley
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Fri Jul 24, 2009 8:31 am Post subject: EV200 |
At 04:03 PM 7/23/2009, you wrote:
Really? Who used to carry them that doesn't any
more. My preferred sources are still offering
them. I think the Cole-Hersey guys are still
cranking out their equivalent parts in volume.
I think these are the devices that Van's offers.
| Quote: | Problems--
avoid the part.
And hundreds of thousands of el-cheeso contactors
have been used in airplanes for decades and for
some reason, they never seem to have bubbled up
high enough on the "problems list" to have been
replaced. The max temperature ratings for cited
for the purpose of meeting specified design goals
over a products service lifetime. The 122F max
does not mean that the critter goes into destructive
meltdown at 123, 153 or even 200F.
We've had numerous discussions on the List concerning
ratings vs. limits vs. service life, on a host
of products. The physics of the matter haven't
changed. That 122F figure is not a drop-dead
reason for doing anything. It's a reason to consider
the product's suitability to task using a combination
of understanding what the ratings mean -AND-
demonstrated field history.
| Quote: | 2) Not sealed. Not dust proof, or fuel proof.
No, not hermetically sealed. But those cans
are steel and the caps are swaged on with
hydraulics or some form of rolling press. I've
opened dozens (not easy to do) for various reasons
and have yet to discover a spec of dust. And how many
contactors are expected function as advertised
while sloshed with fuel? The venerable Cutler-
Hammer 6041 series contactors have been around
since the late 30's and are less "sealed"
or "fuel proof" than the el-cheeso RPM/W-H/Stancor
devices. Yet they are still in current production on
many of the Hawker-Beech products. What part would
you recommend that HBC consider for upgrading their
choice of contactors? I'd be pleased to forward
your recommendations to their VP of Engineering.
| Quote: | 3) Low interrupt capacity.
And what current levels do you propose to interrupt?
A battery contactor opens just before shutdown
of the airplane when it's parked. How much current
does the contactor carry under these conditions?
If the service life at full rated current is in
the tens of thousands of operations, how much will
it go up if you only open it during shutdown
of the airplane? 10 Amps? Gee, that's a killer.
| Quote: | 4) High hold current---16 ohm coil. Almost one amp.
Yes . . . it's "higher" than the EV200, but not
nearly one amp. See:
http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_2.jpg
http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_1.jpg
| Quote: | 5) Low hold force. The specifications call for specific orientation.
2G rating?
I've not seen that. Please cite the page and paragraph
where this is offered. I've done linear g-loading tests
on these contactors and was unable to open them at the
limits of my centrifuge . . . 10+ G
| Quote: | 6) Wildly wrong for B&C to use coil suppression diodes on these.
Absolute BS. I've demonstrated many times that the
assessment that you and others have offered on the
diode suppression issue is without foundation in the
simple ideas and physics behind the design and
incorporation of these devices. You guys read specs,
and then demonstrate your lack of understanding by
posting a "doom-n-gloom of the day" article that
does NOT demonstrate or explain where I'm wrong.
| Quote: | 7) Not designed to open against voltages above 36 volts. (So forget
For normal operations, the b-lead contactor is not
subjected to more than 36 volts. When operated as
recommended, the service life on an el-cheeso
contactor in the b-lead is not at risk. However,
during an OV runaway, you damn betcha the contactor
is expected to open at more than 36 volts . . . and
why should we care? If the OV protection system
does it's job . . . and just assuming that a couple
of high-energy opening events for the contactor
is going to trash it . . . do I care?
| Quote: | See: www.stancor.com
Which OMRON part would you recommend?
| Quote: | and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11.
Your choice are your own and I wouldn't dream of
attempting to dissuade you from exercising the
right to make them and enjoy the consequences
therefrom. But your participation here on the
List needs to offer more than your opinions
based on poor interpretation of spec sheets,
understanding of design goals and knowledge of
demonstrated recipes for success.
| Quote: | Better yet, avoid all contactors and use manual switches if you can.
ABSOLUTELY! . . . so why do you continue to ignore
that which I have offered on this topic for years?
Make my day, show me where I'm wrong.
