yak52
Posted: Tue Jul 21, 2009 3:42 pm Post subject: LAA Testing |
What we are seeing in the British "testing" is the final step in the execution of a self fullfilling prophecy. I contacted the engineer with the LAA to suggest that the test envelope be tried on the airplane without the "modifications" designed by CH. Then to do the testing again on the airplane after the "modifications" were done and compare the results. This would seem to be a logical regimen. I was informed that the LAA would not do that as they fully accepted the premise that flutter would occur with "slack" aileron cables and it would be unnecessary to do "before" testing. They also acccepted the premise that a structural strengthening of the center spar carry through would be necessary although they had no evidence or engineering study for that premise. Now they have done the after "test" without any baseline or before tests to compare it with and will declare the modifications a success and require the kit be installed in order fly the airplane in the UK. The "flutter" people will pat themselves on the back and declare themselves superior. Everyone else will face the prospect of doing the modifications; and no one will know anymore about what really caused the accidents than before. In case you don't realize it, this is not a success in any form except that now some people can feel confident in building and flying their airplane, at least until the next time someone pulls 6 plus g's.
Larry Webber
Joined: 05 Jun 2008 Posts: 63 Location: West Kingston Rhode Island
Posted: Tue Jul 21, 2009 4:12 pm Post subject: LAA Testing |
Well said Roger more BS will follow from "the renegade group"
Larry
Date: Tue C 21 Jul 2009 19:41:27 -0400
Subject: LAA Testing
What we are seeing in the British "testing" is the final step in the execution of a self fullfilling prophecy. I contacted the engineer with the LAA to suggest that the test envelope be tried on the airplane without the "modifications" designed by CH. Then to do the testing again on the airplane after the "modifications" were done and compare the results. This would seem to be a logical regimen. I was informed that the LAA would not do that as they fully accepted the premise that flutter would occur with "slack" aileron cables and it would be unnecessary to do "before" testing. They also acccepted the premise that a structural strengthening of the center spar carry through would be necessary although they had no evidence or engineering study for that premise. Now they have done the after "test" without any baseline or before tests to compare it with and will declare the modifications a success and require the kit be installed in order fly the airplane in the UK. The "flutter" people will pat themselves on the back and declare themselves superior. Everyone else will face the prospect of doing the modifications; and no one will know anymore about what really caused the accidents than before. In case you don't realize it C this is not a success in any form except that now some people can feel confident in building and flying their airplane C at least until the next time someone pulls 6 plus g's.
| Quote: | http://www.matronics.com/Navigator?Zenith-List
ronics.com
ww.matronics.com/contribution
| Windows Live™ SkyDrive™: Store C access C and share your photos. See how.
_________________ how do you eat an elephant ? one bite at a time |
Doug.Norman(at)sportaviat Guest
Posted: Tue Jul 21, 2009 5:22 pm Post subject: LAA Testing |
Roger,
You have it exactly right, well said. In fact the short summary we see on the LAA web site is rather equivocal about what they’ve done, what they’ve tested, and how really establishes goodness. I’m sure it’s a fine set of tests… it’s just that we have no idea what it proves. Perhaps only that they have not broken the airplane with their modifications. “…These tests have been conducted at various aileron cable tensions and the instrumentation is showing excellent damping of the wing vibratory responses even at cable tensions well below the manufacturers recommended settings. ...” As you point out, there’s an assumption of a ‘wing vibratory response’ to which there is no evidence. In fact, just the opposite when factoring the German testing and analysis. Talk about constructing a straw man to be knocked down!
BTW: what has struck me lately is that Part 23 does not require mass-balanced ailerons (we hear many who demand this as the only answer to a (apparently imagined) problem). Consider the Alarus (yes, also a CH design). It is a Part 23 certified airplane, and I don’t believe it has mass-balanced ailerons.
It’s all quite fascinating.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of roger lambert
Sent: Tuesday, July 21, 2009 7:41 PM
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
rtdin
Joined: 16 Mar 2008 Posts: 46 Location: Florida panhandle
Posted: Tue Jul 21, 2009 10:29 pm Post subject: LAA Testing |
Hi Roger.
Glad to see that you are still active in the search for answers to the unfortunate accidents that involved in flight breakups of CH 601XLs. I recall the msgs that we exchanged while you were trying to get your mind around one of the fatalities. I sent you copies of that NTSB docket. I cited portions of their report to bring you back to the facts as reported as you explored so many blind alleys. I stopped trying when you set your mind on theories that were not supported by NTSB findings.
I find comfort that the LAA and its engineers are conducting the tests with Heintz designed modifications. Glad to see that you are offering assistance. Please fill us in your qualifications. Engineering experience, pilot ratings, hours etc. I have searched the various dockets and reports and I have not yet found any instances of the improper pilot techniques that you report. Especially, pulling six Gs. Please cite those instances from the reports. I have only found reports of in flight breakups that happened in the enroute/cruise phase of flight or in the traffic pattern. I did find a report from France that reported a "rumor" that the pilot sometimes pulled almost three G. This has resulted in some of the most avid supporters seriously recommending three G as the new ultimate limit. I've seen a few remarks such as "If he does a 3 G pull up, the wing will fail." With friends like this....... The LAA is beefing up the center spar. Silly LAA.
