Oxygen System
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
trigo(at)mail.telepac.pt
PostPosted: Mon Apr 03, 2006 10:16 am    Post subject: Oxygen System Reply with quote
And the controller/regulator, which one did you use and where did you put
it?
Carlos
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Leland Collins
PostPosted: Tue Apr 04, 2006 7:50 am    Post subject: Oxygen System Reply with quote
Carlos, the main valve and the flow-regulator valve on my Aerox system
are on top of the bottle and that is why mine is so hard to adjust in
flight. I have to twist and reach and try not to dump the plane on it
side while I adjust the flow rate. Some oxygen systems have the
flow-regulator valve on the bottom of the flow-rate meter so that you
can look at the rate while adjusting it.
Leland
Time: 11:16:12 AM PST US
Subject: Re: Oxygen System
it?
Carlos
Leland
RV9A
N137LC
oliveira(at)frontiernet.n
PostPosted: Tue Apr 04, 2006 2:58 pm    Post subject: Oxygen System Reply with quote
Please move the valve somehow! You may not remember, but the cause of the
accident that killed John Denver was a fuel valve that was positioned behind
the pilot on one side. He had to twist around to switch tanks and lost
control of his newly purchased long EZ.
You may be more careful, but no sense having any contol you have to get to
in flight that causes that kind of disruption.
John Oliveira
N909RV reserved. working on Fuselage
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