I forwarded to you, part of one report that the NTSB said that while established in cruise for ten minutes after t.o., the front hor. stabilizer brackets first failed downward, causing a 200 ft climb, then the h.s. popped up causing a severe nose tuck that destroyed the ship. You favored pilot error. This could have been caused because an inspection point (cracking, after 100 to 300 hours in svc.) in this area was first reported by CH in the Zenair Association Newsletters. See ZN 150 (Sept-Oct, 2005) pg.2 for details. Then another pilot reported in ZN 155 (July-Aug, 2006) pg. 8 finding these cracks on his bird. I don't know. What do you think? I wasn't there.
Don't worry about me pulling all those Gs. My wife holds me down to 2 G. If she is sitting next to me it is further reduced to one G.
Bob Dingley
CH601XL plans 6-6791
(Holding at the wings) Do not archive
Dell Deals: Treat yourself to a sweet155x1201715982/aol?redir=http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2D6) [quote][b]
BobCollins
Joined: 12 Aug 2008 Posts: 19 Location: Sunnyvale CA USA
Posted: Wed Jul 22, 2009 12:39 am Post subject: LAA Testing |
Bob,
I would then assume that if your wife is sitting next to you, then you
and her are not flying. Please remember that _any_ (non-inverted) turn
causes a g-force greater than one.
Bob Collins
Sunnyvale CA USA
MaxNr(at)aol.com wrote:
<snip>
| Quote: | Don't worry about me pulling all those Gs. My wife holds me down to 2
Bob Dingley
yak52
Posted: Wed Jul 22, 2009 4:35 am Post subject: LAA Testing |
In a recent posting:
Hi Roger.
" I stopped trying when you set your mind on theories that
were not supported by NTSB findings. "
Those findings by the NTSB were that there was no evidence of oscillatory damage or metal fatigue. All damage was consistent with overstress. Please explain how
these new modifications would have prevented any of the accidents in the reports you cited.
I did attend the last two Zenith events at Sebring and Sun and Fun. The g figures were supplied by Zenith who particiapted in the NTSB study and had actual
engineering studies done to determine the number of g's necessary to do the damage done in the accidents.
" I forwarded to you, part of one report that the NTSB said that while
causing a severe nose tuck that destroyed the ship."
yak52
Posted: Wed Jul 22, 2009 5:11 am Post subject: LAA Testing |
To complete my earlier post:
Hi Roger.
how these new modifications would have prevented any of the accidents in the reports you cited.
I did attend the last two Zenith events at Sebring and Sun and Fun. The g figures were supplied by Zenith who participated in the NTSB study and had actual
engineering studies done to determine the number of g's necessary to do the damage done in the accident.
Please explain how the modifications being tested would have prevented this accident. Please explain how an airplane flying in level flight causes both horizontal
stabilizer attachments to break simultaneously and the stabilizer then fails downward. Please explain how the airplane, while in level flight, loses an aileron that circles
over the airplane to strike the newly failed horizontal stabilizer on the opposite side of the airplane?
"Don't worry about me pulling all those Gs. My wife holds me down to 2 G. If
she is sitting next to me it is further reduced to one G."
I'm sure you realize that you experience 1 g while just standing(sitting in your case) on the earth.
Once again, I just wish the LAA testing actually would have gone toward determining the cause of actual accidents, not just creating a false sense of security through a
faulty test regimen.
dougsire
Posted: Wed Jul 22, 2009 6:38 am Post subject: Re: LAA Testing |
Roger,
Do you have a copy of the NTSB Materials Laboratory Report 07-095 dated 9/19/07 regarding the Yuba City crash? One can't hope to understand what might have happened without really digesting this.
_________________ Doug Sire 601XL
Do Not Archive |
yak52
Posted: Wed Jul 22, 2009 8:36 am Post subject: LAA Testing |
"Roger,
happened without really digesting this."
No, I don't have a copy of the NTSB metallurgy report. All I have is the full narrative, which I believe must be based in part on that report. Please post that part of the report where the cause of the accident is stated. Not the result, but the cause.
I don't want to understand what might have been the cause . We have all heard endless speculation. I want to know what the cause was within reasonable engineering probability and certainty. Unless one has the cause of an accident within some reasonable degree of engineering probability, then any changes to the airframe are being based on guesswork. Its analogous to taking your car to the shop- the mechanic only listens to your description of the problem and making no investigation himself, changes a part. He then sends you on your way to be a tester for his actions in parts replacement. If it works, fine: if it doesn't you're the one alongside the road. You won't know until its too late. The same thing is being done to this airframe. Thinking that making these modifications is the cure only puts you in the spot of the car owner. Hopefully, the pilots are now aware of the V speeds, sensitive elevator and cable tension characteristics of this airplane and will fly the airplane accordingly, making the modifications only redundant. The only thing we know is that these modifications will get the LAA of Zenith's back and put the airplanes back in the air. The true effect of the modifications is unknown because the LAA refused to do before and after testing.
tigerrick(at)mindspring.c Guest
Posted: Wed Jul 22, 2009 9:05 am Post subject: LAA Testing |
Well put, Roger.
Thanks.
Rick Lindstrom
ZenVair N42KP
